Question about Craftsman 25cc Gas Line Trimmer
Poulan Model 112 String trimmer with a 21 cc engine w/ fuel leak.
Worked fine last week. Filled with gas this week and picked it up and fuel started to pour out the air intake.
  • 8 Answers
SOURCE: Poulan Pro Gas Trimmer Carb Problem...
try and adjust the fuel/oil mis screws
Posted on May 12, 2009
redbeard00
  • 957 Answers
SOURCE: I have a craftsman 25 cc string trimmer with fuel
You shouldn't notice a difference if you remove the air filter. So I would replace it. Also if you are using compressed air to clean or blow-out the carb. Be careful, its not recommended and could make it worse.
Posted on May 14, 2009
  • 376 Answers
SOURCE: Craftsman Edger 536-797520 is leaking gas from the air filter
The needle valve is sticking open. The carb needs cleaning and diaphragm replaced. Probably best taken to a shop unless you have experience with diaphragm carburetors. Dwain
Posted on May 27, 2009
  • 83 Answers
SOURCE: 32 cc string trimmer will not run
It sounds like you need to adjust the fuel mixture screw in the carb. To do this, while it is running adjust the screw in either direction until it runs properly without the choke.
Posted on Sep 10, 2009
hunter19_46m
  • 7482 Answers
SOURCE: I have a ST622 walk-
Check your fuel filter if you have one, normally they will be located in the fuel tank.
If the mower/weedeater is over a year old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instrucitons you get with the carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their orginal position before you started.
This is a FREE answer,Please rate me
Posted on Apr 09, 2011
We have a propane tank outside to supply our range stove in the house for some reason the gas is not reaching the stove anymore , can it be the cold weather?
I would suspect the regulator might have iced and maybe if you poured hot water over it it would pass on thru system but be prepared to buy a new one if it doesn't .
Jan 13, 2015 | Cars & Trucks
Truck will turn over but not start
Try pouring some gas in the intake dont go nuts with gas just a few ounces if the vehicle starts and then shuts off you have a bad fuel pump. I have a 1996 Blazer and I replaced mine last year make sure if that is the problem that you shop around for a price because it could save you hundreds of dollars shop around. If it runs and keeps going it could be you fuel injectors are bad. Last winter i had to put gas into my intake when it got real cold. What happens is the fuel gels when it gets cold and it makes it harder for the injectors to take it in . I also replaced my fuel injectors now this winter it starts right up.
( If you dont no where the intake is locate your air filter and follow the intake vent where the vent hose connects to your engine. Unscrew the clamp pull off vent hose and then pour the fuel inside of engine fuel intake manifold. I will bet money your vehicle will start if it dont you have some type of electrical situation.
Jan 05, 2011 | 2000 GMC Jimmy
My car ran out of gas I put gas in it and now it qont start
we just had to replace the fuel pump in our 96 deville, The mechanic said that running the car with a low level of fuel can cause strain that would cause it to break,
Nov 28, 2010 | 1996 Cadillac DeVille
So my gas gauge doenst work so I ran out of gas and died out on the side of the road. I walked to the gas station filled 10 dollars and filled my car up. Tried to start it but it sounded like it wanted to...
Hi!!If you keep trying to start the car with an empty tank, air gets in the lines an make it hard to start. Look in the fuel rail for the service port valve, it looks like the one tires, it has a plastic or metal cap, unscrew it and place a rag under while you push the valve with a small screwdriver, do not push too hard or you'll damage the valve. once you push and release the valve, turn the key to the ON position for 5 secs. and repeat the procedure, if needed do it again until you get a solid stream of gas. It will be nice to have somebody turning the key while you do the bleeding. It always worked for me. As a last resort, use starter fluid on the intake, manually open the throttle and spray a little, place the air hose and crank it up. Stay away from the intake when engine is cranking, it may backfire.
Good Luck?? Don't forget to rate this post!!
Sep 26, 2010 | 1997 Pontiac Grand Prix
Why does fuel leak out the intake of my 98 yzf600r when I try to start it?
Your float needles may not be sealing right, and too much fuel is getting into the float bowls, after they are filled gas still keeps pouring out and has nowhere to go but the intake air box.
Make sure your petcock is not left on for more than a few seconds when you go to start it.
Apr 03, 2010 | 1998 Yamaha YZF 600 R thunder cat
Last week, had same problem 1994 buick roadmaster car cranks, (turns over)& no start changed the fuel filter, car turned over & ran fine for 1 week, now same problem?? can someone help me??
I might suggest pouring a fuel additive in your tank. Possibly you have some condensation/bad gas. Pour it in and let it sit overnight. See if it helps... it won't hurt.
Oct 16, 2009 | 1994 Buick Roadmaster
Craftman leaf blower when I press primer bulb I get air in line. It seems to be coming from block that choke is attached to hoses look good.
Diaphram gasket in carb is swelled and air is getting through,get a carb reduild kit and it should be fine.
Aug 05, 2009 | Craftsman Blower Attachment
95 aurora wont start
did check engine light come on? if so have codes checked there are many things that could cause this issue, cam sensor, could be one issue
Jul 07, 2009 | 1995 Oldsmobile Aurora
Will not start
Replace the spark plug, dump out the old gas and put in new fuel mix, and replace or clean the air filter.
Apr 21, 2009 | Dishwashers
Car won't start without adding gas to air intake then won't idle
Check the fuel filter, you may have clogged it when you filled the tank.
Mar 15, 2009 | 1989 Audi 90
Craftsman 25cc Gas Line Trimmer Logo
179 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
