Question about NEC Computers & Internet
I have an old NEC audio computer sound setup with a base that fits into front 51/2 slot large w/ a sub/out cable(looks like a earphone cable)w/4 more outputs speaker jacks.Only# on it is MIFGML-3387 FCC ID.Never used I need manual/Drivers ect Could really use HELP and see if its woeth setting up. Thanks John.H This Computer set up is old,but never used Really want to know is that, or this worth installing in my PC Help,Advice Driver,manual would really HELP Again Thanks
  • 279 Answers
SOURCE: Connecting 4 speakers
The microphone jack won't help you at all. It only accepts incoming sound, it doesn't play anything back.
The problem with using the headphone jack is that it puts out more current, since headphones aren't usually self powered. It's generally not good for the speakers to use the headphone jack for them.
And as your speakers did not all come as a single set, it's unlikely either set has output ports designed to plug additional speakers in.
So what you need is the stereo mini jack splitter, as electroguy mentioned. In case you don't know what we mean by that, here are a couple links to sites with two different versions:
http://catalog.belkin.com/IWCatProductPage.process?Product_Id=149749
http://www.dv247.com/invt/13646/
However, you probably can save money by buying it locally. For small items like that, shipping kills any savings you have online. I know Radio Shack sells them, but it's likely you can get them at any store that sells stereo equipment.
Once you have the splitter, just plug it in to the back of your computer, where your speakers are currently plugged in, and plug each set of speakers into one of the two ports on the splitter.
Hope that explains everything clearly.
-Dyllan
Posted on Dec 17, 2007
SOURCE: loud buzz on every output with no audio
Hi, Its a pretty easy fix of your handy with a soldering iron, just replace all of the caps near the power supply. Make sure you replace them with the same or higher voltage rating.
Posted on Mar 16, 2008
DCSE
  • 191 Answers
SOURCE: internal speakers not working
try reinstalling the audio drivers first
as it seems to be an issue with either drivers or with the sound card
provide more info like
when was it working fine
wots the operating system you are running
Posted on Jun 07, 2008
  • 479 Answers
SOURCE: Can get signal from UA-25 to computer... but no audio from computer to UA-25?
try reinstalling the device as some of the files may not be copied correctly
Posted on Sep 29, 2008
SOURCE: Durabrand 2.0 CH USB Speaker System
all i get is static out of my 2.0 durabrand usb powered speakers whengged in
Posted on Oct 10, 2008
No sub woofer volume
Make sure Subwoofer power is on and connected with RCA cable in correct place.
Go into setup of "Speaker setup" and select 5.1 setup. Activate subwoofer to YES if setting is No.
On some Amps you need to select front speakers to SMALL even if you have large speakers to enabled subwoofer.
Sep 08, 2014 | Yamaha RX-V375 5.1 Channel Home Theater...
Want to connect pc speakers and subwoofer to lg37lc55 tv unfortunaly it doesnt have an earphone 3.5 connection point. My other smaller tv does, the speakers and subwoofer consist of a white and red audio...
Your TV should have an AUDIO OUTPUT other than optic..at least " Headphones" output..
You can connect TV audio output with a RCA cable.
white and red audio jack....
since SUB has both RCA and "3,5mm Headphone female Jack"..here are the options;
** you need to buy a cable one end 3,5mm MALE headphone jack and the other end 2xRCA stereo (or 1x RCA for mono or you may need "Y cable " ) to be connected to your TV...
** or 2x RCA
white and red audio jack and connect from your TV..
**" "Headphones" output to SUB with 3,5 male-to-male cable ( the least recommended)
And you need to connect front,centre and rear speakers to your SUB as well...
Take care and if it succeeds please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
May 19, 2011 | LG 42LH40 LCD TV
I have a new windows 7 laptop that I am trying to use my old yamaha MS55D speakers with, but it says there are no drivers. Please can you suggest where I might get the driver or what else I can try
PROBLEM SOLVED: YAMAHA YST-MS55D allows both USB and audio jack. On the back of your subwoof - find the USB ONLY area. Disconnect the USB cable from your sub and computer. Then use the other audio cable to link ur sub with the audio jack on your computer (the earphone plug). You don't need to change the other connections. Your Speaker will then function like an earphone, which means no drivers needed as it is not a USB device anymore.
