Question about Intex Krystal Clear Model 635 Pool Filter Pump 1500 Gph
Same as others with Krystal clear model 635 pump.
This pump is a piece of junk. It makes ('made' now because it quit working) loud noises from day 1. Ends up the impellor sheared all its blades as someone else described. Can't get a replacement impellor, also as someone else described. Turns out it is made in China. No surprise. The probem is the impellor blades hit the housing, eventually causing the blades to shear. I had to modify my pool a bit with fittings and such so the pump and strainer I bought would adapt to my pool. Therefore, unfortunately I had to buy the same pump to replace this one. Since the pump has a 1 year warranty, my solution is to send back my old one before a year has expired. A little dishonest, but if a company cannot support their product (w/ replacement impellors) then I have no other choice.
    Scholar:
  • 86 Answers
We too have an Intex pool and opted to not waste money on their pumps which arent adequate enough to properly filter the pool. We bought a nice sand filter system off a great seller on amazon for $305 delivered. (DO NOT BUY "GAME" system for intex pools, my sister bought one and has had nothing but problems and just bought 5 weeks ago).
We are very happy with the results from our Waterway sand filter system. We did not have to buy any adapters to fit it to our pool. And it keeps the water perfect! We have an 18' x 52 metal frame pool. If you intend on using your pool for years, I recommend buying a sand filter system. It is more expensive than replacing the intex pump, but you will be much happier with the sand filter system.
Hope this helps. Good luck!
Posted on Jul 29, 2009
Krystal Clear 635 pump shuts on and off
my pump only wok 28 days and broken no more work a need return please
Aug 01, 2012 | Intex Krystal Clear Model 635 Pool Filter...
Tip
How to fix the Model 635 pump issues
Take that piece of junk and toss it. There are simply no replacement parts available. Replace with a Pentair 3/4HP Dynamo and a 75 sq. ft. filter unit. You can use the existing Intex hoses with 1" couplers and pipe clamps. Buy a length of 1-1/2" flexible spa hose to connect from pump to filter. It'll cost about $400 all told for this setup (if you do the install yourself), but you'll recoup the cost in the 3-4 years you'd spend replacing the 635 annually.
on Jun 09, 2009 | Intex Krystal Clear Model 635 Pool Filter...
Manuel neede for a intex krystal clear pump model 638 with skimmer basket
Below is a copy of the users manual for the krystal clear 635. It should have everything in that you need to set up your pool filter.
http://www.pooltoysource.com/images/pdf/RVR006.pdf
Nov 15, 2010 | Intex Krystal Clear Model 635 Pool Filter...
Intex Krystal Clear Filter/Pump Model 635 replacement parts for the pump
my intex 635 pump impeller is broken i need a replacement part. i do not have the money for a new pump.
Jun 30, 2010 | Intex Krystal Clear Model 635 Pool Filter...
Filter is making clunkity type noise when filter is started
it sound like it may need bearings. trouble is getting anybody to work on one of these. if you take the cover off of the motor side and listen to it and look at the shaft on the motor , if its all rusty ? its junk see if you can find pump and motor replacement on ebay.. i help any ? vote .. thanks jay
May 26, 2010 | Intex Krystal Clear Model 635 Pool Filter...
How many horsepower does the krystal clear model 635 pool filter pump have
IF YOU PLAN TO REPLACE THIS PUMP , LOOK FOR A HAYWARD 1/2 HP SUPER PUMP. THERE CHEAP AND TUFF . USE YOUR OLD FILTER.. THAT MOTOR IS AROUND A 1/2 .. LOOK AT THE AMPS IT USES, ITS ON THE MOTOR . SAY 15 AMPS IS A 1HP AT 115 VOLTS
May 25, 2010 | Intex Krystal Clear Model 635 Pool Filter...
Krystal Clear Model 635 Pool Filter Pump 1500 Gph: I can not find my manual and I cant remember if th...
If you are talking about the plastic o-ring for your pool filter, it goes on the top, if I remember correctly.
May 17, 2010 | Intex Krystal Clear Model 635 Pool Filter...
My krystal clear 636 pump sounds like its working but no water being pumped back into pool, any ideas my pump actually says model#636 on the side
IF WATER IS NOT TURNING IN PUMP BASKET IT IS YOUR IMPELLER AS THIS IS A COMMON PIECE THAT BREAKS ON THESE PUMPS MAKE SURE YOU HAVE ALL CONNECTIONS TIGHT AND ALL VALVES ARE OPEN TRY TAKING RETURN HOSE OFF THE POOL AND START TO SEE IF YOU GET FLOW YOU WILL HAVE TO PUT A PLUG IN RETURN SO WATER DOESNT LEAK OUT
Jun 28, 2009 | Intex Krystal Clear Model 635 Pool Filter...
Need impeller for 635 Krystal Clear pump
You can't. This exact thing happened to me at the end of last year. All the fins are broke. We ended up upgrading to the pump, and now this one overheats after 30 minutes and shuts off!
Problems with Intex Krystal Clear Model 635 Pool Filter Pump 1500
No, the pump should not be noisy. It sounds like you have picked up a foreign object in the pump housing. you may have to pull the face off to determine. OR the pump/motor is indeed defective and should be returned.
Mar 15, 2009 | Intex Krystal Clear Model 635 Pool Filter...
Intex Krystal Clear Model 635 Pool Filter Pump 1500 Gph Logo
558 people viewed this question
Top Intex Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Charles T Nevin
Charles T Nevin
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
