Question about Briggs & Stratton Garden
No amperage from alternator. charged battry and started fine, but after mowing lawn would not start again until after recharging battery.
  • Briggs & Str... Master
  • 2,478 Answers
Have your battery checked. Sounds like may be bad.
Posted on Dec 09, 2011
    Scholar:
  • 173 Answers
It's the Magneto, that's the problem.
If you aren't recieving a spark, when it's turned over.
Alternatively, it could be the timing.
Hope that fixed ya!)
Posted on Jul 23, 2009
Battery losing charge
Sounds like you have defective diode rectifier. this little box when working properly allows your voltage to only go 1 way to charge the battery. if you have used a vehicle to boost the tractor you have damaged the rectifier. because a vehicle running puts out 14.8 volts lawn equipment is 12 volts only you can boost using a vehicle only if it is NOT running
Apr 04, 2014 | Garden
Battery drains and won't charge
I would start by having battery tested. If u remove it and take it to auto parts store they will test it for free. It could be that the battery will not hold a charge or your tractors alt. is not putting out a charge
I have a 1998 hyundai coupe 1599cc the engine cuts out when idling and i have to jump start it or wait for about half an hour before it will start again
This sounds like a battery or alternator problem.
Lets start with the battery, just because the car starts in the morning does not mean the battery is good, A bad battery will start the car and as car is running and drawing power out of the battery the battery which is getting charged back up from the alternator but if battery is bad and not accepting the charge this will do a few things.
First it will cause damage to the alternator because , the alternator will try to charge the battery with no result and so it keeps charging at high rates and heats up and causes damage to itself , the next thing is battery loses voltage slowly until it does not have enough voltage to keep engine going , inturn engine stalls out,
I would start by first having the battery tested by a shop with a battery tester, the next thing is the alternator , have that tested.
Your problem will be a bad alternator or battery. good day.
Jun 24, 2012 | 1999 Hyundai Accent
REPLACED STARTER THEN RECHARGED BATTERY CAR STARTED FINE THEN DROVE FINE THEN GAGES ON DASH STARTED GOING CRAZY ALONG WITH RADIO THEN CAR ACTING LIKE IT WANTS TO DIE NOW WONT START
sounds like your battery is dying,, have it LOAD tested,, it could show 12 volts, but the amperage isn't up to par,, even with one bad cell the battery will drain , also,, once you know its fully charged, start the vehicle,, use a meter at the battery posts to check the voltage,, you should get a reading of 13.5-14.5 volts, if not your alternator isn't doing its job, make sure all battery connections are clean and tight.
Sep 11, 2011 | 2002 Ford Explorer
I have charging system problem on my 2006 toyota rav4 4 cylinder,i check alternator and the is bad,so i replace my alternator,recharge my battery,start the car and the battery indicator light on,but my...
your battery could have a dead cell and still register 12 volts when not running,, if your getting 13.67 volts on the posts with the car running, the alt is fine,, but the battery is faulty,, take it and have it load checked, that way you can be sure it has the amperage that its supposed to have,
Sep 05, 2011 | 2006 Toyota RAV4
The battery in my JD lawn tractor was dead; it started and mowed several times with a jump start but eventually only the tractor would run while the mower would not engage. With a new battery installed,...
I suspect that the alternator/generator has gone bad, preventing the battery from chargine, or generating enough voltage to keep the electric pto on your mower engaged.
I think that it is located on the engine beneath the flywheel.
I hope this helps you.
Aug 03, 2011 | John Deere Garden
Troy Bilt Lawn Tractor Will Not Start
check connections on the battery let me know thanks wade
Jul 04, 2009 | Garden
Lawnmower won't start up
I have the EXACT same problem with my mower. I called the Black & Decker number listed above, and learned that the mower is under recall for this problem. So call them and find out where the nearest dealer is, and they will fix it for free.
May 27, 2009 | Black & Decker 19" Electric Lawnhog...
Garden Logo
116 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
