Question about Canon PowerShot S5 IS Digital Camera
External flash interferring with lighting
My camera over compensates when using an "off the camera" extra flash to help with more light. The photo ends up being darker than just using the normal flash on the camera.
How can I stop the light bounce with just using my flash and using other light source without my camera being too sensitive.
    Problem Solver:
  • 17 Answers
Its not clear which camera you are using and there may be different solutions to your problem....
All SLR digital cameras and most of the "higher grade" digital cameras have an option whereby you can adjust the intensity of the camera's flash. This can make the world of difference.
Then you also have the option of setting the flash synchronisation to respond to what Canon call "First curtain" or "second curtain". This can make a huge difference. If your camera is set for the flash to fire at first curtain, it fires as the shutter opens; and as it closes on second curtain. Sounds technical, but it is worth checking, as there is a difference.
You should also check what your settings are for the "off camera" flash. Synchronisation is key. It sounds as tho your off camera flash is way out of sync
Posted on Apr 10, 2008
Why is the white background not white?
This is a common problem. The metering and light balance are the reasons that you are having problems achieving good results with your photos.
All cameras on the auto cycle are calibrated for 18% gray. Another words a photo of all white results in 18% gray. A photo of black results in 18% gray. The camera adjusts the shutter speed and aperture to achieve an average light level of 18%. That is why photos of snow always appear gray. To compensate for this characteristic of the cameras an 18 % gray panel is held in front of the camera and than the settings are set.manually. The metering in the camera is now locked and using the same light levels objects will be in their natural level.
A second problem is the white balance. Using flash avoids some of these problems. Adjusting the camera for source lighting type will help the most. The light balance is the cause of discoloration of the objects in the photo. Usually the camera white balance can be set for auto, incandescent, fluorescent, outdoor or flash,
Use a manual setting if it is available on you camera, You need to adjust the settings until you get acceptable results. If the photo is dark add light by reducing the aperture number to a lower number allowing more light. After the aperture is open wide(lowest number) increase the exposure to longer time. With very low light levels a tripod may be necessary.. After doing this once record the numbers for next time.
Nov 15, 2015 | Nikon COOLPIX L100 Digital Camera
My friends and I want to shoot senior photos in the basement but don't have external flashes is there a way to get the same effect without them?
Depending on your camera. Adobe has a free version of Photoshop that allows you to alter your photos.
Oct 01, 2013 | Photography
Grainy pictures
If you are taking pictures in low-lighting conditions without flash, then the pictures will appear grainy. Set the ISO to a lower number (try ISO-100 to start with) and use the flash to compensate for low-light conditions.
This should improve the grainy appearance of your photos.
Dec 29, 2010 | Nikon D100 Digital Camera
Portrait provides extra sharp focus on the subject. It also opens the aperture some, and may in SOME cases give you a blurred backbround depending on the distance of the subject and background to the camera.
If outdoors, consider setting the camera to manual flash so that it will lighten the subject. If indoors, consider turning off the flash. You may need to provide better external lighting on the subject, or use a tripod and ask the subject to hold still during the picture.
Try increasing the zoom (best is to set it to maximum), and then adjust your distance from the subject to get as close as possible. Note that you still might be standing relatively far away because of the zoom.
Another way to experiment further with focus and blurred backgrounds is to use aperture priority (Av) mode on your dial. Use the right/left button to set the lowest "f-number" on your screen. The lower the number, the greater the aperture. All other functions of your camera will automatically compensate. Again, use max zoom in taking closeups with low "f-numbers". Also experiment with the manual focus to pay particular attention to achieving sharp focus on your subjects eyes.
You have a very capable camera. It can do what you're thinking of. You just need to practice with it. It's digital, experiment with the above techniques. Throw away the bad pics and keep the good, noting which technique worked best for the lighting and situation.
Dec 28, 2009 | Canon PowerShot A710 IS Digital Camera
Canon Powershot SLR takes fuzzy photos
you need additional flash or brighter light to click in low lighting condition. In order to compensate for low light conditions, the shutter goes slow and therefore you get fuzzy pictures.
Another way is to click on movie(video) mode and then atleast you can see them moving around as well as while editing, you could take out some pictures from the video( though on lmuch ower resolution).
Jan 28, 2009 | Canon PowerShot S5 IS Digital Camera
Taking photos
Set the camera flash to auto. A digital camera will automatically use all available light to take a picture, and will only use extra light (the flash) if it needs to.
By using manual flash you are over exposing your shots..... giving it more light than is required.
Give it a try.
Jan 10, 2009 | Praktica SlimPix Digital Camera
Indoor pictures are way too dark
Most cameras have an EV or a +/- exposure setting. Go into the menu and check for EV compensation, or a " +/- " button. Set it to overexpose " + " one stop at a time til you get what you want. Please leave feedback if this helps.
Jul 26, 2008 | Cameras
Indoor photos are too dark and skin tones orange-ish
I have the same problem at my church with the indoor lighting on my camera. I'm able to get it work by putting the whole thing on manual and adjusting the lighting settings that way.
Jun 13, 2008 | Sony Cyber-shot DSC-W70 Digital Camera
PROBLEM: F828 & external flash
I think this is due to the TLL preflash of the 828 internal flash. Each time it actually fires 2 flashes. First one for metering and second one for actual exposure. First "fake" flash probably trigers your external flash which is too early. Slution... hmm i think there are afordable slave adapters out there which detect the TTL preflash, ignore it and fire the external flash on the right timing along with the main flash. cost.. about few tens $ i think. they can detect also infrared light so you can mount IR filter on your internal flash to prevent interfering with the exposure...
Sep 12, 2005 | Sony Cyber-Shot DSC-F828 Digital Camera
Picture too light
The cause and solution may include one of the following: The flash is not needed. Change to Flash Off or decrease the flash compensation in any of the PASMC modes (certain cameras only). The subject was too close for flash. Move so that the distance between you and the subject is within the effective flash range. There is too much light. Decrease the exposure compensation. If you use flash, adjust the flash compensation in any of the PASMC modes (certain cameras only). Auto-exposure was not set. Press the shutter button halfway and hold. When the AF/AE indicator turns green, press the shutter button completely down to take the picture (most cameras).
Aug 29, 2005 | Kodak EasyShare One Digital Camera
Canon PowerShot S5 IS Digital Camera Logo
55 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
