Parks Optical 13.5hp Briggs And Stratton Intek Lawn Mower Engine
Problem for Parks Optical 13.5hp Briggs And Stratton Intek Lawn Mower...
13.5 OHV B&S won't stay running, blows gas out carb.
By wuchen_pa on Jul 19, 2009
I just bought this riding mower, used (mistake #1) from an individual (mistake #2) and paid too much (mistake #3).. I ran it once, it seemed to work well enough. two weeks later, it started out fine and after about 20 minutes, blew a huge blue/white smoke out of the exhaust and no longer developed any power. I looked at the mower while the air cleaner was off and trying to keep it running with the choke mostly closed, it is VERY load pulsing noise from the carb and blowing gas out of the carb. It wont stay running like this long, even manually working the choke and gas feed. The seller has vanished. I bought this mower, because my Toro needed $400 in repairs, muffler and a new sump ?? says the mower shop. This used mower cost $500, thought I was better off :-( Well, now I have two broken mowers and very tall grass! Help!! What could it be? Something repairable?
Best Solution
posted on Jul 19, 2009
Very Helpful)
trhoadar
Rank: Master
Rating: 95%, 14 votes
Sounds like you have a blown valve. I'm assuming this is a 4 stroke motor, if it was 2 stroke then it would be the reed valves. But either way it's the valves.... unfortunately that will require a mechanic :(
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #2
posted on Aug 03, 2009
Somewhat Helpful)
Ken Poling
Rank: Apprentice
Rating: 92%, 3 votes
Question? Were you mowing on a steep incline when the white smoke developed? If you were, you may have had the oil level a little high and it got excess oil momentarily in the cylinder. The Spark plug may be just foweled, clean it or replace it and it might run O.K.
>KP
Was this helpful?
Yes
No
Popular Solutions for Parks Optical 13.5hp Briggs
Questions and Unsolved Problems for Parks Optical 13.5hp Briggs
Do you recommend Parks Optical 13.5hp Briggs And Stratton Intek Lawn Mower Engine?
Answer
Answer
I need an owners/parts manual to this machine. ariens Sno Thro 10m5. I think it is the 10m5, it has... (More)
Answer
We can cut grass for about 45min then the tractor begins to sputter and stall. Withthe blades... (More)
Answer
B&S 13.5hp Intek (Husqvarna);easy to start - works well by cold -BUT by warm engine starts... (More)
Describe your Power Lawn Mowers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Power Lawn Mower Experts
Top Garden & Power Tool Repairmen
(800) 937-7279
Replacement lawn mower and snow blower parts from...
Commercial Parts Warehouse
(509) 678-4379
Precise Engine Repair proudly represents Briggs...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
