Question about Troy Bilt 5.5hp Self Propelled Mower
Riding mower rear bagger clogs at bottom were meets deck
It seems like the way the tubing closes down is too qiuck is this a common problem
    Problem Solver:
  • 13 Answers
Yes it is. To go around this, dont mow tall or wet grass.
Posted on Jul 20, 2009
Mower belt will not engage ?
First is to check the belt diagram and make sure your belt is on the correct side of the engagement pulley. This would be the one on the left side of deck with a spring attached.
Oct 06, 2016 | Mtd Arnold Corp RearMounted Bagger for MTD...
How to install a Husqvarna leaf bagger
The bagger installs by using the supplied bracket on the rear of the tractor. Mount the frame of the bagger onto the bracket. then connect the discharge tubes using the spring connecters. Flip open the lid and slide the bags into the frame.
Sep 04, 2014 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Idle rolling
are you talkin aboutit surgin up and downat high idel thats normal when you engage the blades it levels out under load
Oct 26, 2012 | Craftsman Garden
Have a Craftsman LT1000 and the discharge pipe on the grass collection tube continually gets clogged. The grass is not wet or overly thick and the blades are sharp. Engine RPS's good and i always cut...
Inspect the inside surface of the discharge tube. If you do not find any hangups, then I would wonder how fast you are mowing. If you are going full speed, I would recommend that you slow just a little. I was just thinking, have you been doing the same thing for a long time and recently have this problem develop. So, give good inspection. I do not know what type of bagger you have, but is the air able to escape the bagger, if it is not then it sets you up for a clog. If you can not find anything on detailed inspection of bagger system, there are sprays for under the deck of lawnmowers to minimize the chance of grass clinging to the underside of decks, you could try applying that to the ducting of your bagger. I hope this is helpful.
Aug 22, 2011 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Cut grass clippings does not get picked up by riding lawnmower
When using a bagger, you need correct blades on mower or Worn blades will cause the deck not to get the vacuum needed for the bagger to pickup.
Aug 22, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Bagger problems
I would say is to run the mower at high rpm's and slow the tractor speed down and not take full cuts.
Aug 11, 2009 | Garden
How do I install the grass collector
Assuming that you have the correct grass catcher..... Install the discharge deflector at the deck discharge. This is the smaller piece that bends 90 degrees. It will slide into clips on the deck when you have the deck's plastic deflector raised up. Next, install the bagging assembly. It's pretty straightforward. Lastly, install the plastic chute (tube). Push it in the grass catcher (bagger) opening, and then pivot it over the deflector and down onto it to seat it. Connect the straps.
Best regards, --W/D--
Aug 10, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Chute for bagger keeps getting clogged
John Deere LA 125. Chute keeps clogging up with grass.
Apr 22, 2009 | Garden
Troy Bilt 5.5hp Self Propelled Mower Logo
223 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Mike Squire
Tim Whalen
Are you a Troy Garden Expert? Answer questions, earn points and help others
