Hello, Installed new hard drive which is a clone of previous one. Previous drive worked OK, but was very old. Now, on start-up, the computer hangs during boot and askes me to choose F2 or F12. I then have to hit F1 to continue boot process whichfollows througjh OK. ALso, since this problem I get a lot of screen freeze-up on internet and a few on other programs as well. That never used to happen. Can you help?
  • 13,433 Answers
I recommend you start fresh, do a new installation of windows, or use the recovery cd's that came with the machine Or the windows installation cd.
About the other problem, whats the full error message and other details that you see on the screen?
Posted on Jul 19, 2009
Recovery discs won't install windows on new hard drive
sad to say but probably have to buy a new operating system disk .
May 13, 2015 | HP Computers & Internet
Hp designjet t1100 blank hard drive installation
Unfortunately I had a similar issue with an HP A0 printer. The Hp 'Engineer' could not fix it. The hard drive had failed and there is a complete new hard drive with software loaded available but only through Hp.
Feb 27, 2014 | HP Designjet T1100ps Printer
Operating System Requirements
No Problem
Always do a full backup before updating your Mac OSX. Use Carbon Copy Cloner to make a bootable "Clone" of your current Hard Disk. Once the clone is done... Boot from the clone. (Hold Option Key down at Startup and choose external HardDrive with new clone OSX)
Verify that this clone Boots & has all of your current data.
Use the "Mac Tracker" App on the Mac or iPhone to see what the maximum OSX system your model can handle. (Makes no sense in installing just OSX10.5 if you can go to say OSX10.7
Download a copy of the MacOSX 10.5.8 installer DVD (Saved as a .DMG file here Fenopy.se (Search for OSX 10.5). OR OSX10.9 (free download) if your Mac can run on this latest OSX.
Burn your OSX Install software to DVD. Use Disk Utility with your .DMG (Disk Image) File and select the .dmg from the LH Side menu to burn to DVD.
Once burned, try booting from the DVD. If that works OK then you are ready to go. BUT not quite yet.
You really don't want to install a new clean system over top of your existing system. This would be like a Band Aid Fix.
(This is where you must have your current existing system cloned to an external hard drive. Just like i mentioned above.)
Because, now you will start up or "boot" your computer from the DVD installer disk you just made. You will find the Disk Utility tool in the top menu. Use this to FORMAT your internal Hard Drive. (Dont Have your External Drives connected at this time... for safety.)
Choose ERASE or Partition and Select "Mac OS Extended (Journaled)" as the format type.
This process only takes a few minutes. If you have more time you can select the Security Option (choose fastest or single pass) then hit erase button. The security option in this case is only used to write "ones" to every sector on the disk thereby thoroughly testing the drive. This happens to be the ideal time to make sure you have a good flawless internal hard drive. Peace of Mind for older Macs.
Once completed, your drive is totally empty, you have lost everything unless you have made a "clone" beforehand.
Now you can run the installer and leave that process to complete for half an hour or so.
When installer has finished the Mac should reboot itself (you will hear install Jingle), with the new clean OSX installed. You can then manually answer all the questions if you want and give it your Network passwords etc. OR You can select Migration Assistant and migrate all your previous files & settings automatically from that external drive "clone" you made earlier.
You should now have almost a brand new clean Mac to install your new scanner software on.
Also... if you only installed say OSX10.5.0 then you will have updates to download on line, then install, to bring your Mac up to 10.5.8
I run this process on my Mac's at least once a year so that I always have a clean OSX with defragged hard drive so I can work reliably for the next few months. If not... I still have my "Clone" to boot from.
By the way Apple's latest systems since 10.7 (I Think) have an emergency boot partition automatically installed by the installer software. You just re boot & hold the OPTION KEY down and you are given the choice of booting from this bare minimum emergency system. It is heavily limited as to it's functionality but Disk Utility is there to look for problems.)
Good Luck
Feb 21, 2014 | Apple Mac OS X v10.5 Leopard
How to change the hard drive that contains the operational system in an Acer EasyStore H341 server?
Transfer an Operating System to a New Hard Drive
When replacing an old hard drive, a process known as cloning is the easiest and most thorough method for transferring data between the old and new hard drives.
A cloning utility takes a snapshot of your current hard drive and then re-creates that snapshot on your new hard drive.
The process clones everything, including the operating system, installed applications, settings and personal files.
Create a system restore disk so that you can return your system to its previous condition if an error occurs.
You can use a backup and restore utility provided with your operating system, or find one for free or for purchase on the Internet.
Many cloning utilities can also create system restore disks.
Shut down the computer and remove power.
Physically install the new hard drive.
Restore power and boot up the computer.
Ensure that your operating system recognizes that the new hard drive has been installed.
