Hi, the best option would be a hard reset. Before doing so, i would suggest doing one lase hotsync.
at the back of your pda, there is a reset button. press this. be prepared. as it is resetting, press and hold the power button as well as the up button. hold these for like 3 seconds then release. it will then ask you whether you wanted to reset it. press the up button once again and release. it will then reset the pda.
if these instructions are still difficult there are some at palm.com. best of luck.
my TX screen/stylus alignment is off: at the bottom of screen it is necessary to tap more than the...
(More)
my TX screen/stylus alignment is off: at the bottom of screen it is necessary to tap more than the width of the keyboard row below the desired letter to get it and the bottom row of commands doesn't respond at all, no matter how many times I do the alignment in set-up/preferences. Anyone has a solution?
Problem connecting to wifi won't recognize the wifi source but sometimes it does. i.e. scan shows...
(More)
Problem connecting to wifi won't recognize the wifi source but sometimes it does. i.e. scan shows wifi source then scan again it won't see it! maybe mutable times then it will! Now you see it now you don't? Try to connect may take up to 5 times before it connects.
