Question about Epson CX8400 All-In-One InkJet Printer
How to use scanner in Epson cx8400
Thanks to solution 6, it is printing. But how can I make the scanner work? After I added the printer in system preference, I didn't find the program in applications. Where can I find it?
  • 3 Answers
4 steps I use on mine: Start menu, all programs, epson scan, epson scan
Posted on Oct 21, 2009
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 81 Answers
There is a program that comes with windows called scanner and camera wizard it can be accessed from the start menu.
Posted on Jul 19, 2009
I have an epson cx8400 and i replaced the black ink cartridge but theres an error message saying that i need to replace other ink coartridges. I just want to print in black, how do i bypass the error...
hello
i have this link below that gives you allinformation about your Epson printer. specifically the manual , required for review to address the issue with the ink cartridge error.
Run a Printer Check A printer check will help you determine if the Epson Stylus CX8400 Series is operating properly. 1. Turn off the Epson Stylus CX8400 Series and your computer, if connected. 2. Disconnect any connected USB cables. 3. Load plain paper in the sheet feeder. 4. Press Setup. 5. Select Maintenance and press OK. 6. Select Nozzle Check and press OK. 7. Press cx7400_cx8400_ug.1.109.1.jpg Start. 8. The Epson Stylus CX8400 Series begins printing the nozzle check pattern. • If the page prints, your Epson Stylus CX8400 Series is operating. Your problem may be caused by your computer, cable, software, or setting selections. Check for additional solutions or re-install your software. If the pattern on the page has gaps, clean or align the print head. • If the page does not print, the Epson Stylus CX8400 Series may have a problem. Check for additional solutions. If they don't work, contact Epson.
general= http://www.epson.ca/cgi-bin/ceStore/support/supDetail.jsp?BV_UseBVCookie=yes&oid=90342
manual = http://files.support.epson.com/htmldocs/cx84__/cx84__ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Nov 13, 2010 | Epson CX8400 All-In-One InkJet Printer
I have a supermarket till receipt stuck in the works of my epson dx 8400 how can I get it out
***hi there,il be willing to help you on that. ****
If paper is stuck inside, turn off the Epson Stylus CX8400 Series.
Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX8400 Series back on.
***if my troubleshooting steps are helpful, pls vote for me, i will appreciate it, so that I can be a part of fixya, thanks, Godbless****
Feb 17, 2010 | Epson CX8400 All-In-One InkJet Printer
My Epson CX8400 will not print black text?
1. Press Setup
2. Select Maintenance and press OK
3. Select Nozzle Check and press OK
4. Press Start
5. Check the nozzle check pattern that prints to see if there are gaps in the lines
6. If there are no gaps, the print head is clean and you can continue printing If there are gaps or the pattern is faint, clean the print head
Oct 20, 2009 | Epson CX8400 All-In-One InkJet Printer
I have been trying to scan with my epson cx8400 went to self help but cannot seem to get the scanner/printer to work
To scan: Insert doc. onto the scanner then go to Start menu, all programs, epson scan, epson scan
Oct 15, 2009 | Epson CX8400 All-In-One InkJet Printer
Epson stylus cx8400 won't print web pages
There are 6 downloads for your printer, 5 are software and one is the driver.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=90342&prodoid=63069506&BV_UseBVCookie=yes&infoType=Downloads&platform=Windows&x=20&y=9
The help is free because we are all users like you who hare or knowledge sometimes learned the hard way.
Now disconnect the printer and go to printers and faxes and uninstall/delete it.
Go to add/remove programs and uninstall all epson programs.
Install the driver and connect the printer when told to by install prog.
Install other epson software.
Sep 18, 2009 | Epson CX8400 All-In-One InkJet Printer
Cannot Print from on Epson CX8400 from Mac OS X Leopard
I could only get my CX8400 to work with Leopard once I manually selected the driver located at /Library/Printers/PPDs/Contents/Resources/EPSON Stylus CX8400.gz
I think that may have appeared after installing a driver downloaded off the web, but I didn't track my steps carefully enough to be certain. I used http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=90342&prodoid=63069506&infoType=Downloads&platform=Macintosh
I know this is a bit jumbled, but hopefully it helps.
Jul 08, 2009 | Epson CX8400 All-In-One InkJet Printer
Can't print with epson cx8400 after upgrading mac to 10.5.6
Just roll back the driver. this option can be found in the hardware manager, under the hardware tab on system.
Click start, control panel, system, hardware manager.
May 07, 2009 | Epson CX8400 All-In-One InkJet Printer
Epson CX8400
Your next step is dependent on exactly how the nozzle check prints.
Let me know
Aug 21, 2008 | Epson CX8400 All-In-One InkJet Printer
Can't print to Epson CX8400
I had the exact same problem with the endless blank pages "printing" out.  I have a MacBook Air with OSX 10.5.6.
Before I got a chance to try and delete and reinstall all the drivers all over again, my phone call was answered by a very helpful lady from Epson's support line US: 562-276-4382.
Here's how easy it was to fix: Go into Apple System Preferences, click Printer & Fax. HOLD CONTROL while clicking on the printer on the left side of the screen.  When you HOLD CONTROL, it allows you to choose the option to "Reset Printers".
Click "Reset Printers", and you will see them all disappear.  Simply plug in your CX8400 and click the plus button to add new printer.  It will search for the driver for you if you have an internet connection.  It worked for me on the first try and took only about 2 minutes total!!!!
I'd wasted so much time installing drivers and screwing with the printer before this.  Save your time for things that make you happy!  Share help when you can!
Dec 03, 2007 | Epson CX8400 All-In-One InkJet Printer
Epson CX8400 All-In-One InkJet Printer Logo
1,347 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
