Question about Kenmore Refrigerators
On my Kenmore 106.73842300 refrigerator, the unit
With my Kenmore 106.73842300 refrigerator, the unit is intermittantly not cooling (both freezer and fridge). When I first found out it wasn't running, I fiddled with the temp knob and then it started cooling again....for awhile. When it failed again the temp knob wasn't effective. The unit will come back to life for a couple of days and then without warning it will stop working for a few days. It recently came back to life and has been working for a couple of days again. Any ideas?
hotuna
  • 288 Answers
SOURCE: Kenmore Elite refrigerator stops cooling - Relay keeps cycling
The compressor is locked up. Basically it is stuck. You can pick up at the local appliance parts store a hard start relay, Home Depot ,Lowes, or or those guys wont have it. Its not too expensive and is worth trying because your only other option is you need to replace the compressor. The part is called a kick start or hard start, the guy at the parts store will know what you are talking about. It is simple to connect and has the wiring directions on it. Sometimes this is all it takes. I have been able to get a stuck compressor to go by placing a short 2x4 on it and whack it with a hammer a few times. This is only a temporary fix though, as it will eventually lock up again, but emergency situation this saved the food. If the fridge has a fan back there make sure it works too, it may have been the original cause. Good luck.
Posted on Dec 26, 2007
SOURCE: Kenmore Elite bottom freezer refridgerator
I just went through this with my refridgerator and actually posted one of the questions. Here is what I found ........
In the freezer compartment behind the panel there is an evaporator fan which pulls cold air from the freezer and pushes it up into the refrridgerator compartment. If the fan is not working it is one of three things.. 1) there is so much frost in the fan area the fan blade is stopped and cannot push the cold air into the refridgerator compartment or the air channel is blocked. 2) there is no electricity going to the fan (usually tied to the door switch of the refirdgerator compartment, and 3) the motor is dead and will have to be replaced.
Solution to #1 - defrost but there is another problem in the "frost-free" part of the system which must be addressed or the frost will return and it will happen again in the future.
Solution #2 - check to see there is power to the fan. (most are 110VAC but some are 100VDC. Use a meter and check)
Solution #3 - If there is power, the motor is dead. Replace the motor. Be aware that AC and DC motors are different and replace per manufacture's specifications.
Posted on Nov 23, 2008
SOURCE: GE side by side refrigerator. Fridge side not cooling - help!
Hi, they have changed lots of parts, were they defected, did they tested parts for faults or they just change parts, because it's available, there's always a reason why a certain part, go bad. so far you change most of parts in ref. check refrigerant (gas, freon) pressure, check compressor, for faulty suction and high side valve, it's possible your compressor loosing efficiency. or say if compressor normally pump 50 psi. now it's pumping 40 psi. is the refrigeration cycle balance ? is there restriction in your ref. system? is compressor running long enough? plug on ref. let it run for 1hr, listen to compressor for any clicking sound, fans and everything else could be working, be compressor not, compressor could be short cycling (not working long enough) also check voltage in receptacle(outlet) with digital multi-tester, get accurate voltage reading, let me know, could also be a faulty circuit breaker in house (building) not your ref. let me know, system could have very slow refrigerant leak, you could have a very small (slow) gas leak, that's why your refrigerator get hot first, then your freezer, there's a condensate line (loop) that passes through, ref body, close to doors to prevent door gasket from freezing, after few years sometimes develope leaks, cause by rusting. it's very possible there could be small leak in your system. let me know what happened.good luck.
Posted on Aug 14, 2009
Sea Breeze
  • 4654 Answers
SOURCE: refrigerator not cooling
You model if the ARB1950C has a defrost timer inside the fresh food compartment and behind the temperature control panel. Need to see if you can manualy turn the timer clockwise until the compressor stops. During that time of 25 minutes the freezer should be in defrost. I believe your timer needs replaced based on how you explained what is happening. The part number for your timer is 67001036 and can be found at the links below. If it stays longer that 25 minutes then it's sticking in the defrost section of the defrost timer and will need to be replaced. If your refrigerator does not restart after about 25 minutes then slowly turn the timer through the opening in the plastic cover. There may be a plug covering the hole to make the hole not so visible. If you should have problems fell free to let me know, Thanks Sea Breeze
appliancepartsse@yahoo.com
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com/
Posted on Aug 17, 2009
  • 2122 Answers
SOURCE: Maytag MZD2766GEW side by side refrigerator fridge not cooling
you have a defrost problem, could be bad adaptive defrost board,t-stat heater,when you open freezer door listen for fan if fan is blowing check the t-stat,look at it and see if it has a buldge on it,sometime you can see this and tell it's bad,you'll need a meter to read out the heater and other parts to see whats bad,might be a good idea to call a tech to do this,when you find problem you have to melt everything out again
Posted on Oct 31, 2009
The refrigerator portion of our unit is not cooling, however the freezer is still cooling just fine. Any ideas what could cause this?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 05, 2011 | Kenmore Top Freezer Refrigerator
Kenmore refrigerator 598586 intermittent cooling. when not cooling only condensor fan runs. evap motor has been replaced by service company same problem. thanks
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 16, 2010 | Kenmore 58522 Side by Side Refrigerator
The unit cools and freezes good for 3 to 4 weeks then it dosent cool. unplugf it for a day or two and it woorks good again for another 2 to 3 weeks.
The defrost may be sticking...this can be an intermittent problem and hard to pin down...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 22, 2010 | Kenmore 53542 / 53544 Side by Side...
Freezer working fine-refrigerator not cooling-unit bought 1998
heatman101
tydue6
Oct 17, 2009 | Kenmore 50522 / 50524 Side by Side...
Refrigirator is not cooling. Freezer is cooling
if you have a bottom freezer, you need to defrost the unit the cool air from the freeezer is what cools the top part, but the channels are iced up
unplug the unit and let it thaw out overnight
Sep 12, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
2 yr old kenmore refrigerator with bottom freezer. Refrigerator not cooling. Freezer is
This unit has an electronic speed control on the condensor fan which controls the cooling in the refrigerator unit. The electronic control failed which allowed all items to work as intended just without a high enough fan speed to cool the refer unit.
Aug 23, 2009 | Kenmore Refrigerators
Refrigerator and Freezer stopped cooling after intermittent noise
Hello
if the ice maker arm is down regardless of the water being off the valve will energize ( dry ) no this will not effect cooling
Apr 12, 2017 | Kenmore 73503 Stainless Steel Bottom...
Refrigerators Logo
79 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
