Needed codes for RCA312W to control Sylvania tv sst 4273
Have a Sylvania tv sst4273. need codes for a rca312w remote to make tv work
Code 1192 works using my rca model rcr4358 universal remote with my syvania sst4273 tv
Posted on Sep 15, 2009
SOURCE:
Need a list of tv codes for the rca312w remote
Thank you for posting your question at Fixya.
You can find the list of TV codes in this link http://www.scribd.com/doc/2218751/RCA-Universal-Remote-Codes
Have a great day! Jas247
Aug 28, 2011 | RCA RCR312W Remote Control
Procedure to code in for rca312w remote to ge televsion
Turn on the TV, press and hold down the TV key, while holding down the TV key enter one of the four digit codes, the LED light should go off, if not, repeat the steps using a different code....hope this was helpful...
May 28, 2010 | RCA RCR311B Remote Control
How do you program a rcr312w
I have a RCA312w remote and a Orion tv ....how do I set the remote to the tv?...
Feb 01, 2009 | RCA Universal Remote Control
Listed code for my Memorex DVD/VCR not working
I HAVE RCA RCA312W TV AND I NEDD THA CODE TO PROGRAN A SONYO TV
Jan 16, 2009 | RCA Universal Remote Control
I have a rca312w control and the codes to program my sylvania tv
Try these codes 0054 or 0030
How To Program Your Remote Control
  1. Turn device to be programed on.
  2. On the remote control, press a device key one (e.g., AUD, VCR, TV, or CBL). Press and hold SETUP until the selected mode key blinks twice, then release SETUP.
  3. Locate the four-digit code found in the list below that corrisponds with the device you are programming then enter that four-digit code. If performed correctly, the selected mode key will blink twice.
    (NOTE:If the selected mode key emits a long blink, the code is invalid. Repeat steps 2 and 3 and try entering the same code again.)
  4. Aim the remote control at the device ad press POWER once. The device should trun off. If it does not, repeat steps 2 and 3, tryin each code for you brand until you find one that works. If it still does not work, try searching for the code.
  5. Repeat steps 1 through 4 for each device you want the remote control to control.
Nov 11, 2008 | RCA 3-Device Universal Remote with...
Hola
Hola,
Aca tenes un manual de tu tv:
http://www.sylvaniaconsumerelectronics.com/pdf/om/SST4273.pdf
La pantalla esa que te quedo fija debe desaparecer a los 10 sec si no apretas ninguna tecla.
Creo que antes de hacer nada con tu tv te recomiendo que seria bueno que te consigas el control remoto original de tu televisor.
aca tenes una opcion a 24 dolares ---->>>
http://www.funai.newremotecontrol.com/catalog_item.php?catnum=NE121UD
y aca el original por 34 dolares ---->>>
http://www.remotes.com/store/sylvania/sst4273.html
Seguramente con el remote original desbloqueas tu televisor.
Espero que soluciones tu problema pronto.
Dejame saber como te fue
This will fix your problem.
Please don't forget to rate my help!
Thank you for using FIXYA!
Have a great day!
Pablo :-)
Oct 19, 2008 | Electrical Supplies
Codes for sylvania tv
I purchased a sylvanis lcd tv and it won't work with my comcast cable remote...I can't turn it on or off with it or turn up or down the volume. i've called my cable company 3 times and they can't seem to help me. Can you help?
Feb 10, 2008 | Zenith ZEN450 Remote Control
Sylvania TV
i had a sylvania tv and i accidentaly cracked my remote... i got this remote and it will work for a little wile then it will stop working for a wile, then it will work and now its been a wile and i forgot the code for this tv.... i only wantthe code but i cant find were to get it... i will try codes from other sites but they dont work
Dec 27, 2007 | Televison & Video
Televison & Video Logo
668 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
