Question about Philips 42MF231D 42 in. Plasma Television
I have a 42mf231d/37. the power goes on, you can hear sound, but no picture.Also there is a funny burning smell that comes from the circut board on the left hand side of the tv when looking at the back of it. Any ideas?
    President:
  • 1,077 Answers
Most likely the TV has a power supply related problem. It's possible that it maybe a bad capacitor or transformer on the power supply board. The most common board to go bad is the Backlight Inverter Board. That part supplies power to the screen. But, I can't say it's 100% the problem because I can't actually look at the tv over the internet. I can only make guesses with the symptoms.
You have a few choices:
1. You can try leaving the TV unplugged for 30 - 45 minutes so the TV can discharge and reset itself.
2. If by chance the TV is still under warranty, go that route.
3. If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists.Usually, cost under $20. And most cases the new part cost less than $15.
4. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
I hope I shed some light on the subject for you.
Posted on Jul 19, 2009
My Magnavox 42MF231D/37 TV has no picture
Call Magna vox tech support. Sounds like you need a new set. They may have you factory reset the set.
Feb 20, 2015 | Magnavox Televison & Video
No picture and burning smell from left side
Bad COF ic on buffer board. Can usually tell which one's bad. It will look overheated or a hole in top of ic. Look at upper and lower buffer boards to see which ic is bad. Can get from Encompas Parts, Recommended replace y sustain with buffer.
Nov 26, 2011 | SNK Magnavox 42MF231D 42 in. Plasma TV
I bought philips model no. 47pfl7403d/27 in 2008 .Suddenly last month it started skipping picture but we could hear sound.After few days it started smelling like something is burning and it stopped...
Seal deal w/ ours. I took it apart and the power supply board had the burn marks on it. Just ordered another power supply board (pn: 272217100571) for ~ $100. TV back panel comes off fairly easily to get at boards.
Jun 14, 2011 | Philips 47PFL7403D 47 in. LCD TV
I have a 37" Philips (37PF9431D/37) flat panel tv. It won't power on. When you plug it in you can hear a click the green light stays on for a few seconds then goes out. I've checked the power board for bad...
i am having the same problem. My Phillips 37" 37PF9431D/37I LCD High Definition TV won;t turn on. When I press the power button i hear a click and the green light comes on for a couple of seconds and then the red light appears. I can;t figure it out. Did you find a solution?
May 20, 2010 | Philips 37PF7320A 37 in. HD-Ready LCD...
Magnavox 42mf231d/37 - no picture
Common problem on this tv, ceramic capacitor beside horizontal transistor.Need be Replace . 561K 2KV
Aug 06, 2009 | Philips Magnavox 27MS343S 27" TV
TV on, sizzling sound, smell smoke, picture goes out but TV still on
It could be any number of components on the main board/power board which could be frying..But if you are hearing a sizzling sound, it could be something probably like a capacitor or the board itself. Difficult to say unless it is opened. First thing, though, is unplug the TV from the mains as a precaution against fire.
Since you are a technical guy, it shouldn't take you long to figure out what the components are thats burning. However, if your TV is under warranty, I advise against opening up the set as that will void your warranty. However, if its not under warranty, go ahead and open up the set and see what components need replacement, or replace the whole power board itself (if you are comfortable with electronic soldering/desoldering).
Cheers!
IrishDruid
May 10, 2008 | Protron PLTV3250 32 in. LCD Television
ProScan PS32500 32"-Picture has white static line & Static/burning smell
It sounds like the circuit board is arching over somewhere. It could be as simply as cleaning and digging out the carbon mark to stop the arching. This is most likely the screen or focus voltage causing this, if there are no parts that have broken down. This will damage the printed circuit board and make things worse the more you let this cook. This could be dangerous for you to mess with because of the high voltage present, so my best advise would be to get this into the repair shop as soon as possible before this board burns up. It should not cost all that much if the CRT board can be repaired. Good Luck
Mar 21, 2007 | Proscan PS32500 32" TV
Philips 42MF231D 42 in. Plasma Television Logo
489 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
