Question about HP Pavilion F1503 15" LCD Flat Panel Monitor
I have the same problem with the same flat screen
When I booted up the system the light on the side just blinks and does not do anything else - this monitor is always shut off at night and is only a year and a half old - please help
  • Robert Salgado
    Robert Salgado May 11, 2010
    sound like your tower either on board video card or your video card it self in pci slot is not reqen the monitor anymore. I had a problem like that and had to disconnect my video card and reconnect to have it read my card again. But if this don't work get a old monitor or someones and test your monitor might have just gave out. or u can just reformat your pc
  • 41 Answers
Hi
please check that the settings is okie on the control pannel in display setting for the monitor ,
if it is okie then go to run and in run type msconfig ,once u do this it will give u a system configuration box ,then in the sytem try to do the normal startup for the computer ..
if it still doesnot work then try to run a tool called dial a fix and u can get this is google
Posted on Jul 22, 2009
Tx2000 hp laptop not booting up, all lights are on green except amber light from wireless button
Do you get anything on the screen at boot? When you removed the HDD did you test it? It powers up, but will not boot correct? Fan spins, LED's Blink? Battery charges? Can you get to BIOS or Boot Menu? Can you do a Restore/Recovery? If you insert a repair disk into the DVD/CD rom drive does it respond? Take a look at HP support page: http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?tmp_task=solveCategory&cc=us&dlc=en&jumpid=reg_r1002_usen_c-001_title_r0001&lc=en&product=3658348
Apr 01, 2013 | Computers & Internet
Aux power led light is amber on dimension E521
I think your problem is your memory or video card.
Below are some steps that I recommend.
When you plug in the power cord is there any lights whatsoever on the computer?
When you press the power button do you hear fans running, hard drive spinning, lights on the computer, hear any beeps or lights constantly blinking, hear the DvD/CD drive click and the light on the drawer of the DvD/CD turn on for a second or two? If so the laptop is trying to boot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with the computer and why it is not booting. Most times it's a motherboard issue when you hear beeps or blinking lights continuous. Most times the problem is with the memory or Video Card. Count the Blinking Lights or Beeps and take note of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoever when you press the power button.
Maybe you have a Static Charge Buildup. Remove the Power Cord, then Press and Hold the power button for 30 seconds. After 30 seconds plug the power cord back in and hit the power button to see if it boots.
Maybe your memory is bad or the memory slot is bad.
Remove the Power Cord, Open the Case and remove one of the memory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and try rebooting. If it fails take the chip out and set it aside, then put the other chip in and try booting it in both slots. If it boots, just to verify that the chip set aside is bad, mark an x on it and put it into the open memory chip slot and try booting.
Maybe your power supply is bad. Sometimes there is enough power to make the power light or some other lights come on but not enough power to make the fan turn on or hard drive spin.
Below are links and info I found from Dell's Website based on your model.
http://support.dell.com/support/edocs/systems/dime521/en/SM_EN/specs.htm
Controls and Lights Front of computer:
Power button - push button
Power light
green light - Blinking green in sleep state; solid green for power-on state.
amber light - Blinking amber indicates a problem with the power supply inside the computer. If the system cannot boot and there is a solid amber light, this indicates a problem with the system board (see "Power Problems" in your Owner's Manual).
Diagnostic lights
four lights on the front panel (see Diagnostic Lights.)
Standby power light
AUX_PWR_LED on the system board
Hard-drive activity light
green light - When the computer is reading data from or writing data to the hard drive.
LAN indicator light
green light - Solid green indicates that a LAN (local area network) connection is established.
http://support.dell.com/support/edocs/systems/dime521/en/SM_EN/adtshoot.htm#wp1056411
Jun 03, 2012 | Dell Dimension E521 (D10E16) PC Desktop
Power light is blinking
Count the blinks and the pattern of the blinks (3 long blinks, 1 long blink followed by 2 short blinks, etc.).
Remove the Power Cord, Remove the screw and cover that houses the memory and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.Does anything post to the screen at all when you press the Power Button? Maybe your video card is bad.
Apr 15, 2012 | IBM ThinkPad T41 Notebook
Blank screen
Did it boot all the way? Do you hear the fan running, disk drive spinning? If it sounds like it booted but the display is black, try this:
When you press the power button do you hear fansrunning, hard drive spinning, lights on the computer, hear any beeps or lightsconstantly blinking, hear the DvD/CD drive click and the light on the drawer ofthe DvD/CD turn on for a second or two? If so the laptop is trying toboot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Apr 14, 2012 | Computers & Internet
D100l has blinking caps lock
Give us more details if you want help. Blinking Caps when? When you boot up? Is it booting all the way so you can use the computer?
Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
Does anything ever post on the lcd screen?
Apr 06, 2012 | Computers & Internet
When i start my computer , i see a blank screen and a dash is blinking on the upper left hand corner. i am not able to do anything besides (F12) boot system
just open the right side cover of your pc and unplug the powercable of harddisk and plug the otherone or same and then try again. chek all your data cables too.
Apr 19, 2011 | Computers & Internet
Laptop not booting up and nothing showing up on the screen
What leds you can see blinking on laptop? Can you hear any bootup sounds? Sometimes my laptop hangs on standby or hibernat, then screen is black and some leds may blink. Usually i need to take charger and battery off for 10 seconds and boot up again. If that dont help then there must be some hardware damage.
Jan 27, 2009 | HP Pavilion FE849UA Notebook
HP Pavilion F1503 15" LCD Flat Panel Monitor Logo
93 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
