Question about RIM BlackBerry Pearl 8130 Cellular Phone
Blackberry pearl radio keeps turning off every 3 minutes sometimes sooner sometimes longer but i cant even ever make a phone call without it turning off at all.
I have a Blackberry Pearl 8130, the mobile network shuts off by itself. When it try to provision, the phone states that the radio is shut off. How do I fix this problem so the radio stays on all the...
This is unfortunately a known issue with the Pearl. There are a couple reasons to why this happens. If your battery is defective, then your phone will sporadically believe that your phone is low on battery (even when its not), this will cause your phone to kick the radio off by itself--even every 5 minutes. Try cleaning the battery contacts or even try a new battery. Another reason is a faulty OS, if the battery replacement doesn't work, then the problem is with your OS and will have to be re-installed. I know this sounds like a hassle, but its a known issue and it should take care of your problems.
Below is the procedure :
http://crackberry.com/blackberry-101-lecture-12-how-reload-operating-system-nuked-blackberry
This would be a long procedure.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 12, 2011 | RIM BlackBerry Pearl 8100
Radio keeps turning off on pearl 8130 tryed battery reset but still turning off like every minute or less
This is a device issue. You will need to contact your service provider for replacement options!
Mar 06, 2010 | Verizon Communications BlackBerry Pearl...
Blackberry pearl 8130 flashed to cricket wont connect to internet
You can call cricket and ask them to "refresh" your internet, wait 5 minutes and try again. Worked for me.
Aug 26, 2009 | RIM BlackBerry Pearl 8130 Cellular Phone
My blackberry pearl trackball doesnt work
Take it where you bought it and try to get it replaced, saying it's defective. Hopefully you're under warranty, unlike myself who has a **** blackberry who's radio keeps turning off randomly and won't make or recieve calls without having to manually reconnect 'mobile network' hundreds of times a day. Your phone must have got really wet though because buttons and **** don't ******* unless exposed to extremly wet conditions (trust me, I know). I'd like an iphone over this **** for damn sure but i'm stuck with any annoying and fairly useless phone for now.
Aug 03, 2009 | RIM BlackBerry Pearl 8130 Cellular Phone
Radio keeps shutting off
When there is no signal around ur blackberry will shut off the radio instead of constantly searching for one which really kills battery power just make sure you arent in a real signal dead area and you should be fine to turn it back on just go to manage connections and click it back on,if this is not the problem then there might be some problem with ur phone.
Jul 12, 2009 | RIM BlackBerry Pearl 8130 Cellular Phone
Multiple Blackberry problems on the same phone! Please help!
I think the easiest way to resolve as many of these issues is by resetting your blackberry.
Hold down ALT+RIGHT SHIFT(CAP)+DELETE keys - I'm not 100% sure this works on your model but it is soft reset.
Go into Options, then select Security Options, then select General Settings, then activate the BlackBerry menu and select the option to wipe the device - Will reset all your personalised settings to default
Jun 01, 2009 | RIM BlackBerry Pearl 8100
Cant call out on my black berry pearl
I have a blackberry pearl that i can no longer call out on.. i dial the number, press the talk button and all i get is tone sort of like a siren sound. how can i fix this??
Apr 28, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
Phone won't turn back on
No. There are some sellers on ebay which sell you a kit to clean up water damage on your cell or BB, but it's super hard to do without breaking the device. Even with instructions, it requires you take everything apart etc.. And its like $40-50 for the kit.
Sometimes you get lucky and up to 3 weeks later the device will dry out and work, and I've had some work the next day.. but only about 33% of the time do they come back at all...
Mar 22, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
Taking a long time to load
If this is your blackberry they do take longer than normal to start. Think of it as a small computer it needs time to boot up.
If it is doing this for longer than 3 minutes or forever than remove battery from phone and reseat sim cards memory card etc.
Jan 20, 2009 | RIM BlackBerry Pearl 8100
RIM BlackBerry Pearl 8130 Cellular Phone Logo
1,612 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
