Question about Samsung DLP HL-P5663W 56" TV
I try to vibration pcb but samething problem on many horz line on picture.
  • 10,594 Answers
Please intimate exact model and brand of your TV that you are looking for info.
Thanks.
Posted on Jul 19, 2009
After 10 to 20 mins left half of screen goes to white vert lines
Sounds like power supply regulator board fault. Check all the electrolytic capacitors for any leaked or bulged one. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. Do asearch by type in the brand name of your device at its search box.
It will be best to replace the power supply regulator board as card basis.
Jul 01, 2014 | Samsung LN32D450G1D 32 LCD TV
Very wide pink and green horz lines, no picture
CLEAN Y SCAN RIBBON CABLES WITH CONTACT CLEANER AND COMPRESSED AIR IF THEY DONT DISAPERR REPLAC Y SCAN BOARDS
Apr 25, 2010 | Samsung HP-R4252 42 in. Plasma HDTV
Red key located on screen only here the sound
If you have sound and no picture,do you have on screen graphics? If no you have lost High voltage and have no horz. or vert. deflection possible power supply problem needs to be repaired by qualified Technician. If you have on screen graphics you may have a problem with the input you are usng,TV,VCR or LINE
Apr 11, 2010 | Apex Digital GT2025DVR 20 in. TV/VCR/DVD...
Hi, Two sets of lines have appeared on the screen
are these lines vetical or horz if they are vertical your panel has failed and will need to be replaced big bucks if they are horz , then it could just be the T-con board and you will need a tech to confirm this I have seen this problem cause by a poorly seated connection
Dec 07, 2009 | Televison & Video
I have a good picture then it goes horz. with static and then a good picture and then a horz. lines and static about every sec.
The horizontal line indicates failure of vertical section, checkout the output capacitor of vertical-section connecting to the yoke (vertical) for any loose contact, dry solder, capacitor wear-out.
Need to check the register and filter capacitor that powers the vertical-section.
Sep 28, 2009 | Sanyo DS25390 TV
Red Horizonal Lines
Good Day;
You may have bad picture tube or convergence problem. Good Luck, big IRIShH.
Sep 18, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Hi, Vs-4561 MItsubishi rolling picture
Good Day, pleasehelptv;
Those caps may be the problem but try this:
VERT JITTER/HORZ UNSTABLE-CHECK 'GE' CONNECTOR PIN 5 FOR 1VPP Y SIGNAL INTO PIP PCB THEN CHECK 'GE' CONNECTOR PIN 11 FOR 1VPP Y SIGNAL FROM PIP PCB. IF SIGNAL AT PIN 5 IS GOOD AND PIN 11 IS CLIPPED OR REDUCED. CHECK ALL ELECTROLYTICS (I.E.C7001, C7014, C7026, C7036) AND ALL CONNECTING TRACES TO THESE CAPS FOR CONTINUITY 2. HORIZONTAL TEARING,VERTICAL JITTER. SIGNAL RELATED CONDITION. APPLY FOLLOWING CIRCUIT CHANGES ON PCB-SIGNAL: A. REPLACE R2K8 WITH A 1K RESISTOR (BASE OF Q2B2). B. REPLACE R2K3 WITH A 47 OHM RESISTOR (IC201 PIN 50). C. ADD A 100PF CAPACITOR FROM BASE OF Q2B2 TO JUNCTION OF R2L0 AND R2K6 (GROUND).
HOPE THIS WAS HELPFUL.
Good Luck, big IRISH.
May 15, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Jitter and tearing on bright pictures
1. VERT JITTER/HORZ UNSTABLE-CHECK 'GE' CONNECTOR PIN 5 FOR 1VPP Y SIGNAL INTO PIP PCB THEN CHECK 'GE' CONNECTOR PIN 11 FOR 1VPP Y SIGNAL FROM PIP PCB. IF SIGNAL AT PIN 5 IS GOOD AND PIN 11 IS CLIPPED OR REDUCED. CHECK ALL ELECTROLYTICS (I.E.C7001, C7014, C7026, C7036) AND ALL CONNECTING TRACES TO THESE CAPS FOR CONTINUITY 2. HORIZONTAL TEARING, VERTICAL JITTER. SIGNAL RELATED CONDITION. APPLY FOLLOWING CIRCUIT CHANGES ON PCB-SIGNAL: A. REPLACE R2K8 WITH A 1K RESISTOR (BASE OF Q2B2). B. REPLACE R2K3 WITH A 47 OHM RESISTOR (IC201 PIN 50). C. ADD A 100PF CAPACITOR FROM BASE OF Q2B2 TO JUNCTION OF R2L0 AND R2K6 (GROUND).
Jan 21, 2008 | Mitsubishi VS-60611 60" Rear Projection...
Picture on TV showed as small lines at the top of the screen. Sound was fine but picture was bad. This happened while playing a video game. Unplugged TV from the outlet for about a half hour. Plugged it...
I would definitely say you have a heating up problem, im guessing either the convergance ic are heating up or HOT or horz output or a capacitor, you could try spraying freeze (radio shack carries it) when the problems starts showing up to isolate the problem.
Dec 21, 2007 | RCA P46921 46" Rear Projection Television
D40W20
Part of your feedback voltages are now incorrect. Find the solder bridge and remove it then see if you at least get back where you were...accordianman
Oct 16, 2007 | RCA Scenium D40W20 40" Rear Projection...
Samsung DLP HL-P5663W 56" TV Logo
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
