Question about iLO IWT3206 TV
My tv is one band only uhf i want to make two band in cluded vhf
WD40FW2610 shows please run channel auto scan then i do thes it gots up to 69 and quits
What about your Westinghouse 40" LED TV? What was the year of manufacture? Did they offer more that 69 cable channels on that model in that year? Not on UHF/VHF bands!
UHF/VHF: AIR (2-69); CABLE (1-135) • Composite/C-Video Input: NTSC
Apr 24, 2017 | Televison & Video
Okay, here I am again, wanting to know how to add cable channels to my Hitachi C21 F800S TV. It currently only shows one channel, BET. Please help! Thanks!
1 Press menu button to enter the menu screens for the following optional adjustable settings.choose
2-tune
3-AUTO SEARCH (Activate to auto search & preset receivable broadcast stations)
-if it don't work change this
4Press menu button to enter the menu screens for the following optional adjustable settings.choose
5-tune
6-BAND (change the band system for tuning (i.e. VHF-L,VHF-H or UHF).
if VHF-L don't work try VHF-H or UHF and restart all over
good luck
Oct 05, 2014 | Televison & Video
VHF/UHF RF Power falls to Zero when the Auto ATU tunr logo is on the display. When the tunr logo is off the VHF/UHF RF power is only 10 watts on 2M and 3 watts on 70cms. The Yaesu FT 857 D should have no...
Check for open or shorted Veractor diodes and steering diodes there may be no direct interaction as you say but if a diode is open or shorted the RF circuits might still be selected for the higher bands and the lower output power on your vhf/uhf is an indication of this.
If you do not have a service manual you can get one hear, you will likely kneed one
http://www.tradebit.com/filedetail.php/127575994-vertex-yaesu-ft-857-ft-857d-2005-service-repair
Good Luck Best regarsds Falco
Nov 04, 2013 | Yaesu FT-857D transceiver
Just bought bearcat and trying to find out the scanning codes for cape breton emergency and police
It's not just a certain code it depends on if there using high band vhf or lo band vhf or even uhf mine out here is high band vhf 155.6500 thats our main channel i know because im a licensed emt ...
Jun 16, 2009 | Symbol LS 4071 Handheld
Local ABC and PBS stations do not come in. All others local stat
Check to make sure your DTV antenna is an "all band" antenna with reception in both the UHF and VHF bands. It sounds like you may be in Philadelphia area. In Philadelphia, all the DTV stations are in the UHF band except Ch 6 and Ch12, which are in the VHF band. Some of the DTV antennas are UHF only. You can tell if yours can receive VHF if it has the "rabbit ears" long wip antennas. If so make sure the whips are extended fully and turn the antenna to try to get a good signal.
Visit the 6ABC and WHYY websites for up to the minute information about the issues with reception issues.
Jun 16, 2009 | Insignia Digital-to-Analog Converter for...
I have a 13 inch TV with a small table top antenna with rabbit ears on it and a dial. I plugged the antenna cable into the converter for antenna in. I plugged a cable from converter box to my TV. I was...
You may need an antenna that gets VHF and UHF bands. The "rabbit ear" antenna is designed for VHF band. Many of the DTV channels are located in the UHF band. You may want to call the FCC's DTV hotline for help. They will know the TV stations in your area and can tell you if you need a different antenna. The can also arrange for someone to come help set up your DTV converter at no charge to you. 1-888-CALL-FCC is the number.
Jun 15, 2009 | Insignia Digital-to-Analog Converter for...
Making the TV VHF plus UHF cable ready
If your tv tuner on vhf only goes to channel 13 you will not recieve uhf channels if you are hooked to cable tv. You can do a search for mid band to uhf converters (converts uhf to vhf).We used to use them in the early 80's. Even if you can find one it will only go to channel 22.
Jan 27, 2009 | Curtis RT700 7 in. Portable Television
RCA VCR VMT 385A support needed
c is cable
h is hi vhf (7-12)
l is lo vhf (2-6)
u is uhf (13 and up)
Dec 31, 2007 | Televison & Video
What's the channel frequencies for a common 22 channel motorola 2 way vhf radio?
Not sure what you want.....VHF band ius approximatly 130mhz to 175 mhz..... in that VHF band there is a commercial VHF band aprox. 155 mhz to 175...... the amateur radio vhf band is aprox. 135 to 150mhz.
With amateur radio, any freq in that range can be used...... with commercial radio the FCC cangive a company any freq. in that range also.
If you are looking for FRS/GMRS frequencies they are UHF freqs not VHF.
So I'm not sure exactly what you want......sounds like you might want to program in FRS freqs into an Icom amateur radio. If thats  the case you will need an Icom that will do UHF freqs.
Oct 12, 2007 | Unwired UFR650 (14 Channels) 2-Way Radio
VHF stations WILL NOT display. UHF stations WILL display. Have tried both the remote and the controls on the TV. What is the solution?
a no ufh channels would be a setting in the menu, but when your vhf channels go, the problem is typically the tuner itself, or the band switching ic. could be either. you will need a schematic to know what voltage is supposed to be on the pins.
Jan 24, 2007 | Zenith B25A10Z 25" TV
iLO IWT3206 TV Logo
65 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
