Question about Dell Inspiron 9300 Notebook
Dell Inspiron 9300 la[ptop will not boot up, black screen
I have the same issue. I start my Dell Inspiron 9300, the windows xp startup begins and then it goes black. It makes all the start up sounds, but no screen. I can start it fine in safe mode and see everything, but when I try to restore it I get an error message saying I can not do system restore in safe mode. Help!!!!
Tried to start my dell inspiron 1521 laptop, and invalid partition type on a black screen came up and will not load windows. i have window xp home edition, x65 on it. this is the first time it's happened...
Is this system in dual boot mode?I guess the primery OS has failed due to which you are facing this issue.Try doing a factory image restore or try a repair installation of windows XP
Dec 26, 2010 | Dell Inspiron 1521 Laptop
I've got an Dell Inspiron 9300 LCD
Try running diags Fn + Power button see if anything fails
Since you can boot to the BIOS, then the system is posting, so I suspect you have either a Windows issue or a hard drive issue.
If the HDD passes diagnostics, I'd try booting to the XP CD and see if you can press R for recovery console and run the command CHKDSK /R and see if that resolves
Post back with the results
Jul 19, 2010 | Dell Inspiron 9300 Notebook
Starting problem
Immediately after seeing the Dell logo, keep tapping the 'F8' key,
until you see a "menu" (white text over a black background)
giving "startup" options for Windows XP.
Select "Safe Mode" and see if you can start in that mode.
Then, use "System Restore" to go "back" in time, to the most-recent checkpoint (date/time) where your computer _DID_ work.
Restore to that point, and restart.
Jul 17, 2010 | Dell Inspiron 1525 Notebook
Start menu issue
If a system restore does not take care of this issue, then i recommend backing up all data then reinstalling the operating system. If you need further assistance, you can contact us 24/7 at 800-595-3564. Thank you.
Jan 18, 2010 | Dell Inspiron E1505 Notebook
Dell Inspiron blank screen
You can restore your system in your safe mode.
To use System Restore to restore Windows XP to a previous state, follow these steps:
  1. Log on to Windows as Administrator.
  2. Click Start, point to All Programs, point to Accessories, point to System Tools, and then click System Restore. System Restore starts.
  3. On the Welcome to System Restore page, click Restore my computer to an earlier time (if it is not already selected), and then click Next.
  4. On the Select a Restore Point page, click the most recent system restore point in the On this list, click a restore point list, and then click Next.
    Note A System Restore message may appear that lists configuration changes that System Restore will make. Click OK.
  5. On the Confirm Restore Point Selection page, click Next. System Restore restores the previous Windows XP configuration, and then restarts the computer.
  6. Log on to the computer as Administrator. The System Restore Restoration Complete page is displayed.
  7. Click OK.
If you successfully restored your computer to a previous state, and the computer is performing as it should be, you are finished.
Jun 11, 2009 | Dell Inspiron 9300 Notebook
Dell inspiron 1525 notebook will not start windows
Usually this happens when the vista boot loader fails. During boot up, keep tapping F8 and then select Disable Automatic Restart... and get the stop error code which usually starts with 0x
Jun 09, 2009 | Dell Inspiron 1525 Notebook
Dell Inspiron B130 Startup Issues
when digit the password to initiate does not initiate and it gives the following message me:
The User Profile Service service failed the logon.
User procases out cannot sees loaded
por favor la repuesta en español
Compaq Presario CQ60-215DX Note book PC
May 10, 2009 | Dell Inspiron B130 Notebook
Laptop black screen during boot, then normal in Operative System
is it affecting your pc
you can change the bootup display time if you want
but I would leave it as is if your system is not affected by it
Jan 20, 2009 | Dell Inspiron 9300 Notebook
Black screen dell inspiron
simple, insert the CD XP boot it on using it, then repair wait for a moment, then it give you options which is either to repair your OS or install it again. thats it
Dec 14, 2008 | Dell Inspiron 6400 Notebook
Dell Inspiron 9300 Notebook Logo
347 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
