Question about GE Kitchen Ranges
Ge profile jsp40a0w3aa computer screen is all numbers and can not set anything The burners seen to work
5 Suggested Answers
SOURCE: cleaning and care for my GE Profile stovetop
The one thing I don't suggest is using the Ceramabryte product the dealer left with us. It leaves a greasy film. When I get ready to clean my black GE Profile, I pull off the controls to wash separately. Then I lift off the grates, take a single-edge razor blade to scrape anything stuck on (it doesn't scratch), then I use baking soda and scrub and scrub with lots of paper towels. Then I start cleaning off the baking soda with lots and lots more paper towels. There is still a film, but at least it's not greasy. At this point I grab some more dry paper towels, pour on a 3' puddle of rubbing alcohol and wipe it all over the stove top and front. You may have to do this twice. Then, if I don't turn on the hood light's brightest setting, it really doesn't look too bad. I have to do this at least once a week, as I have never had a stove that got so dirty so fast and was such a pain to clean.
FYI, I would never buy another of these stoves. Besides the cleaning issue, there is the fact of having to replace the igniter (glow plug?) twice in the first four years. My old, bottom-of-the line Magic Chef went 25 years with the first replacement not coming until it was about 15 years old. Also, the broiler is unimpressive and steaks, etc., just sort of steam. Can't get a really good crust going. It's a slide-in and the top is very narrow, front to back, because of the slanted control panel on the front, and so you really can't put two large pots or pans on one side. Let's see....oh yes, I ordered the unglazed grates for safety reasons and it came with the procelain glaze. Those were replaced free of charge, though I had to go pick them up. Then the first set of unglazed grates began to rust about six months into use, so had to be replaced (again, no charge at least). Recently I noticed that the inside walls of the oven, where the racks slide, are starting to rust. Finally, the burners are difficult to calibrate, which I really notice when I try to cook rice, which comes out right about 50% of the time.
Now, on top of all this, I have to worry about the glass door exploding?!?! Should I ban my grandchildren from the kitchen? Has anyone from Consumer Reports seen this website?
Posted on Apr 03, 2008
  • 382 Answers
SOURCE: GE Profile Spectra Electric Oven.
call a appliance and parts store give them the tear and model number from stove it is inside the door or on back it5 mkay also be on the top under the fuse panel access door
Posted on Dec 27, 2009
mrfixit3667
  • 262 Answers
SOURCE: ge profile gas range. one burner with no clicking and no ignition
Try one to light one of the other burners that work and watch the electrode on the burner that does not light and see if you have spark when you here the clicking nois. (( most gas cooktop spark ignitor all spark at the same time, even if your only trying to light one burner ))
If you do have spark, Then the Ignitor switch is bad.
If you don't have spark then your spark modual is bad.
Posted on Jan 10, 2010
SOURCE: GE Profile Gas Range, oven doesn't heat up on any
Find the bake ignitor (you may need to remove bottom drawer or oven cavity floor to get to the ignitor). Turn on the bake. If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. Should be 3 - 3.6A. If less than 3A - replace ignitor. If the ignitor does not come on - check the voltage on the ignitor, should be the line voltage 110-120v AC. If there is a line voltage on the ignitor and it's not coming on - replace.
Part numbers, the first one being the direct replacement: WB13T10045, 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
Those ignitors are interchangeable, if you can splice the wires, if not comfortable splicing wires - order the first one in the list above.
Posted on Jul 15, 2010
Ge cooktop radiant
I have never seen any that have fuses for the individual elements . did you spill liquid on the top , like boil something over . that shorst them out and need replaced .
Jun 28, 2016 | GE PROFILE PP912TMWW 30" CERAMIC COOKTOP -...
Hot surface light stays on on GE Profile Cooktop model JP989 and On does not light for left burners. This is only happening on left burners. Left front burner goes to high with any setting on the switch...
You could have a shorted burner, if it is not then you may have gotten a bad part.
always unplug electricity before attempting to repair on any electrical appliance
Aug 17, 2017 | GE 30 in. Profile JP989 Electric Cooktop
Have a four burner gas GE Profile cooktop. How do
The igniter module is working fine. One of the switches (which are on each valve shaft) is stuck or shorted out. Pull a wire off each one at a time to determine which one is bad. Careful! 120 volts to each wire. Also, this can happen after you spill water into the valve area, if that sounds right, let it dry out.
Jan 29, 2010 | GE 30 in. JGP328 Gas Cooktop
Need to replace burner on ge profile jsp47
Hi pauli1598, if you are thinking of doing it yourself, let me suggest a quick look at the following link www.ehow.com/how_2262532_diagnose-repair-electric-burner-problem you'll find a complete procedure there and if you don't have a meter you can always exchange the defective element(burner) with one that is working just make sure it is defective. You can always find replacement electric elements in your local appliance parts srore or sears or if you prefer on line ordering www.repairclinic.com you will need the complete brand name and model number.
Jan 08, 2010 | GE Profile JSP47 Electric Single Oven
My ge profile range top and burner work bu the
try cleaning the ignition wire (spark) it works with ground
Nov 11, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Where do I find the model number of my GE Profile gas range?
on back of appliance near top behind control panel but should be on outside of rear cover
Jul 15, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile stovetop w/4 burners doesnt stay hot enough to cook on anymore
I would check to see if you have 220 Volts to the stove, even if you have only one leg with 110 volts to stove it will let the burners get half hot. with out the model number i don't know about any censers. The flat tops have temp sensors on them. but not that operates for all four. I would check at wall receptacle first for 220 volts first but only if you are qualified to work with electricity REMEMBER it can injure or KILL you.
Feb 05, 2018 | Kitchen Ranges
Can't make my oven work after a power loss - GE Profile Advantium
check voltage to oven. if thats ok your control board may be shot.
Feb 01, 2007 | GE Profile Advantium SCB2001KSS Stainless...
GE Spectra XL 44 Self Cleaning
Ray, sometimes the burners get gunked up. Remove the cap and burner and see if the small orifice that is located by the spark electrode is clogged. Clean it out with a paper clip. Make sure the burner cap has good contact with the burner. Catriver..post back.
Dec 06, 2006 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
87 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
