Lincoln Master
- Posted on Nov 10, 2016
Re: How to replace the door blend actuator on 2009...
Right side or left ? Electronic Automatic Temperature Control or manual ? Temperature or mode door ?
Temperature Blend Door Actuator - LH
Removal and Installation
NOTE: It is not required to install the new LH temperature blend door linkage parts included in the LH temperature blend door actuator service part kit if only the temperature blend door actuator requires replacement and the linkage parts are not broken or binding.
LH temperature blend door actuator and linkage
- Remove the 2 lower steering column opening cover bolts.
- Detach the lower steering column opening cover.
- Disconnect the in-vehicle temperature sensor aspirator hose and electrical connector.
- Position the instrument panel wire harness away from the LH temperature blend door actuator.
- Remove the 3 LH temperature blend door actuator screws.
- Disconnect the LH temperature blend door actuator electrical connector.
- Remove the LH temperature blend door actuator.
- Manually operate, and inspect the LH temperature blend door linkage for incorrect placement, binding or damage.
Temperature Blend Door Actuator - RH, Dual-Zone EATC
NOTE: It is not required to install the new RH temperature blend door linkage parts included in the RH temperature blend door actuator service part kit if only the temperature blend door actuator requires replacement and the linkage parts are not broken or binding.
RH temperature blend door actuator and linkage
- Disconnect the glove compartment damper from the glove compartment.
- Remove the glove compartment.
- Remove the RH lower instrument panel insulator.
- Remove the RH lower floor console trim panel.
- Remove the 3 RH temperature blend door actuator screws.
- Disconnect the RH temperature blend door actuator electrical connector.
- Remove the RH temperature blend door actuator.
- Manually operate, and inspect the RH temperature blend door linkage for incorrect placement, binding or damage.
Mode Door Actuator - Defrost/Panel/Floor Door
- Removal and Installation
NOTE: The defrost/panel/floor mode door actuator can be accessed from below the driver side of the instrument panel.
NOTE: It is not required to install the new defrost/panel/floor mode door linkage parts included in the defrost/panel/floor mode door actuator service part kit if only the mode door actuator requires replacement and the linkage parts are not broken or binding.
Mode door actuator and linkage
- Remove the 3 defrost/panel/floor mode door actuator screws.
- Disconnect the defrost/panel/floor mode door actuator electrical connector.
- Remove the defrost/panel/floor mode door actuator.
- Manually operate, and inspect the defrost/panel/floor mode door linkage for incorrect placement or damage.
Mode door actuator linkage only
- Remove the mode door linkage.
- Depress the tab and remove the panel door lever.
- Remove the floor/defrost door intermediate lever screw and floor/defrost door intermediate lever.
- Pull straight outward to remove the floor/defrost door lever.
- NOTE: When installing the mode door actuator, make sure that the panel door lever and floor/defrost intermediate lever are correctly aligned with the mode door actuator cam.
To install, reverse the removal procedure.
