SOURCE: complicated GE clock radio/CD player
To set the time:
Hit the SET Wake/Time Button closest to the CD player until the clock face appears in the bottom left hand of the display.
Use the TRACK Rev Search Fwd Arrows to adjust the time.
Rev will decrease by minutes and Fwd will increase by minutes.
Hope this helps.
SOURCE: RCA RP5420 clock radio
Bob, My auto-set worked fine. I'd suggest setting the time manually (by sliding the top-rear slider all the way to the right and using the '<<rev' and 'fwd>>' buttons) if you are still having problems.
SOURCE: Changing time on RCA CD clock radio
UNPLUG!!! Wait 15 seconds. Plug in again, CLOCK will flash 12am.
Press "set" button ONCE.
Press Double Back Arrows |<< to go backward from Midnight
or
Press Double Forward Arrows |>> to go forward from Midnight
(Either press-hold the Double Arrows for quick minute-scroll or repeat-press Double Arrow for a slower minute-by-minute change.)
SOURCE: How to change the time on clock radio
I'm not 100% sure if this is right or not, but i used to have one similar and the way to reset it was:
Give this a try and hopefully it works, good luck
SOURCE: do not know how to turn off alarm setting for clock radio
Instructions are here: the closest available RCA CD-CLOCK RADIO USER MANUAL online is for Model #RP5610 at this location: http://www.voxxsupport.com/images/manuals/RP5610/media/RP5610_DOC_OM.PDF
If unable to link to that webpage, go to RCA Tech Support page at: http://support.rcaaudiovideo.com/manual.aspx?product=143 and click on download manual.
