Question about HP NB199UA Pavilion Notebook
Gaming issue! fps drops significantly in game!
Hey all!
*System Info*____________________________________________
OS Name: Vista home prem. SP1
System Model: HP Pavilion dv4-1225dx _entertainment Notebook PC
Processor: AMD Turion(tm) X2 Dual-Core mobile RM-72, 2100 Mhz.
Total Physical memory: 4.00 GB
Available virutal memory: 5.99 GB
HDD memory: 230 GB total
My issue is the frames per second drop from 40-55 fps to 4-13 fps. I've noticed that this happens when my lap top heats up. the processor uses up to bout 80 percent as the fan runs constistently runs. NOTE i already have a docking station to put the lap top on top of. . the kind that keeps your computer running cool. please post if you know any solutions.. thank you.
Vista Home Prem 64-Bit/32-Bit w SP1 Damaged
Gotta ask if it is the same exact Operating System. If it is, then there should be no problem. However, if you have upgraded, it will not work.
Jul 03, 2013 | Gateway FX7026 PC Desktop
Fps drops from 2 to 5 seconds while gaming
if you have installled the game the virus may be cd.just opt for an antivirus.
Feb 08, 2013 | Acer Aspire 5742G
Pro tools m-powered problem
You may need to check to see which "service pack" you are currently on.
See below requirements:
System Software — Windows XP & Vista
  • Windows Vista Business or Ultimate Edition
    • 32-bit OS Installation Only
  • Windows XP Professional or Home Edition
    • With Windows XP Service Pack 2 or Service Pack 3
  • Not Supported:
    • Windows Vista 64-bit (any version)
    • Windows XP Professional x64 Edition
    • Windows XP Media Center Edition
    • Windows 98, Me, 2000, NT, 95, 3.1, DOS
  • Not Tested:
    • Windows Vista Home and Home Premium Edition
    • Although Windows Vista Home and Home Premium Edition have not been tested or qualified by Digidesign, there are currently no known issues with Vista Home and Home Premium 32-bit operating systems and Pro Tools M-Powered 7.4 compared to the supported Windows Vista Business or Ultimate Edition operating systems.
Windows Vista SP1
There are currently no known issues with Service Pack 1 for Windows Vista based on our initial limited testing and customer feedback. Although full qualification with all Digidesign products has not been completed, we do not recommend against updating to SP1, given the number of important overall system fixes in SP1. We do recommend that you backup your system and create a restore point before updating to SP1, should you encounter any problems after installing the update.
Sep 21, 2009 | Computers & Internet
Marine sharpshooter 2 will not run on vista home prem even in compatibility mode for xp sp2
You can try running the program as administrator and if that doesn't work then the game is not compatible for the OS you are running.
Jun 05, 2009 | Groove Games Marine Sharpshooter 2 :...
Flight sim gaming joystick for vista home prem
Personally I went for the logitech force 3D, it works brilliantly with flight sim X
May 29, 2009 | Microsoft SideWinder Precision Pro 2.0...
Low frames per second while gaming
The FPS in your games is primarily controlled by your graphics card. The better the card the better the fps. To get the best possible fps in gaming you should be using a good quality card like the NVidia GTX 260 card or better or an ATI Radeon 4870 or better. If you have the money you might want to upgrade. If not try turning off all but your essential background processes & see if that helps. Good luck.
May 09, 2009 | Computers & Internet
Visiontek hd 2400 pro game graphic lag
most computers systems have certain drivers configuration setups for certain games so you dont have that problem.
control panel, open up personazation,open display setting, find advance setting, open the folder that matches the type of graphics card you are using.
open the control center
3d settings
game setting
display options
avivo tm video
power players
graphics: hardware & software options
rod
Feb 26, 2009 | VisionTek ATI RADEON HD2400 Pro Edition...
Would like help with what the optimal gaming settings are
Got free help somewhere else and problem solved
Nov 11, 2008 | Computers & Internet
Another computer
Hi again,
For your posted gaming requirement, the Gateway M-1625 looks like more than sufficient. I am of the opinion that the advantages of DDR3 over DDR2 would not be significant with the games you have in mind. Additionally, Dual Core 2GHz AMD, 256MB memory on the ATI RADEON X1270 and 2Gb memory would of course make most current games happy. However, as stated in your other post, my concern is the the Vista OS which has been known to have so much memory issues which may affect the gaming performance of the machine. Perhaps a way to circumvent this is to upgrade to 4Gb memory. I would not suggest downgrading to XP due to unavailability of compatible drivers.
May 12, 2008 | Computers & Internet
HP NB199UA Pavilion Notebook Logo
230 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