Pick the cloning utility that works best for you. (See Below for some options.)
http://www.easeus.com/disk-copy
http://www.clonezilla.org/
http://www.runtime.org/driveimage-xml.htm
All freeware
http://www.acronis.com/homecomputing/products/trueimage
http://www.symantec.com/norton/ghost
Purchase
Base your decision on your operating system and the cost and complexity of the utility.
Install and launch the cloning utility on your old hard drive.
Follow the instructions included with the cloning utility.
Keep the old hard drive as a backup, or reformat it for additional storage space.
Cloning a Notebook Hard Drive
Pick the cloning utility that best fits your needs. (See Above for some options.)
Base your decision on your operating system, the cost and complexity of the utility, and whether the utility can clone notebook hard drives using bootable media, such as CD-ROMs, DVD-ROMs or flash drives.
Keep the old drive as a backup in case the new hard drive fails.
or
Copy an OS to Another Hard Drive
Copying an OS or operating system to another hard drive can serve several functions.
Some simply want to move their current operating environment to a new PC, while others are replacing an old system hard drive with a newer one and want to avoid the hassle of updating and reinstalling.
The process of copying your operating system to another hard drive is a very easy one, in fact, and can be accomplished by anyone with nothing more than some software and some time.
Install Acronis True Image and launch it from its installation icon.
A link is provided below for the Acronis free 15-day trial.
http://www.acronis.com/homecomputing/download/trueimage/
http://www.feyrer.de/g4u/
Support free software or g4u WILL die!
http://www.macrium.com/reflectfree.asp
Macrium has a free also pay options
Click the "Utilities" button from the left menu bar.
Click the "Clone Disk" button from the right pane of the main program window.
This will cause a dialog box to appear.
Click the "Next" button on the bottom-right corner of the dialog box.
Select the disk with the operating system you wish to copy from the drive list and click the "Next" button.
This will begin an examination of your hard disk that will finish in a few minutes.
Select the destination disk from the hard drive list and click the "Next" button.
Choose the "As-is" option for how you would like to handle your partitions.
This option merely lets you decide whether to keep all partitions on the drive or copy just the data onto one blank partition on the new drive.
Click the "Finish" button, and Acronis will prompt you that your system needs to be restarted to begin the cloning process.
The restart will happen automatically when you click the "Finish" button.
Allow the computer to restart, and Acronis will launch prior to the operating system and begin the cloning procedure.
This process may take several minutes to several hours, depending on the size of the operating system and whether there are any installed applications.
Restart you computer once again after Acronis has completed the cloning procedure.
The software will notify you when the cloning has finished.
Boot into your operating system and use your new operating system installation as normal. You may now remove your old operating system drive or format it as you desire.
Hope this helps.
Nov 24, 2012 | Computers & Internet
Can a old 3gbs 1.5 terrabyte western digital hdd be cloned to a new 6gbs ssd
not sure exactly what you are referring to
there are ways of cloning an entire disk to another disk or copy the contents of a hard drive to another hard drive
How to Copy Contents of One Hard Drive to Another
There can be several reasons for needing to copy data from one hard drive to another; for instance, if you are migrating data to a new computer or hard drive or if you just want to make sure you have a working backup.
The simplest method is to just drag and drop the contents from one hard drive to the other. But this method will not work well for copying complicated things like operating systems.
To do that, you need to use a hard-drive cloning program.
The cloning program will copy your old hard, in its entirety, to your new hard drive.
Connect both drives to your computer.
This can be done by installing them both inside the tower or by connecting them via USB external enclosures.
Open your operating system's file explorer utility. Select the hard drive you wish to copy. Highlight all of the contents of the hard drive.
Drag and drop the highlighted files to your back up hard drive.
Allow the files to copy over to the new drive. Depending on the amount of data you are copying, the process could take a couple of hours.
Clone the Hard Drive
Download and install one of the many programs that will allow you to clone a hard drive. Cloning a drive makes an exact copy of the drive on your new drive.
It's the only way to accurately back up operating systems, as none of the data is rearranged at all during the cloning process.
Connect both drives to your computer, either by installing them or connecting them via USB external enclosures.
Open your cloning program. Select the "Clone Disk" function.
Choose the drive you wish to clone and the destination drive for the data and start the program.
Do not do anything else on your computer while the drive is being cloned, as it will change the data on the drive and disrupt the process.
Cloning a drive can take a few hours.
Once it is done, you will have an identical copy of the old drive on your new drive.
hope this helps
http://download.cnet.com/easeus-disk-copy-home/3000-2242_4-10867157.html
Copy and backup hard disks and partitions sector to sector. freeware
http://download.cnet.com/easeus-todo-backup-free/3000-2242_4-10964460.html
Back up and restore photos, music, videos, documents, hard disk and partition.freeware
How to Copy My Operating System to a New Hard Drive
Install the new hard drive into the computer.
