Question about POSX POS-X Xi2000-BT Handheld
How to replace battery xi 2000 BTs
I have same problem .It works when in cradle.I want to replace battery but how to open scanner and which battery I need. Any one knows pl write
    President:
  • 566 Answers
Look in the base of your scanner. There should be a clip holding and securing the battery.
Check the user's manual. I couldn't find one for your model, but check this one for the Xi3000-BT that replaced your scanner:
http://www.totalbarcode.com/download/Xi3000-BT.pdf
Posted on Jul 20, 2009
I changed the battery in my ms9535 & now it doesnt scan
First ,make sure to let it charge over night. Second, you may need to scan the bluetooth barcode located on the top of the charging cradle. This will tell the scanner which base to communicate with. If the charging cradle has a solid blue light, then the bluetooth connection is good.
Aug 07, 2014 | Metrologic Instruments MS9535 VoyagerBT...
LS4278 no laser
There are three possibilities I can think of assuming this is not a brand new scanner:
1. The LS4278 is faulty - which given Symbols quality I would say it is normally not the case unless th scanner has been dropped or otherwise damaged.
2. The cradle is not charging the scanner. You may wish to try another cradle - one that you know is charging aother scanner. After a few minutes you should be able to see the laser.
3. The battery in the scanner either needs a recondition (see product reference guide), or needs replacement.
Apr 14, 2014 | Symbol LS 4278 Barcode Scanner
My Motorola MC9590-K keeps telling me the USB device is not recognized when I connect with the cradle. The unit does it even when I use a different cradle.
Is it the right cradle to connect. Sometimes the cradles look alike but actually are different. You can check the back and the bottom and see whether all the ports are the same between those cradles. Replace the battery and see if you suspect that is a battery issue. Some of those batteries are not really endurable.
Sep 10, 2012 | Motorola MC9500-K Handheld Mobile Computer...
My ls4278 is not lighting up when on the cradle, will not scan or charge...i have 3 scanners and cradles and somehow all the scanners stopped working completely..all the cradles have the light on but when...
The most unlikely scenario is that all the bases are defective. If you power your PC off every night, you should purchase a power supply so the scanners can continuously charge. Another issue may be that you need new batteries (also unlikely if they stopped working at the same time). Also try swapping scanners and bases (one scanner from one base and place it with another base) make sure you firmly place the bottom of the scanner in the base to verify there is a good connection with the charging pins. We are here to help if you have further questions.
Tech Support Barcoding Technical Support
May 18, 2011 | Symbol LS 4278 Barcode Scanner
My Radio Shack Pro-82 Scanner batt. went dead , now I have no sound
That means you have to put new batteries in your scanner... or recharge your rechargable batteries but if you use rechargable batteries use your yellow battery cradle for rechargeable batteries and your black cradle for alakline batteries....foe pro 82...
Feb 28, 2011 | Radio Shack Pro-82 Scanner
My symbol barcode scanner beeps 4 time while I try to scan. The Manual states that the battery is bad. I replaced the battery & it does the same thing.
This 4 beeps also stays for communication error. Please check the connection to the cradle and also the connection between the cradle and PC.
You can start by pairing the scanner with cradle with the Pairing barcode, then defaulting the scanner to the standard settings - use the barcode "Set All Defaults" from the manual. Then select the right host type USB, RS232 or another.
After this procedure should the scanner work.
Sep 07, 2010 | Symbol LS3578-ER Rugged Barcode Scanner
I have a symbol LS4278 scan gun. When I place the gun in the cradle it blinks with an amber light. In the documentation that says that it has a "Critical battery temperature fault". I replaced the...
Hello Lynda,
this seems to be an error with the charging system of the scanner. As you stated the error occurs also with other battery. Just check if the scanner is in warranty and send it for repair.
It could work also with this error, but the charging will not work correctly. As the temperature error is safety measure which stops the charging until the status get changed.
Aug 02, 2010 | Zebra LS4278 Cordless Bar Code Reader...
DS 3478 Will Not Power UP
make sure you have a 3478 cradle. We ran into that. We have 3478's and 3578's. You have to look at the gun and cradle to match up. 3578 replaces the 3478. Bless Symbols heart the two aren't interchangable. Can't tell the difference except on sticker.
Aug 18, 2009 | Zebra DS3478-SF Wireless Handheld Barcode...
The battery seems to not be charging, it only
Check the battery leads to see if one of them was severed somehow. If the leads look good. If the leads look good replace the battery.
Jun 15, 2009 | POSX POS-X Xi2000-BT Handheld
Does LS 3578 ER SCANNER HAVE A DRIVER ?
it can work with ether of them mainly then driver is needed. so i hope that is the answer you wanted and please rate the help i have been to you.
THANK YOU!
Apr 21, 2009 | Symbol LS 2208 Barcode Scanner
Computers & Internet Logo
108 people viewed this question
Top POSX Computers & Internet Experts
David Payne
David Payne
Are you a POSX Computer and Internet Expert? Answer questions, earn points and help others
