Question about Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1
Looking for a 3amp fuse for a hayward pool heater in the ottawa area ... Where can i get 2 of them
  • 170 Answers
Any automotive or electronics store
Posted on Jan 17, 2010
Canadian tire has them in the automotive area.
Posted on Jul 31, 2009
    President:
  • 1,714 Answers
Do you have 'Radio Shack' there? Go online to any electronic store; Digikey.com or Newark.com or grainger.com
Posted on Jul 19, 2009
I have Hayward H400IDL2 heater I recently had #1 and #2 1.5 amp fuses blow. I replaced them and then the #4 2.5 amp blew so I replaced it. When I press the mode button to spa the heater blower comes
Good Day, missed your post for a few days. #1 & #2 fuses are on the high voltage side. This could mean a problem with incoming voltage or a bad fuse or main circuit board. Call our tech line at 908 355-7996. I have attached a link to the manual. http://www.hayward-pool.com/pdf/manuals/H-seriesLowNOx-H250IDL2-H350IDL2-H400IDL2.pdf
Aug 24, 2014 | Hayward H400idl2 400,000 Btu Low Nox...
I have Hayward H400IDL2 heater 6 years old. I recently had #1 and #2 1.5 amp fuses blow. I replaced them and then the #4 2.5 amp blew so I replaced it. When I press the mode button to spa the heater
Hi, this is John the Hayward tech. If you are now seeing the #4 fuse go that is on the low voltage side. I would guess the main circuit board. I left a manual on your other post.
Aug 24, 2014 | Hayward Pool & Spa
Can I change out a Hayward H400ID with an electric heater for the spa only? If so what electric heater product brand would you recommned. Raypak?
Hayward has manuals for each type heater, gas and electric.
http://www.hayward-pool.com/prd/In-Ground-Pool-Manuals_10201_10551_14502_-1___I.htm
Hayward also has contact page, and can probably recommend correct change-over product.
You want to switch from propane to heat-pump type.
There are likely 3 areas of difference. Read each manual and generally look for 1) unit size and capability to match spa 2) pipe connections and sizes 3) Electrical requirement
From electrical standpoint, You need GFCI-protected line from circuit breaker box, or GFCI (arc-fault) breaker. This will prevent electrocution risk around spa.
http://waterheatertimer.org/How-to-wire-GFCI.html
Wire sizes are based on volts and watt-rating of heater.
Each electrical device has rating plate showing volts and watts.
3500 watts divided by 240 volts = 14.5 amps so install double-pole 20 amp breaker and use 12 gauge wire.
1500 watts divided by 120 volts = 12.5 amps so install sinle-pole 20 amp breaker and 12 gauge wire.
http://waterheatertimer.org/Color-codewire.html
Oct 28, 2012 | Raypak Spapak Electric Spa Heater -...
H2520 fuse blown
check wiring make sure correct voltage also check to see if you have a shorted wire
Jun 16, 2012 | Hayward H Series Pool & Spa Heater 200k...
Solenoid Valve where the natural gas line connects to the Heater keeps turning on and off at a rapid pace. The valve only stays off about a 1/2 second and may stay on for 10 seconds before it goes...
You can find a Hayward warranty service provider in your area by entering your zip code and selecting "product repair or service" on Hayward's locator page of their website, found here:
http://www.haywardnet.com/locator/
John
Sep 16, 2011 | Hayward 250fdn Low Nox Nat Gas Swimming...
I can't light our pilot light - Hayward H150
I dont thnk you have a pilot light on this model ... I think it is lit by a electronic device that glows.
Remove the front cover and look up into the burner area. Turn the heater on. Can you see a red glow?
Aug 05, 2011 | Hayward H-series Electronic Gas Pool...
I need a seal for my 1.5 horse power SPL pool pump, but I cannot find it. The company I bought my pool pump no longer carries Jacuzzi pumps. Is there somewhere I can get it or another seal I substitute?
Any pool store in your area should have a 201 mechanical seal available. If not, try looking under pump repair for a shop in your area. It is a very common seal and is interchangeable with the Hayward super pump seal so it should not be hard to find.
John
Jun 20, 2011 | Hayward Pool Products HAYWARD 1.5 HP 2...
H400IDL Hayward Pool Heater. Ours is dead. Any suggestions on what we need to do to fix it? FS, BO are our error messages.
BO is bypass operation fault and FS is temp.sensor failure. It is recommended that you contact a pool professional to fix this. If you are in the Phoenix Metro area you can contact me at info@wefixuglypools.com
Dec 28, 2010 | Hayward 250kbtu Ng Pool Heater - Inground
My pilot light is lit but the heater won't turn on.
GET A NEW PRESSURE SWITCH.. CALL AND ASK FOR A PRESSURE SWITCH FOR SAY A HAYWARD POOL HEATER .. LOOKS LIKE THIS ..EBAY Pressure Switch Hayward generic pool heaters also H100
May 20, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1 Logo
102 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
