Haier HDN655E Dehumidifier
Problem for Haier HDN655E Dehumidifier
Runs but does not collect water
By shardanl3 on Jul 19, 2009
runs but does not collect water. Humidity is not going down.
Best Solution
posted on Aug 01, 2009
Helpful)
paulr621
Rank: Apprentice
Rating: 92%, 4 votes
It is possible that the cooling fins are not working due to insufficient coolant or the compressor system is faulty. Basically the fan pulls air across a cooling fin . Moisture from the air then condensates and falls into the pan as water. The air is then heated before it exits into the surroundings. The fact that there is no water collecting suggests that the cooling stage is not working. I see from other posts that there is a fuse somewhere. Maybe this fuse is blown and is associated with the cooling compressor..hope this helps
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Haier HDN655E Dehumidifier
Questions and Unsolved Problems for Haier HDN655E Dehumidifier
Do you recommend Haier HDN655E Dehumidifier?
Answer
Answer
I have a haier dehumidifier 45 it does not have a manuel. It runs all the time - how do you set it?
Answer
the motor runs and air blows out of the back of it but no water collects in tank
Answer
I have a Haier Dehumidifier HDN655E without a manual. I can not find a manual on-line. It runs all... (More)
Answer
need to replace zener diode ZD2. I assume I would but 1.5v zener diode?
Answer
How can I fix this? Purchased at Target in Appleton, Wisconsin. Does Haier have an 800 number?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Haier HDN655E Dehumidifier:
Top Dehumidifier Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Dehumidifier Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
