Question about Samsung DLP HL-P5663W 56" TV
Many horz line on screen. model hl-r5667w - Samsung DLP HL-P5663W 56" TV
  • taeikchung41 Jul 19, 2009
    I going to order new digital board.
  • 6,784 Answers
HI, This unit is experiencing a major issue that concerns the Digital PC board in this case. There are major solder point breaks that are causing many connectivity issue throughout the board layout, in return, causing this distorted view you are witnessing. the Horizontal lines are a direct indicator of issues that concern the Digital Boards integrity. this board will need to be replaced asap, if possible.
Samsung Part Number: BP94-01858A
Posted on Jul 19, 2009
Samsung hl-r5667w DLP no picture,
Hello, are there any sounds coming from your television? If something happened to the colorwheel I dont think the TV would come on at all, I would by instinct take a look at replacing the DMD chip.
Jan 01, 2014 | Samsung HLR5667W 56" Rear Projection HDTV
I've received a replacement pcb digital board and installed it what else do i need to do prior to using the TV . model #HL-R5667W
If that is all that was wrong with it, that should be it.
I expect it may require retuning if the mmory is on that panel.
Jan 07, 2011 | Televison & Video
Screen on my HL-R5667W DLP is fading from the left
Ur tv have a convergence problems.The 2 STK convergence ICS are defective and dying.The shop will fix this for u about $300-350 for parts and labors.
May 08, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
My tv has white lines that run up and down across whole screen. it has like 4 lines then a inch space then 4 lines and a 3 inch space My tv is a SAMSUNG HL R5667W
Power supply board, Look for bad capacitors they will be vented or puffed up on Top.
Encompass parts has whatever you need for this model
1-800-638-3328
Mar 02, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
Samsung DLP HL-R5667W not turning on. Showed
Purple spots means Bad Light Engine Part number is BP96-00822J Encompass Parts Has them for
$950.00 - $350.00 core price Part $600.00
1-800-638-3328 Lamp# BP96-01073A
Ballast Board# BP47-00027A
Jan 08, 2010 | Samsung HL-R5667W 56" HDTV
I have a Samsung HL-R5667W that is about 3 1/2 years old. The screen is dark except for occasional flickers of light. The lamp appears to be giving off light when I look in the back. I replaced the bulb...
Hi my name is Eric,
I hope I can help you with your issue ,
Most likely your colorwheel is bad,
second possibility is the digital board.
Both are for a technician to install, you could do more damage poking around inside the TV.
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Eric
Sep 26, 2009 | Samsung HL-R5667W 56" HDTV
I try to vibration pcb but samething problem on many horz line on picture.
Please intimate exact model and brand of your TV that you are looking for info.
Thanks.
Jul 19, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung HL-r5667w TV shuts down on its own.
You may have a colorwheel going bad. The bearings start going out and this is an indication of the failure. The colorwheel is located in the light engin e therefore you may want to get a qualified tech to look at it
Dec 16, 2008 | Samsung HL-R5667W 56" HDTV
Colored lines and rectangles
Sounds like a problem on the digital board. try hard booting (unplug for 2 minutes) to reboot the microprocessor. if no resolution, look for a new board part # bp94-01859f if your model # ends in WX
Nov 30, 2008 | Samsung HLR5667W 56" Rear Projection HDTV
Hl-r5667w
I just responded to your other post check the connection between the lamp and ballast at both ends. Also did you get the same exact lamp as your old lamp, as Samsung has two different arc gaps and they wont work if you get the other type even though they look the same physically.
Jun 21, 2008 | Samsung HL-R5677W 56" HDTV
Samsung DLP HL-P5663W 56" TV Logo
29 people viewed this question
Jerry Greenberg
Jerry Greenberg
