Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Motor not going on at all anymore
10 year old fridge. yesterday noticed that the motor didn't go on and fridge started to warm. was able to unplug/plug and changed both the freeser and fridge to colder setting. fridge went on then worked fine hit shutoff temp overnight and has not turned back on since. there is power; no noise whatsoever and seems like a thermostat? can i replace just the thermostat? where will i find it in the fridge?
  • steve_j_mill Jul 23, 2009
    thank you aasc. Whirlpool ED25PQXFN02. Bought new in 1999.
    thank you aasc. Wl'pool ED25PQXFN02.
  • Whirlpool Master
  • 1,606 Answers
Need brand and model number .
Posted on Jul 21, 2009
  • Mike Smith
    Mike Smith Jul 23, 2009
    The thermostat pt# is 2198202 and is the refrigerator control in the panel at the top of the refig section . If you tap on the control and the refrig comes on , then this is the problem . Remove the 2 knobs and pry the cover , top first , off , Then remove the 4 , 1/4 screws to remove panel , Remove the side cover and rear damper cover , and you'll see the thermostat tubing kind of coiled around the damper . Installation is reveral . Be sure to disconnect power to refrig first !!
    Sergeant:
  • 183 Answers
Your starting relay may be defective.
It may have a solid state starting relay. Remove the relay and shake it. If it rattles, it is bad. May be able to replace it with a Solid State Relay Part # 32330
Posted on Dec 10, 2010
I have a 10 year old GE Monogram refrig. We noticed a small puddle of oily liquid on floor beneath freezer door. It is accumulating about 1 tsp/day.
certain amount of oil is in the compressor motor casing to stop it burning out
it is under the same pressure as the refrigerant
I would say the oil comes from that casing
you could turn the fridge off at the wall
bring the fridge out to get behind it
and degrease the area to see if the leak is severe
if it is..... needs a fridge technician
not sure
check if cost of replacing the motor compressor unit
on a ten year old ge
might be more that fridge is worth
Nov 10, 2016 | GE Refrigerators
Unit is about 10 years old, bought new from Lowes. When I open the doors the bar or middle frame is warm to hot. Now the freezer and refrigerator is not cold. Ice started to melt down so I removed the ice...
I suspect the warm to hot is from a heater that keeps moisture from from condensing on that bar. you don't notice it when the unit is working properly. Make sure your condenser fan is running and that condenser is clean. You may have a compressor that is failing
Jun 23, 2011 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
3 yr old ge fridge started clicking yesterday and everything got warm i unplugged and motor kicked on. Is this a compressor going bad?
Good day,
It could be, as you said, the compressor going bad or it's possible the start relay clipped to the compressor body is failing.
If it repeats the problem, you could unclip the relay from the compressor and replace it with a new one.
However, since you still have 2 years factory warranty on the compressor I would suggest you call GE or a GE factory authorized service company. If it's the relay, you will be charged for the repair, but by doing that you will maintain the integrity of the compressor warranty, especially if the repair turns out to be short lived and it turns out the compressor needs to be replaced.
Oct 05, 2010 | GE Refrigerators
Our Amanda refrigerator/freezer has been making noises on and off (buzzing) over the past two months, in particular the bottom freezer. Today everything started to melt and the buzzing is frequent every...
It sounds like your evaporator fan motor, they last about 4-5 years. Try to see if the buzzing noise comes from the motor, usually in the freezer compartment behind a vented cover plate
The freezer is usually cooled by the compressor, the fridge is then cooled by an evaporator fan motor ($30). If this fan seizes or slows down then the fridge warms up (it sometimes starts squealing before this happens). It could be that your drain hose is clogged or frozen. Maybe the temperature adjuster go bumped.
If you think it is the evaporator fan motor:
Check to be sure you can get a replacement fan first, they last about 4 - 5 years. Can get from a parts supplier or electric motor company.
UNPLUG fridge. Located usually in top of freezer behind a vented cover plate. Remove cover, remove screws holding fan in, may have to cut wires. Replace with new motor, make sure the fan pushes air into the freezer area and doesn't spin backward drawing air from the freezer area.
Oct 31, 2009 | Amana ABB1927DE Bottom Freezer...
GE - SIDE BY SIDE MODEL TFX25JR - Continous HUM
Probably the condenser fan motor is going out they will often make noise for a long time before anyone notices. Get it looked at soon. overheating the compressor on that old of a fridge could spell trouble.
Sep 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer not freezing and fridge not cooling
Check the back wall of the freezer for ice buildup.
If yes, a defrost parts problem.
Check the freezer fan. Is it running?
If no, replace the freezer fan.
Check the condenser fan at the compressor. Is it running?
If no, is compressor hot?
If compressor is hot replace condenser fan motor.
If compressor is not hot.
Replace the compressor start relay.
Feb 27, 2009 | Kenmore 53502 / 53504 Side by Side...
Amana side-by-side fridge freezer only cold at the bottom
yes the evap fan in the frezer should be running when the compressor is running[it may not for a minute or so as it starts up.Amana's are good for the connectors at the evap fan motor comming apart.the connectors are white and will look like its together but when you pull it will come apart.i would always cut the connector out and use a wire nut so wont happen again.if any other questions please email thru FixYa and i will be glad to help. God bless ,tom
Jan 30, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Fridge freezer upright
Replaced the thermostat
Jun 22, 2008 | Freezers
The refrigerator side is not cooling.
ALMOST DEFINATELY YOU WILL HAVE AN ELECTRONIC CONTROLLED AUGER(MOTOR)CONTROLLING THE AMOUNT OF CHILL ENTERING THE FRIDGE COMPARTMENT. IF YOU SET THE FRIDGE TO MINIMUM AND LISTEN CAREFULLY, THERE SHOULD BE A SOUND INDICATING THE AUGER IS WORKING.( OPENING AND CLOSING THE FLAP). SET TEMP. TO MAX AND LISTEN. IF NOTHING, IT COULS BE A DEFECTIVE MOTOR OR FAULTY THERMISTOR(TEMP. PROBE).
Aug 08, 2007 | Samsung RS2556 Side by Side Refrigerator
Maytag refrigerator Model MZD2766GEW
Check the evaporator fan motor located abocve teh cooling coils in the freezer side.
Jun 05, 2007 | Maytag MZD2766GES Side by Side...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
251 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
