Question about Garden
My Toro 17-44 HXL Model # 71228 was running just fine. I got off to move a bike and when I tried to start it up it would not start. It would try to start and then it would bang and then die. I checked the air filter, fuel filter, oil and everything looks ok. I let the mower sit over night and then tried to start it again. It started right up without any problems. After about 5 minutes it died again and when I tried to start it the same thing happened and it wouldn't start. It tries to start and then it bangs and shuts off.
  • bill
    bill May 11, 2010
    If you havent checked the oil this year, DO SO IMMEDIATELY!!!!!!!!!!!!!
boscia
  • 163 Answers
SOURCE: engine revs faster than it should. no controle of speed.
on the bottom of the carb is a metal bowl, remove and clean internal parts. make sure the float moves freely and isnt sticking
Posted on Nov 30, 2008
  • 95 Answers
SOURCE: Engine dies for no apparent reason after several hours running
Sonds like a sensor putting out an error code to shut it down ( like a fatal error code) Prolonged vibrations and heat can make cam sensors, maf, o2 senosr do craz ythings which will actuate a govener and stall your car...could also be you fuel pump causually telling you that "hey im bout to die".I dealership can run a stress test (if you will) to check the longivity of the pump...
Good luck hope this helps :)
Posted on May 19, 2009
SOURCE: toro personal pace mower 5 yrs old only runs 10-15 seconds.
Was gasoline left in the tank during off season? Sometimes gas will break down and clog the jets in the carb. The priming bypasses the carb so when you put fuel in by pumping the bulb it runs, but dies becasue no additional fuel is coming through the carb after the primed fuel is burned off. Sounds like you need to clean the jets in the carb and in the future, use Stabil in gasoline to keep it from breaking down.
Posted on Jun 30, 2009
woobie dog
  • 1273 Answers
SOURCE: My LawnBoy mower 195 cc 4 cycle that starts fine.
It sounds as though it is starved for fuel. Check the pinhole vent in the fuel filler cap. if it is plugged, the engine will still draw fuel, until a vacuum is pulled on the tank, resulting in no fuel. If this doesn't fix you. check for adequate fuel at the carb, and wirk either forward or backwards from that point, depending on what you find. I'm betting on the vent!
Try it; it may be just the thing!
Best regards, --W/D-- please feel free to rate this solution! Thanx!
Posted on Jul 30, 2009
M2Tech1
  • 313 Answers
SOURCE: john deere 42 inch,17.5 hp-was running good then
have you had a look at carb side of things as it may be having fuel starvation probs.. the fuel in line not getting through jets or float chamber cleanly.. also the tank might have contamination from rust or debris..
Posted on Aug 13, 2009
Toro wheel horse XL series model 71212 / 17-44 hxl manual
Go to https://www.toro.com/en/parts and enter your model number 71212, it will give you choices for parts, operator, etc.
Apr 27, 2017 | Toro Garden
I have a Toro HXL 16-44. Starts but then shuts right off after initial try, then will not start up again at all. Just turns over, never starts up.
Your fuel needle is not closing , allowing too much fuel... there needs to be a proper fuel air ratio. Have you recently had the unit serviced? Someone mess with the carburetor itself?
The float needs to be adjusted so it closes the needle sooner
Oct 17, 2015 | Toro Garden
I can start my Toro 14-38 HXL riding mower but it will only run for about 30 seconds I have changed the fuel filter any other suggestions?
will it run longer on 3/4 choke?
Sounds like you need to clean the Carburetor Jet.
Has the mower been running fine all season and just start this or have you not run it in months?
Did you run it out of gas totally and then this problem ocured?
Aug 05, 2013 | Garden
Toro wheel horse 14 38 hxl
check your wiers that go to you solinoid but first try to jump your mower usind jumper cables put the red cable on the bottom bolt of your solinoid and find a good ground for the black cable then let you car warm up then trun the key on your mower to start and it will start
May 12, 2013 | Toro Garden
When i try to start the riding mower will only crank once.....toro 16-hxl will crank once, then nothing
Make sure your battery is in good condition first. Then if your machine is an OHV you might want check the intake and exhaust clearance. Go to smalleng.com and watch video they have a great tutorial on this subject. Good Luck...
Sep 26, 2011 | Toro Lawn Mower With Toro Power Tools
I have a Toro 1644 HXL mower.It starts fine but if you go to release brake/clutch or try to engage blades it dies immediately. Will start right back up? Safety switch?
u have a saftey interlock circuit issue, poss a bad seat switch or relay is causing it to die when the pedal is released.....good luck hope this helps oh and also might even be the blade switch itself.... get out the volt meter and go to work my friend!
Nov 19, 2009 | Garden
15 38 hxl moves slowly, trans won't pull on incline
If the transmission whines, the brake may be sticking. you may have to relocate the brake return spring, to the rear of the flange that the spring is currently attached to
Aug 13, 2009 | Toro Lawn Mower With Toro Power Tools
Hello, my Toro 14-38 hxl (model 71193)is not
I have 12-38 hxl, and if my grass is too tall, it will wedge under the cutting deck and lock the blades, and the belt willstart smoking white. With the motor off look under and see if you do not have something stuck (branches or grass).Also, check your sparkplug.
Jun 05, 2009 | Toro Garden
Garden Logo
701 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