May 16, 2011 | Yamaha YST-MS55D Computer Speakers
Sound cable connection
Look more closely at your motherboard, for a 4-pin "PC Speaker" label.
The "HD Audio" is _OUTPUT_ (left front, sub-woofer, right front, left back, right back) to Surround Sound speakers.
Dec 31, 2009 | Foxconn (945G7MA-8KS2) Motherboard
I get no bass sound from sub-Woofer connected to Yamaha RX-V465
Check your speaker settings in Setup menu / Speaker Setup / Manual / Config (and then in this submenu also Equalizer).
In Config, choose where should low frequency sound go - subwoofer and/or front speakers (if they are big enough). The settings are: Bass Out: SWFR/Front/Both.
Also check Subwoofer phrase in SWFR Phase.
Check settings of all speakers, they can be Large / Small / None. If small, frequencies lower than "Crossover" settings, will not be put on them.
Nov 13, 2009 | Yamaha Rx-v465/rxv465 Home Theater...
K9N6PGM2 motherboard cant get front audio micrphone and headphone sockets to work
In my case, it was solved by tweeking the sound utility, and not by touching anything in the computer:
  1. Make sure "Realtek Audio Manager" is installed (should come with the drivers)
  2. Start The "Realtek Audio Manager" (can do it by plugging earphones to the audio jack on the rear - the one the works)
  3. Look for the configuration tab - something like "Connector Settings"
  4. Set the "Disable front panel jack detection" checkbox
  5. Press [OK]
  6. Try again to connect the earphones to the front panel
See link from MSI forums:
http://forum-en.msi.com/index.php?topic=120665.msg911410#msg911410
Oct 16, 2009 | Computers & Internet
Intex tv tuner card SAA713x and computer sound on one point
this will make your life alot easier
http://www.radioshack.com/product/index.jsp?productId=2103863
best way to do it bud
Aug 20, 2009 | Philips SAA7130 TV Tuner/FM Radio/Video...
How do i hook up a nintendo to my tv which cords go where and can someone walk me through it
Round peg into the round hole. Red peg on the red slot. etc. If the wire from the nintendo doesn't fit the slot on the tv then you're in the wrong slot. if the wire from the nintendo fits the slot on the tv (and is the same color if you are using red/white/yellow rca cables) then you're good. here's a hint on connection types (you will not mix): 1. RCA (red/white/yellow round connectors) Red=right audio sound White=left audio sound Yellow=video connect to the slots that look like they want some. 2. Coaxial (stiff cable with a pinner poking out of the end -- same cable that connects you to cable tv) just hook it up by itself; it carries audio and video. 3. Component (red/green/blue)(red/white) two 'bundles' red=red component of video green=green component of video blue=blue component of video red=right audio white=left audio 4. VGA + (red/white) VGA=video (computer monitor cable) red=right audio white=left audio 5. HDMI (flat hdmi cable. you spent $30 on this 3 foot ****) HDMI=audio and video 6. hugs and kisses hugs=video kisses=audio (both sides)
Jul 15, 2009 | Video Game Consoles & Games
Subwoofer
Depends on what you have it hooked up to. Check wiring and controls if it is self powered. Check receiver/amp to see if it is outputting to subw.
Apr 12, 2008 | Pioneer VSX-D608 Receiver
I have a Pioneer VSX-35TX receiver when connected to the subwoofer there is no sound questions on what I am doing wrong.
Set front speakers for small and make sure sub is turned on in setup mode. If Front speakers are sent to large I believe the only time sub will work is with Dolby Digital Lfe signals. If sub is turned off of course it will never work.
Feb 10, 2008 | Audio Players & Recorders
Computers & Internet Logo
298 people viewed this question
Top NEC Computers & Internet Experts
Steven Wander
Steven Wander
Martin Murray
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
