Question about Samsung DLP HL-P5663W 56" TV
Sony kv 40xbr800 no pictur and 6 times blinking lid on .
  • taeikchung41 Jul 19, 2009
    I try to order new ic.
    I have obc(over b+ current) error, what part defective the kv-40xbr800.
  • 10,594 Answers
Please replace IC6501 and IC8002 on D Board of Sony KV-40XBR800 TV to solve no picture and 6 times blink error.
Both ICs are same part number that is MCZ3001D, located nearby on D board (main board) and available in Part Store.
Thanks.
Posted on Jul 19, 2009
Sony kv-40xbr800 standby light blinking no picture
Check this site to get more details about the blinking codes to Sony TVs.http://electronicshelponline.blogspot.com/ Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Sep 05, 2013 | Sony Kv-40xbr800 Da4 Deflection Yoke...
I havea Sony KV-40xbr800 screen won't turn on red light blinks 6 times, tried plugging directly into wall outlet & no picture still. Any help please ?
Power supply. Disassemble and be careful tv is not plugged in. Check capacitors on power supply for bulges on top. Replace but make sure u deenergize before removal by touching the two poles together. I use a small nail file
Aug 08, 2012 | Sony Kv-40xbr800 Fd Trinitronr Xbrr Wegatm...
Sony kv-40xbr800 blinks two times
  1. Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
Jun 09, 2012 | Sony FD Trinitron WEGA XBRKV-40XBR800 40"...
My sony kv-40xbr800 blinks 6 times, no video no audio, it wont turn on, whats going on?
The problem is on the 'A' circuit board. It is the IC504.Or, it is a low voltage drop or a short. Replace the "A" board. It is the front board on your right when you are at the rear of the set when you remove the cover. Look it up on the net. PS Don't touch the chassis while it is on...HIGH VOLTAGE !!!
Aug 02, 2010 | Sony FD Trinitron WEGA XBRKV-40XBR800 40"...
Sony WEGA KV-40XBR800 Standby light blinks seven times when trying to power on, will not turn on
there is a problem on the power supply section of your tv.try to check the regulators horizontal output,and bad capacitors.
Jun 14, 2010 | Sony FD Trinitron WEGA XBRKV-40XBR800 40"...
Sony FD Trinitron KV-40XBR800 wont turn on
30 YR SERVICE TECH.
YOUR UNIT IS EXPERIENCING A POWER SUPPLY FAILURE.(INTERNALLY)
TAKE TO A SONY AUTHORIZED SERVICER.
Jan 12, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony VEGA KV-40XBR800 d Board failure
sony kv-40xbr800.......doesn't turn on......standby light blinks 6 times....what might be the problem?....is it worth fixing?
Dec 27, 2008 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony Wega 40" TV will not turn on, standby light blinks 6 times repeatedly
Hello,For model KV-40XBR800,
Pls check following area.
Low HV Shutdown:
On the D Board.
Check IC8004/pin 7 should be 7.4v.
Check IC8006/pin 2 should be 2.5v if lower will trigger shutdown by causing pin 1 to turn on.
Check IC8006/pin 3 reference voltage 2.2v.
IC8006/pin 1 normally at 0v. If high
turns D5007 ON which turns the latch circuit Q6532,
Q6530, and Q6527 ON and turns the AC relay RY6501 OFF.
And NOTE: 6 blinks also can be Low B+ protection.
Unregulated 7.5 v from the power supply to 5v reg IC504 on the A Board. 5v to M Board Q2314
to CPU IC2300/pin 43. If 5v missing set will shutdown with 6 blinks.
Good Luck
Dals123
Oct 05, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony kv-40xbr800
Exact same problem. KV-40XBR800 wont turn on, blinks six times. I am in the process of changing both Ic's part# MCZ3001D with part# MCZ3001DB. Ordered them frm ebay and waiting for the new parts to arrive.
here are the pictures of both chips and after i removed them from the d board.
As soon as i receive the new ones i will put them in. I can't wait to see what happens and i wanted to say thanks to all of you out there for putting this thing up. Thank you very much.
Nov 05, 2007 | Sony KV-40XBR700 40" TV
Sony KV-40XBR800
You have the famous regulator problem, or the bad regulator problem, or the cold solder connectioin is on or around the flyback transformer.
Sep 09, 2006 | Sony FD Trinitron WEGA XBRKV-40XBR800 40"...
Samsung DLP HL-P5663W 56" TV Logo
128 people viewed this question
Jerry Greenberg
Jerry Greenberg
