Mitsu ws-65315 I turn it on and it turns back off. I replaced the 4 1000 uf caps and it still does it. whats next
  • 3,741 Answers
The component on the board is getting over heated.also check out the 1000 uf capacitors which you replaced.are they getting heated after you turn the tv on.for that you will have to keep the unit open and then on the tv.its bit risky but this is the only way to check out.if not familiar get it done by a technician.also if the componets are getting overheated but if the component looks proper.then its a power supply board proble,as this board actually sends power to whole unit.but if the power s over the circuit gets overheated and the components gets over heated so to save the further damage the tv shuts off.so also check out power supply.
you can get new board parts at
www.partstore.com
or at
www.shopjimmy.com
thanks.
Please do rate the solution. Thank you for using fixya.keep updated. thanks
Posted on Jul 19, 2009
What could be wrong ? when i turn my tv on quickly off.
replace bulb and clean dust out of all cooling fans, may require you take back off set and remove and disassemble projector inside.
May 04, 2010 | Mitsubishi WS-65315 65" Rear Projection...
We have the Mitsu WS-65315 and have the same situation of turning the power on and it turning right back off again, after pressing the menu and input button as suggested, it is 2 blinks, a pause, and then...
THE WS-65315 with the 2-2 error code means one or both of the soldered in pico fuses that protect the convergence circuit for this set are blown.
This model uses two of the STK-394-250 CHIPS. Both chips will have to be located along with the fuses--most of these sets also have several resistors around the chips--any bad ones will either test OPEN and or will be discolored or white in the middle.
Total parts cost on Ebay for most of the things you will need is under 40 dollars. The repair involves getting at the chips and other parts and being able to unsolder/replace and solder the new parts in.
If you can do it you can save a lot of money as most shops are going to get at least 300 for this repair.
Let me know if you locate the chips etc inside the set-UNPLUG THE SET FIRST. I can tell you what things you will need and where to get them. I have seen several places on the internet that also provide written or video instructions for this repair.
If this helped you rate this solution as I do this here for free.
SD TECH
Dec 09, 2009 | Mitsubishi WS-55511 55" Rear Projection...
MItsubishi HDTV 1080
need to call a servicer, if they found out that if this is a chassis issue, call mitsu
Sep 20, 2009 | Mitsubishi WS-65315 65" Rear Projection...
Green light doesnot turn off on Mitsubish WS-65315
Just go to menu... then ..setup... then... timer ..and turn it off...... the blinking light goes away
Aug 29, 2008 | Mitsubishi WS-65315 65" Rear Projection...
Ws-65315 won't turn on
Need to know more, 1-2 is no error code, you say will not turn on, do it has led light on or do you hear sound in set like high voltage? Any lights blinking? Or just completely dead, like fuse blown?
Mar 24, 2008 | Mitsubishi WS-65315 65" Rear Projection...
Mitsubishi rear projection tv won't turn on
know problem of bad caps.
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
http://hdtvoice.com/voice/showthread.php?t=32186
replace DM
Picture of bad caps
http://www.auctioncreations.com/wd62525a.JPG
The DM board is the one with the digital connectors on the back panel. If you already have it appart, you may as well check the caps on all of the boards. The caps that go bad are typically Jamicon brand caps in 1000 uF and 330 uF values. There are also a couple of 3300 uF caps in the PS that cause problems.
Jan 08, 2008 | Mitsubishi WS-55511 55" Rear Projection...
TV wont turn on
replace DM
Picture of bad caps
Oct 22, 2007 | Mitsubishi WS-55511 55" Rear Projection...
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
Electro Med Services...
