I turn the set on and it shuts off. I changed the 4 1000uf caps. What's next?
  • mikezellam Jul 19, 2009
    It's not flashing when it goes off but the self diagnostic is flashing the 2-3 code
  • 3,037 Answers
Have you found any other bad caps with their heads swelling? If so replace those. I would also try replacing the entire power supply as that is usually the main issue with this problem. Is the tv light on front blinking at all? If so, could you please count the number of times that it blinks as this indicates an error code. Let me know how this turns out.
Benjamin
Posted on Jul 19, 2009
Computer shuts down on its own
Open Control Panel, Power Options, set to High Performance, open Change Plan settings, open Change Advanced Power settings, set Sleep and Hibernate to Never, adjust advanced settings to your preference. Always shut down your computer when not in use, it will last longer, If you don't have a UPS, will help protect against power surges.
Feb 07, 2013 | HP Pavilion P2-1013W AMD DualCore 1.65G3GB...
Keeps blacking out after start up. if i keep turning it off and then on it eventually stays on, but it will happen again the next time the computer is shut down and restarted.
You havedying power supply, check for bad caps first.
Please my guides and learn about bad caps, etc.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Dec 01, 2010 | Amptron 19 inch G19FP LCD Monitor
At just over 1 year old and out of warranty, my Samsung 52'' LCD will not turn on. You can hear the relay click on/off/on/off, getting slower, until it will turn on after about 8 minutes. The firmware has...
Same problem on my friends Samsung LN52A650A. Never did the firmware update cause that refers to a random shut-off problem. I replaced (2) 1000 10 volt caps next to a heat sink with 1000s rated at 35 volts @105 degrees C. The tops on his were a little swollen and you had to really look close. The caps were 2 0f 4 inline caps. They were the smaller 2. TV works.
Jan 02, 2010 | Samsung LN52A650A LCD TV
Regulator doesn't allow gas to flow to grill . Grill cannot heat hot enough to grill steaks. Gas flows too slowly.
Shut off the gas at the tank and disconnect everything.
Unscrew the plastic cap on the regulator. Inside is a flat screw top that has a single slot or an X-shaped slot. This is the pressure adjustment. It controls the diaphragm that regulates gas flow.
Note where it's set. Use a Sharpie to mark the adjuster on its edge (place a dot there), and make a corresponding mark on the threads next to it.
Next, use a large screwdriver or a coin to spin the adjuster counterclockwise three or four times. Pay attention to the number of turns. Now, screw it back in (clockwise) the exact same number of turns, stopping at the index mark you made.
Next, turn the adjuster two turns clockwise, followed by two turns counterclockwise. The idea is to end up where it was originally set. This action unsticks the regulator's valve seat. Done.
Put the cap back on, hook it all up, open the tank valve, and make fire.
Oongawa!
-Peegoo
Jun 23, 2009 | Thermos Stainless Steel Gas Grill
Powers down
this set is known for the deflection and convergence causing the set to shut down ,watch for clues as where to begin, inspect the neck boards also for arcing as well as the flyback trans former,listen for arcing upon shut down.
Nov 16, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Polaroid FLM-323B Will not turn on
Polaroid FLM-323b No power,No led light, checked the fused and the fuse is good?
Can't find any bad Caps? Well I spent some time, well alot of time trying to figure out what's wrong and finally did.
The problem is a diode on the power board location Z9 Part # ( P6KE350A )On some boards it's the diode and the capacitor right next to it part # ( R 331K 1KV )
If this works Please donate Paypal Is12ok@aol.com anything helps Ive spent well over a weeks time and count less hours trying to figure out what was wrong.I have included some pics to try and help.
Thanks Z28r2fast4uc144496.jpg18b1844.jpg27931f3.jpgdb4f9c3.jpg f53556c.jpg 7eeee7c.jpg
Oct 21, 2007 | Polaroid FLM-323B Television
Only see a slice of picture + bright horizontal band
you could do three of these change flyback change yoke change cap that couple the horizontal transistor.good luck
Apr 27, 2007 | Toshiba 27A33 27" TV
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
