Question about Carrier 38CKC042 Air Conditioner
@ heat pump fan not running
Can push start fan an then it will go--but air at vents not very cold---could problem be bad pump an fan motor
  • 614 Answers
Sounds like a bad capacitor. The capacitor starts the fan and the compressor. You can replace it or have a service tech do it for you. Cost about 150 to 180 to replace.Russ
Posted on Jul 20, 2009
That was the problem and it has been fixed...........THANKS!
Posted on Aug 18, 2009
When the heater is on, should the fan outside on top of the unit also be working along with the blower from the heater ? When the heater is off, cold air is comming from the vent's, can I cover the
No. This is strictly a gas package unit, not a heat pump. the condenser fan motor should NOT run when their is a call for heat from the thermostat. The condenser fan only runs with the compressor on a call for cooling. Hopefully the compressor is not running @ the same time, but if it is, it would make sense that the contactor for the compressor & condenser fan motor is stuck closed OR the low voltage cooling wires are shorted straight to a 24Volt control wire.
Jan 15, 2015 | Carrier Heating & Cooling
Why is my 98 ford ranger blow super hot heat out of the vents when the heat is turned of also its overheating why?
Two different issues. The vents and hot air is caused my a cold air mixture door motor gone bad, it's very common. Replace the blend door motor to fix that issue. Overheating could be caused by many things including non working coolant fan, bad t-stat, bad water pump, low or leaking coolant or excessive buildup in coolant system.
Aug 19, 2014 | Cars & Trucks
I have a york 80 diamond heating and air conditioning unit. When it is turned on air comes out of the vents but it does not feel cool at all. When I check the unit outside it sounds like it is on but the...
Hello, if the compressor is running on the outside unit and the fan is not either you have a bad capacitor or a bad fan motor, if the fan starts with a push then your capacitor is bad, if it does not the motor is shot.
Jun 16, 2011 | Heating & Cooling
Fan motor does not blow hot or cold air when turned on
your fan motor is located on firewall behind engine towards middle of car under a cover gain acess turn fan on inside car lightly tap back of motor if fan starts running you have a bad fan motor i assume you have already checked your fuses
Mar 16, 2010 | 1999 Cadillac Eldorado
AC unit outside blowing out cold air, vents
Sounds like compressor not running. may be a bad capacitor, could also be low on freon.
Aug 30, 2009 | Goodman CLJ30AR32 Air Conditioner
Air conditioner and heat blower
You will have two fans, one fan blows out the rear of the unit that cools the condenser soil, one blows out the front across the evaporator that blows the cold air out into the room. Some window a/c's have whats called a squirrel cage fan assy. that has one motor that runs both fans. So you either have one bad fan motor (the evap fan motor) or you have a bad fan blade that has fallen off the shaft. Also check the filter see if it is clean.
Jul 30, 2009 | Heating & Cooling
2003 buick lesabre AC problem
You have to find the motor that controls the blend door and open it manually to find out which one is bad there are 3 blend doors on the HV/AC system one will be where the heater core is. The other will be between the vented air and AC? heating system then the third door will operate vents in dash and defrost condition. If you have someone operate them AC system heating system and watch the blend door motors, the one you find not moving will be the one that has the problem. They have vacuum and electrical motors, if it is a acuum motor you can move the door manually with your hand, if it's electric you will have to disconnect the rod by removing the pinch clip off of the rod.
Jul 10, 2009 | 2003 Buick LeSabre
Air conditioning and heating
have the water pump checked out, i had a van that did the same thing and founf i had a bad water pump it fixed the problem.also check the blower motor to make sure its working right by tapping on it while you have the car running. the car will survive dont worry its going to be one of those two things im pretty sure.
Jan 08, 2009 | 2001 Saab 9-3
High Pressure cutoff
YOUR OUTDOOR FAN MOTOR SHOULD NEVER SHUT OFF IN THE AC MODE. IT IS SUPPOSED TO SHUT OFF IN THE HEAT MODE WHEN ITS IN DEFROST. IF THE UNIT IS RUNNING IN COOL AND THE OUTSIDE MOTOR QUITS ,THE COMPRESSOR WILL QUIT SOON AFTER. EITHER THE RUN CAPACITOR FOR THE FAN IS BAD OR THE FAN MOTOR ITSELF IS BAD, IF CAP IS GOOD THEN THE MOTOR IS At FAULT. THE OUTDOOR PRESSURE SWITCH CAN ALSO OPEN IF THE INDOOR FAN MOTOR FAILS IN HEAT OR THE FILTER IS PLUM NASTY in heat OR THE INDOOR COIL IS PLUGGED UP in heat.. THE PRESSURE SWITCH USUALLY TRIPS AT 400 TO 425 SO ITS WORKING CORRECTLY. YOU MAY BE CONFUSING THE ISSUE SAYING THAT THE AIR IS HOT AND COLD INSIDE. IT IS COLD WHEN AC IS RUNNING HOT WHEN HEAT PUMP IS RUNNING IN HEAT BUT ESSENTIALLY not cold or hot if compressor isn't running, but a lot of folks describe the lack of cold air as hot when the compressor isnt running. but it basically is warm or house air temp.you test the capacitor with a capacitor tester or take it to motor shop and let them test it. odds are its a 5 , 7.5 or a 10. it should test within 10 % of rated value . ask for a RESCUE brand replacement motor. they are great ,reversable etc.carefully oil and sand the motor shaft and note exactly where the blade was located in relation to the grill so you get it back just the same. usually they wire up black to a leg of 220 power. white to the other leg of 220 power. brown and brown with white stripe to the capacitor.you can also pull whole fan shroud assembly on some units and take whole thing to motor shop and let them test motor cap, replace and all you do is return to unit and connect two power leads,
Oct 26, 2008 | Heating & Cooling
Carrier 38CKC042 Air Conditioner Logo
590 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
