Question about Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
Chain wont turn when running
I have a poulan chainsaw wnet to put on new chain and now the chain doesnt spin when you start it and pull the trigger and no the chain brake is not locked
    Problem Solver:
  • 13 Answers
Check the tensioner screw, it could be too tight. Loosen the slack and the chain should move. And of course do this while its off.
Posted on Jul 19, 2009
Chainsaw want idle why?
Try adjusting the idle 5crew on the carb. Its usually marked with an [ I ]
To get it just right, make sure your chain brake is off, screw in the idle 5crew, the saw will rev and the chain will start to turn. Now back the idle off until the chain stops moving and the engine is ticking over nicely.
May 04, 2016 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Chain wont move
Dont mean to be rude, but are you sure the brake is off? make sure you can pull the hand guard fully back to the top handle of the saw, this will ensure the brake is off, if still no better there is either a problem with the clutch or sprocket, remove the side cover and inspect these components.
May 28, 2012 | Poulan 14" Chainsaw
Poulan chain saw how to get old chain drive sprocket off.
You'll have to stop the crankshaft from moving. The easiest way to do this is to take the spark plug out, pull the starter rope out a little ways, and stuff some of it into the spark plug hole. Spin the sprocket until it stops turning, that will put the piston at the top where it can't pass TDC and stops the crank. Turn the sprocket until it comes off then put your new one on.
Aug 09, 2011 | Poulan 14" Chainsaw
Chain will not stop spinning on the Poulan Pro 42 cc 18 inch chainsaw, will cut wood with out pulling trigger. Runs is very vast, dies when pull trigger.
I would say it has an air leak, through a gasket or crank seal, make sure the carb is tight and sealing properly.
Jun 15, 2011 | Poulan Garden
I have a poulan pro 4018. THe chain saw will start, but it appears that the choke is on full blast. As soon as it starts, the chain is moving - unsafe at the moment - I can use it as long as I don't...
Check the fuel filter, air filter, and muffler for plugging. Check the fuel lines for decay or other damage. Turn the idle speed screw (T) CCW somewhat to prevent the chain from turning at idle. If the above doesn't allow the engine to run without the choke on, then remove the carburetor, clean the interior with spray carburetor cleaner and check the diaphragm in the lower chamber for flexibility with no holes or cracks. Hope this helps!
Jan 29, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Wont stay running. it idles kinda high. stays running with the choke on. pull the trigger 2 giv it gas it dies.
Check the fuel filter, air cleaner, and muffler for plugging. Check the fuel lines for decay or other problems. The idle speed screw (turned CCW) will slow the engine down. Hope this helps!
Nov 08, 2010 | Poulan Pro Chain Saw 46cc 20"
Chain doesn't move / clutch
Starts then.... you hit the trigger... ba ba ba .... dies ?
Check fuel filter in tank, make sure air cleaner is clean.
Make sur your mix is correct.
Feb 04, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
You click the trigger the saw starts only for a couple of seconds then runs out of juice.Local chainsaw out fit wont look at it .is worth repairing
the armature is heating up also the bearings could be bad.. on speculation actually you need a new electric chain saw. it will cost more to have that 1 fixed than what you paid for it...
Nov 13, 2009 | Poulan 14 in. 2.0 Peak Horsepower Electric...
18"poulan chain saw wont rev up
carbs dirty need cleaning. try adding some stabil you can buy at auto zone with fresh fuel it may clean itself out w/o having to remove the carb.
Sep 14, 2009 | Poulan PP4218AV 18" Chain Saw
I can start up the chainsaw, but chain doesn't spin
Is the chain brake on? Pull the lever your knuckles are against toward you to unlock the anti-kickback brake.
Jun 13, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin Logo
263 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
