When I get in the car (doors closed) I put the key in and start the car: a alarm goes off. It is a different sound alarm than the door being open. When I turn off the car the alarm sounds again?
To arm content theft alarm. 1. Open the door. 2. Lock the door with the power door lock switch or the remote keyless entry transmitter. The SECURITY light should flash. 3. Close all doors. The SECURITY light should go off after approximately 30 seconds. The alarm is not armed until the SECURITY light goes off.
If a locked door is opened without the key or the remote keyless entry transmitter, the alarm will go off. The headlamps and parking lamps will flash for two minutes, and the horn will sound for 30 seconds, then will turn off to save the battery power.
Try pressing the lock and unlock buttons on the remote, holding for a few seconds, then trying the unlock and lock buttons to see if the alarm disarms...your description indicates the car alarm is still armed!
With the drivers window down, and the doors closed. and locked connect the battery and lock and unlock the tailgate with the key, you need to unlock it twice to unlock the doors and turn off the alarm. If the locks are working like thier supposed to the drivers door will be unlocked and opening it won't set off the alarm. the truck should be back to normal. If not disconnect the battery again. Drivers window down. Put the key in the switch and turn the key on to the run position. With all the doors closed connect the battery. connect it good and don't bounce it around. If the battery casbles aren't clean clean them good so it'll connect good. If it still is alarming then the doors switches are likly. Or the door locking motors. You should be able to lock all the doors ( including the hatch) by hand and get the system to reset. Try it all again using a different door to double unlock as a lock switch might be sticking. If the system can't verify that all the doors are closed and locked it won't reset. If you connect the battery wihg the key turned on the system thinks it's already running and appeares to be in the unset mode.
When alarm goes off,put key in ignition and turn,the alarm should go off and alarm should be reset.Or,remove positive battery cable,wait 10 minutes,reconnect,when you open door,alarm will sound,insert key in ignition and turn key and alarm should go off and alarm should be reset.
you can try switching the key to the "on" position then open the hood and disconnect the negative terminal of the battery and reconnect after 2minutes. this will allow the alarm to be '"reset" and will recognize that you have the key for the vehicle.
We have a similar problem - it doesn't go off when we open the door,
but sometimes the alarm light stays on after we open the door and then
when we put the key in the ignition to start the car the alarm goes
off. The only thing we've found to shut the alarm off is to get out of
the car and put the key in the trunk manually and open the trunk. Then
after we've opened and closed the trunk, the alarm disables and then we
can unlock the doors (which I believe is the step where the alarm
disables) and then we can start the car without a problem.
Hi, I have a 1992 Acura Legend. If the alarm goes off when you open the door when the alarm is set you may have to close the door and put the key in the door lock and turn it clockwise to turn the alarm off.
