Toshiba satellite pro L20 overheating after a short time of use vent & base become v hot,fan on almost continuously & everything slows down/not responding /freezes
    Sergeant:
    Champion:
  • 249 Answers
Problem with the processor.get it checked.
Posted on Jul 19, 2009
Tip
Toshiba Bios Password Deletion Satellite P100 & Satellite Pro P100 With...
With notebook turned off;
  • Open Wi-Fi Cover
  • Remove Mini Card Wi-Fi card
  • Locate & Short Out JP8 for 5 Seconds
  • Remove short and turn on
  • NO BOOT
  • Press & Hold Power button to turn off
  • Turn on again & password is cleared
Satellite L10, L20, L30 & Satellite Pro L20
  • Open Wi-Fi Cover
  • Locate & Short Out JP1 for 15 Seconds
  • (Satellite L10)
  • Satellite L20/Pro L20 short out G1
Satellite M100 & Tecra A6
  • Open Memory Cover
  • Remove Memory
  • Remove Black plastic insulation
  • Locate & Short CMOS CLR1 for 15 Seconds
NOTE:
All the following models use the same password removal process.
Satellite: 17xx Series, 1000, 1110,1130, 1200, 1900, 2430, 3000 P20,P30, P33, A30, A70, A80, M40X, M50,M60, M70, M100
Tecra A3/S2, A5, A6
  • The jumper is always located under or near the memory modules
  • Depending on the model the jumper could be labelled J1, J2, J5, J7, J9 or CMOS CLR1 (M100 & A6)
Satellite A100 & Tecra A7
  1. Remove Strip cover
  2. Remove 2 x K/B screws
  3. Move K/B Unit up but don’t disconnect
  4. Release & Remove Mini Card Wi-Fi Card
  5. Locate & short C88 Pin 1 & 2 together
  6. Power on Machine while still shorting Pin 1 & 2
  7. As soon as the TOSHIBA logo appears, remove short
  8. If machine boots, Password has been removed
  9. Satellite A100 (PSAA2A-02C01N)
    1. Remove Memory Cover from base of machine
    2. Release & remove right side Memory Module
    3. Lift black plastic insulation
    4. Locate & short PAD500 Pin 1 & 2 together
    5. Power on machine while still shorting Pin 1 & 2
    6. As soon as the TOSHIBA logo appears, remove short
    7. If machine boots, password has been removed
    TECRA A4 & Satellite M40
    1. Open modem & Wi-Fi card cover
    2. Remove mini PCI Wi-Fi card
    3. Lift up black plastic
    4. Locate & short C738 Pin 1 & 2 together
    TECRA S1
    1. Open palm rest cover
    4. Locate & short C5071 Pin 1 & 2 together
    TE 2300
    1. Remove 2 x B12 screws from bottom of system
    2. Remove strip cover
    3. Remove keyboard screws 1 x B2.5 & 1 x SF4
    4. Remove 1 x 4mm screw & Wi-Fi cover
    5. Remove mini PCI Wi-Fi card if fitted
    6. Locate & short points as shown in picture below
    7. Power on machine while still shorting points
    8. Short for 5 seconds
    9. Nothing will appear on the screen
    10. Turn system off holding down power button
    11. Password is now removed
    Satellite A60
    1. Open Wi-Fi slot cover
    2. Lift up black plastic
    3. Locate & short C561 Pin 1 & 2 together
    4. Power on machine while still shorting Pin 1 & 2
    5. As soon as the TOSHIBA logo appears, remove short
    6. If machine boots, password has been removed
    If you need your Toshiba bios password removed and your model is not listed above then chances are it's a procedure that can only be done at an authorised repair centre.
on Jun 08, 2010 | Computers & Internet
I CANT CONECT TO WIRELESS USEING MY TALK TALK ROUTER...IM NOT EVEN SURE IF MY LAPTOP IS WIRELESS ENABLED ITS A TOSHIBA SATELITE PRO..L20
Hi tracie23368... There's a wireless toggle on the front to control to rurn on the onboard Atheros 802.11b/g WLAN module. All you should have to do is push that toggle in the front of your machine to the right or to the left and hold for a few seconds which will turn on the Atheros wireless card in your laptop. Then it should hook to your wireless router. Note...If you have the security set on the wireless, it will have to be also set in the laptop to be able to hook to your router Please take time to rate me thumbs up
Read more: Toshiba Satellite Pro L20 ' Laptops ' Reviews ' PC Pro http://www.pcpro.co.uk/reviews/laptops/81410/toshiba-satellite-pro-l20#ixzz1XxqUaS8K
Sep 14, 2011 | Computers & Internet
My toshiba satellite A200 2BO keeps switching itself off?whats the reason?
This could be a sign that your laptop is overheating. If you touch the laptop while it is running & you find it too hot, make sure that the fan is running properly & that the air ways are not blocked.
You can blow compressed air into the cooling vents of the fan. If you notice clouds of dust coming out, then it might be a good idea to disassemble the laptop, clean the fan & air ways, & reassemble it back. If the fan has failed & is no longer running, it might need to be replaced.
If none of this solves the problem, or is not the case, then you might have a bad motherboard.
Sep 21, 2010 | Toshiba Satellite 1805-S274 Notebook
SLOW TOSHIBA Laptop
hai
In ur laptop right click the C: and click properties ,then select disk cleanup follow the instruction and delete the unwanted files like temp files, cookies ,etc and ur system will increase its speed
Mar 03, 2009 | Toshiba Satellite L20-S310TD Notebook
Toshiba Laptop overheating
Your Problem is of overheating the unit.
Pls check the Air exhaust of the Laptop. The fan may be blocking air and may be causing the processor hot. It's better to
service the Laptop if problem still persists.
Viren
Jul 17, 2008 | Toshiba Computers & Internet
Toshiba satellite pro l20 sound
my l20 cant play any sound can i download sound through this site
Dec 02, 2007 | Toshiba Satellite R10-S802TD Tablet PC
Computers & Internet Logo
339 people viewed this question
David Payne
David Payne