Power down the computer completely.
Remove the power cords, the monitor and any peripheral devices.
Unscrew, pop off or slide off the computer case.
Touch the computer chassis
Connect the appropriate cables to the back of the hard drive.
SATA drives take a SATA power cable; IDE (ATA) drives take a power cable and ribbon cable.
If you are unsure of what type of drive you have, consult your manual.
Slide the new drive into an available drive bay, then screw the drive into place.
Make sure all of the cables are secure, then put the case back on the computer.
Connect the power cords, the monitor, and any necessary peripherals.
Power on the computer.
Format and configure the drive as per detailed in the drive's manual.
This process will vary from manufacturer to manufacturer.
Boot to the main drive (the drive with the OS on it).
Download and install a disk cloning software
http://www.downloadcollection.com/lazesoft_disk_image___clone_home.htm
http://download.cnet.com/miniaide-fat32-formatter/3000-2094_4-75701815.html
both freeware
Select your "Source" drive, as well as any partitions.
Your source drive is the drive containing the OS you want to copy.
Check the hard drive data located to verify that you are selecting the appropriate drive.
Select the "Destination" drive, as well as any partitions.
Your destination drive is where your source drive's files will be copied to.
Click "Next." Confirm that your selections are correct. Click "Next" again.
Review the task summary.
If everything is correct, click "Run Now."
Allow the disk cloning software to perform the cloning process.
Do not turn off the computer during this process.
When the cloning process has completed, right-click "Start," then click "Explorer."
Click the destination drive and make sure all of the files have properly transferred over.
hope this helps
Oct 12, 2012 | Apricorn DriveWire IDE/PATA/SATA to USB...
Transfer data and operating system from one hard drive to another
Use AOMEI Partition Assistant,a free Windows partition software, to clone data or OS from one hard drive to another. http://www.disk-partition.com/copy-disk-partition-wizard.html
Oct 12, 2012 | Hitachi TravelStar Computers & Internet
MSI P965 Pt Continually re-boots on start-up
You don't say exactly at what point in the boot sequence the system crashed and restarts. Many things could be at work here. You say you are using the HDD from the previous system. Did you swap this drive straight out and are still using the OS load from the previous system? Windows loads drivers at startup based upon the hardware installed. If you are using and old WIndows load with a new mainboard, this could be the entire cause of your crashes. YOu may be able to get to SAGE mode and remove the old drivers and try to restart the system, but from experience I will tell you that to get the best results when installing a new mainboard, you should reload the OS from the original OS disk, and then load the new mainboard drivers.
Dec 31, 2011 | MSI P965 Platinum Motherboard
I just upgrade to Win 7. Now everytime when powering up the machine, there are two boot options like this: Previous Windows Operation System Windows 7 (with Windows 7 highlighted) Of course I...
If I understand you correctly you had a previous operating system installed on one hard drive and you just now installed Windows 7 but on a separate drive? When you boot the machine if gives you two boot options, the old OS and the NEW OS?
What your going to have to do is format the drive(erase) that contains the old operating system. Format as NTFS.
Try unplugging the old drive, making sure the new drive is set to master and not slave. Boot up the computer.
When you boot up your computer you should immediately get options. One of these options should say "press delete for bios" or press "f6 for settings" You need to go into the bios and make sure the drive with Windows 7 is set to your primary drive in the boot order(hard drive should be first in boot list). We want the computer to boot to the new drive first.
Once you get into Windows you can use a program like partition magic to format the old drive to use as just storage space. You can even use "diskpart' which is an old windows command line utility.
If you reinsert the Windows Disk when you are booting up you will get some recovery options, and if I recall correctly one of these should let you format hard drive space. So, you may be able to do it from there.
Where exactly does the error come up in the boot process? Are you able to boot into safe mode? It may be easier for you to just reinstall Windows 7. If you boot the computer with the disk in the drive, and the BIOS set to boot first to the disk, then during the installation configuration you should be able to have Windows just format the old drive to use as space and install the MBR on the new drive.
-G33k
Jun 11, 2011 | Microsoft Windows 7 Ultimate for PC
Hi, My previous computer died and I have tried to
you need then to "boot" in the second HD to TRY to look at those files.At start up press F12 and chhose the HD.
Oct 12, 2010 | Western Digital Caviar SE WD2500JS...
Will cloned Hard drive work with new MoBo and CPU
No, it's not true, but you will need to buy Partition Magic to clone the smaller drive onto the larger one.
The new MoBo and CPU might give you more trouble though. All of the windows drivers for the old MoBo will be confused when they see all new hardware. In the olden (WinNT) days, this rarely worked. Now in the WinXP SP3/Vista days, you'll probably be just fine.
Sep 01, 2009 | Seagate Barracuda 7200.9 500 GB ATA-100...
k24674
