Question about Dell UltraSharp 1908FP Monitor
Unable to ajust resolution
My referbished dell computer is running the XP program. But it is only allowing me to set up resolution to 640 by 480 pixlels 4 bit. how do i go about seting the computer to a higher resolution? this is the only resolution it allows.
  • 2,567 Answers
You need to install the drivers for your graphics card first to be able to set the resolution to higher than 640x480 with more than 4-bit color depth.
You can find the drivers on the CD/DVD disc included with your PC, or you can download it from Dell's web site.
Posted on Jul 19, 2009
    Novelist:
  • 117 Answers
You need to update the drivers for your vga card. once you do that you can select your resolution. go to dell's website and put in the model of your computer they will provide you a support page link that you can download your correct video drivers for your operating system. once you do that, you are good!
Good Luck!
Ruben
I want my monitor to work once again because it says cannot display video mode? i dont understand help me?
You didn't say which OS you're running. However, it looks like you need to restart your computer in safe mode. This URL explains how to get in safe mode. When the computer boots the video it will look a bit grainy and you won't be able to see the entire desktop without using the scroll bars.
Both XP and Vista don't allow you to perform such an operation through the regular procedure and, as a result, you will only be able to get a screen resolution of 800×600 with the consequence that some icons and programs won't be displayed correctly. This is because Safe Mode just loads only basic services and drivers which are strictly necessary for Windows to run.
Fortunately, by employing the following techniques, you can get around this restriction permitting you to get whatever screen resolution you want.
Windows XP:
  1. Right click on your desktop.
  2. Click Properties.
  3. Click the Settings tab.
  4. Under Screen Resolution, drag the pointer to the right (where higher resolutions are located).
  5. Click Advanced.
  6. On the new window click OK, without modifying anything.
  7. Done, you should have successfully changed the resolution settings.
Windows Vista:
  2. Click Personalize.
  3. Click Display Settings.
  4. Under Resolution, drag the pointer to the right (where higher resolutions are located).
  5. Click Advanced Settings.
  7. Done, you should have successfully change the resolution settings.
Aug 11, 2011 | Dell 1503FP 15" LCD Monitor
How do you change fontz size on dell computer
  1. Change your screen resolution.
    • 1 Right click on the desktop and choose "Properties" (XP) or "Personalize" (Vista.).
    • 2 In XP click on the "Settings tab, and in Vista click on "Display Settings."
    • 3 Adjust the resolution slider to the right or left (right will set a higher resolution, left lower resolution) and then click "Apply." The screen will change to the new resolution.
    • 4 Click "Yes" to accept the changes.
    Alter the text size in the program you are running.
    • 1 Alter the text size in the program you are running. Many programs have their own font-size settings that can often be altered in a view, settings or options menu.
    • 2 Look for an option to change font size or zoom. Often you can click on a "View" menu and then click "Zoom."
    • 3 Zoom to the required size. (For many programs, you can hold down the "control" key and then use the mouse wheel to automatically zoom in and out.)
    Alter your computer's DPI scale setting in Vista.
    • 1 Right click your desktop.
    • 2 Select "Personalize" then "Adjust font size (DPI)," then "Custom DPI."
    • 3 Enter a number between 100% and 500% (higher numbers mean larger text).
    • 4 Click"OK."
    • 5 Click "Apply."
    • 6 Restart your computer.
    Alter your computer's DPI scale setting in XP.
    • 2 Select "Properties," "Settings," "Advanced."
    • 3 Click on the DPI setting you want to use in the drop-down list or select "Custom DPI Setting (other)" and enter your own number.
    • 4 Click "Apply" and restart your computer.
Jul 09, 2011 | Dell Inspiron 530s Desktop Computer
It wont install on windows xp
Trying installing the game in compatibility mode by right clicking on the EXE file on the medium used to start the install for the game and click properties. A window should pop up with a tab called Compatibility. Under compatibility mode click the check box to "Run this program in compatibility mode for:" In the drop down menu click Windows 95. Then try to run the install again.
Mar 16, 2011 | Capstone Software Trump Castle 3 for...
I recently reinstalled my windows XP program and added the Dell E173FPc. At the beginning it work perfectly. I then downloaded all the XP updates and restarted several times. I now have a terrible...
Have you tried setting the resolution using display settings in control panel?
Go to control panel search for display. There you will find option to select monitor and resolution.
Oct 01, 2017 | Dell E173FPc 17" TFT LCD Flat Panel...
Frequency out of range
First of all press F8 key several times before window boots and then select last known good configuration otherwise go in safemode and then set the screen resolution to minimum.
Jul 28, 2010 | Gateway 838GM (RB838GM) PC Desktop
I have a cracked screet with my my dell inspirion 1501 when i try to set it up with a dell flat screen monitor it flickers but does not recognize it and does not work.
go to your computer control panel & chec your resolutions pixels, or your hardware and sound to ajust your mobility setting.
Jun 29, 2010 | Dell Inspiron 1501 Notebook
I have a Dell Dimension 2400 with windows xp. I was having some problems and decided to reinstall xp. After the install, my resolution was set at 480 x 640, everything was big on the screen so I went into...
install windows xp after that open link and download driver and install driver and enjoy .....
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&os=WW1&osl=en&catid=&impid=&SystemID=DIM_PNT_P4_CEL_2400
Oct 14, 2009 | Dell Dimension 2400 PC Desktop
I use Microsoft XP and I use a 24" Samsung widescreen monitor. Is there any way I can get my programs to fill the screen without stretching and distorting. I have a friend who has a Dell widescreen...
Its probably your screen resolution, you probably want it set to something with a 16:9 or 16:10 ratio so 1280x768 or 1280x960 or if you are like me and like lots of real estate 1920x1200
Sep 09, 2009 | Computers & Internet
I've got the good resolution on my screen, accidentaly i deleted a program and my screen resolution turned awful. can anybody help me with that?
What program did you delete? It may have been the drivers for your video card. For future reference, you should not "delete" or uninstall any program unless you are sure of it's function.
Now to resolve your resolution problem, in XP simply right click on your desktop select Properties>Settings tab. Ajust the resolution to the desired level. If a desirable resolution is not available, you may need to update the driver for your video card.
If you need to update the driver for your card, just post back on this thread.
May 10, 2008 | Computers & Internet
Dell UltraSharp 1908FP Monitor Logo
137 people viewed this question
Alun Cox
