Question about Dryers
Kenmore dryer model 869-801-00 serial# m93688044 stock# 69801, 1989 dryer runs but gets no heat. replaced power cord. heating elimate was tested told to be ok. So what else could it be?
  • 6,784 Answers
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
Posted on Jul 19, 2009
MY DRYER WHICH I BOUGHT IN 2009 NO LONGER HEATS UP SINCE ABOUT 8MONTHS AGO! MODEL#110.69422801 SERIAL#MY3088080 TYPE=d433-ele-2406026-fm54
Hi vmalugin1129...
Here are a few things to check:
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape.
If the coil heats up then replace the thermostat/thermistor/thermal fuse as it is faulty.
If you have an ohm meter then you can test the thermostat/thermistor/thermal fuse,
then you do not have to tape the wires together as described above.
To test your thermostat/thermistor/thermal fuseremove the wires from the thermostat/thermistor/thermal fuse and check for continuity, if you DO NOT have continuity then replace the thermostat/thermistor/thermal fuse.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST AS THIS COULD CAUSE A FIRE BECAUSE YOU HAVE REMOVED THE SAFETY.
Check your blower wheel to make sure it is secure to the shaft and not plugged with lint,socks,etc.
If the thermal fuse overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace a generic element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please take time to rate me
Jul 09, 2011 | Kenmore Dryers
My kenmore elite elecctric dryer is running but I get no heat
The most likely cause, is a burned out heating element. Sears has the replacement pparts. You will need the model and serial numbers. The replacement is relatively easy. Disconnect the power and then from the back, take out the screws that hold the element housing in place. Depending on the model, you will also have to pop the top to get the unit out.
May 13, 2010 | Kenmore Dryers
Dryer runs but wont heat
There are 2 possibilities for this problem.
1. The limit switch is out. The limit switch is located on the heating element on the back of the dryer. This is a small button type part. it will have 2 prongs on it for 2 wires that slide on for power.
2. The heating element is out. This will be on the back of the dryer and depending the model it should be a long metal piece that has metal elements inside of it to heat the dryer. or it could be a large round unit. these can be tested with an om meter.
The limit switch will be the cheapest to start with on replacing.
If you need further assistance please do not hesitate to ask. I will need the make, model, and the serial number of the unit to help you further. the model and serial number can be found by opening the dryer door and looking by the hings. there should be a sticker with this information on it.
Apr 13, 2010 | Kenmore 64852 Electric Dryer
No heat in my kenmore elite dryer, model 11085872401(electric)everything else running, tested voltage at 240 ok. pulled the heating element. it looks like a small crack in the middle. Does that have any...
It means your element needs to be replaced, take it to the Kenmore parts store nearest you, and they will confirm that, and you can get a new one there unless they have to order one in.
Be sure to have the make and model and serial number of your dryer with you.
Dec 15, 2009 | Kenmore Dryers
Dryer not heating on any setting.
Check to make sure you are getting full 220 Volt power to the dryer if you are then:
Sounds like your problem may be with the heating coil.
Remove the back of the machine and try to locate the air duct going from the blower to the drum. Normally inside the air duct you will find the heating coil and the thermostats/thermistor.
You can check the thermostat/thermistor by removing the two wires and taping them together with electrical tape.
If the coil heats up then replace the thermostat/thermistor.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause a fire, as you have removed the safety of overheat from the machine.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
Hope this helps
Nov 13, 2009 | Kenmore 62602 Electric Dryer
Kenmore dryer will not heat
only 2 things can be wrong, the heater element is toast or one of the safety thermostats is fried, most likely it is the heating element. make sure its well connected(while unplugged!!!)
Jun 14, 2009 | Kenmore 63942 Dryer
Dryer want heat up
Hi
Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
A ohm meter test for these parts is here.
Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats, motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Please do rate the solution as "FixYa" and revert for further assistance.
Thanks
Rylee
Apr 19, 2009 | Kenmore Dryers
Dryer does not heat
Q - My electric dryer runs but will not heat, what could stop my dryer from heating?
A - Things that could stop a electric dryer from heating:
Q - My gas dryer will not heat, what could stop my dryer from heating?
A - Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
Mar 07, 2009 | Kenmore Dryers
Kenmore HE3 electric Dryer does no heat.
check block where power cord attaches.
Feb 08, 2009 | Dryers
Heating elimate is out
are remove front panel lower below door it can also be there depends on dryer
Feb 29, 2008 | Kenmore 63942 Dryer
Dryers Logo
169 people viewed this question
Top Dryers Experts
