Question about Maytag LSE7806A Top Load Stacked Washer/Dryer
Kicking out water during wash cycle - spin instead of agitation
Most recent problem: After the top load washer fills up with water when it is first started, the motor starts to spin instead of agitating, throwing water out of the top (through the gap between the drum and the metal housing) of the washing machine. I have been watching this for sometime now and it is independent of the various washing cycles (regular, knits, perm press).It's okay to spin as long as the water is draining like in the rinse/spin cycle at the end of the wash because the water is draining. And there is a little period of agitation during the rinse cycle.
Also, how much of a turn should the agitator turn?
    Sergeant:
  • 187 Answers
Try these
  1. Check the drain hose, it should be at least as high as the top of the wash tub, about 38 inches.
  2. The drain hose must sit loosely in the house drain. Do not seal the air gap around the drain hose or a siphon will occur.
  3. Check the drain control lever
  4. Test the drain control coils
  5. Check the cam bar
pls rate my suggestion..
Posted on Jul 20, 2009
Whirlpool type 111-05 Top Loading
The electronic timer is worn and requires replacement, this would be a bulky metallic box located just behind the large setting knob.
Dec 22, 2013 | Washing Machines
Please describe a typical washing cycle to me on the RTW4440XQ Roper 3.1 Cu. Ft. Top-Load Washer, please.
The typical cycle is;
fills to selected water level
agitates wash cycle
drains wash water
spins wash cycle
fills to selected water level on rinse cycle
agitates on rinse cycle
drains rinse water
spins final time
end of cycle
Aug 08, 2011 | Roper Washing Machines
Whirlpool top load washer no low-speed agitation. The unit fills, starts the wash cycle with normal agitation, but after a few minutes it just sits there soaking until the it's time to drain/spin. Drains...
Either the wire going to motor for non working speed is loose or damaged, or motor is bad. It could also possibly be timer not sending power to motor for that speed.
Sep 27, 2017 | Whirlpool Ultimate Care II LSQ9549L Top...
Wont fill or spin runs dry
Check the water pressure switch for proper operation
Oct 19, 2009 | GE WBSE3120B Top Load Washer
Water fills to proper level but agitator doesn't come on instead there is a grinding noise, when I move control to just prior to rinse cycle water drains properly, but still just grinding or buzzing n
Hi, Do you know if the washer spins at all?
It sounds like the coupler has gone bad.
Please let me know if it spins at all.
I can send yyou instructions on changing the coupler.
Vic
May 28, 2009 | Whirlpool LTE6234D Top Load Stacked...
Washer will not agitiate or spin
Motor coupler between motor and gearcase.
Mar 30, 2009 | Kenmore 24032\24036 Top Load Washer
Basin will not fill with water during rinse cycle but will agitate and spin.
most new washers have cold water only rinse and spray rinse ck cold water coming into machine during wash if no cold comes in suspect cold side of fill vale not opening ..could be wiring issue or a bad valve
Oct 24, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
My Whirlpool washer won't agitate or spin . But it does drain the water.
i also had the same problem, and it ended up being the coupler. It was not hard to replace, it cost me about 19.00. I didn't follow full recomende instructions. I tipped the washer backwards. Removed the drain pump and the motor itself. Then I removed the old coupling and placed the new one. The washer is working like new...
Oct 18, 2008 | Whirlpool LSR5132PQ Top Load Washer
Washer fills, drains instead of agitating, fills, etc
ON THIS MACHINE WHEN IT AGGITATES MOTOR ROTATES ONE DIRECTION, WHEN IT PUMPS OUT AND SPINS IT ROTATES THE OPPOSITE DIRECTION. YOUR MACHINE IS ROTATING THE WRONG DIRECTION WHEN IT FILLS., INDICATING THAT THE TIMER IS SENDING VOLTAGE TO WRONG WIRES. SOLUTION , REPLACE TIMER.
PS: MAKE SURE ALL WIRES ARE PLUGGED IN TO MOTOR. WHILE THIS IS UNLIKELY , I HAVE SEEN THIS BE THE PROBLEM.
FXIT
FXIT
FXIT
Nov 24, 2007 | Admiral AW22 Top Load Washer
Agitator Not Working
check your motor coupler, lid switch
Nov 08, 2006 | Hotpoint VBXR1090D Top Load Washer
Maytag LSE7806A Top Load Stacked Washer/Dryer Logo
249 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
