Question about Sony CDX-F5510 CD Player
CDX F5510 upon installation, the head unit was live until we put a cd in and put the display back up, and then the stereo would not turn on.We've checked the fuses and the wiring, pressed the reset button etc
  • 33 Answers
Have you tried unplugging the unit for about 30 secs then trying again?
Posted on Nov 20, 2007
My Sony CDX-F5510 won't eject the CD. I have reset it but it still won't eject.
try disconnecting power to the radio for a few hours. if that doesn't work, it probably has to be repaired professionally.
Dec 06, 2010 | Sony CDX-F5510 CD Player
I have a 1998 Pioneer head unit to put in my car. the #is 1256237179. Is There anyway to get a diagram to see how to hook it up?
Well you can please follow the below steps -
1. Disconnect your car battery. It is vitally important to your safety that you never work on any type of electronic in your car with the battery still connected, as this puts you at risk for electrocution.
2. Remove the old stereo by taking off all the dashboard panels surrounding your stereo, sliding out your old stereo head unit, and unplugging all the wires that are connected to the head unit. Discard the old stereo.
3. Take your Pioneer car stereo head unit and plug each of the positive wires from your car speakers to the positive terminals on the head unit. Take all of the negative speaker wires and connect them to the negative terminals on the head unit.
4. Attach the stereo's black ground wire to a metal bolt or screw located near where the stereo is mounted in the dash.
5. Connect all of the ignition power wires to your Pioneer stereo.
6. Take the harness connector and plug it into your car stereo. Now plug the antenna into the back of your head unit.
7. Slide the stereo back into the dash, screw it in place, and replace the dashboard pieces you removed earlier.
8. Reconnect your car battery, turn the car on and test out your new Pioneer car stereo. Please post comments for more help or information..........
Good Luck!!
Thanks
Jan 16, 2010 | Sony CDX-F7710 Car Audio Stereo CD MP3...
I have power going to the unit yet there is no display,a sony cdx-gt220,i know i have power because it is loading and ejecting cds yet no display.please help,its doing my nut in!!!!
I have a Sony CDX GT 530U. I had a problem with no display and I thought no power period. I did not try to install a CD, so maybe I did have power to the CD motor but no display. This was frustrating because I could get the old factory Nissan radio to power up and work so I thought I had a dead Sony unit. After a lot of monkeying around, I discovered I had blown a fuse while installing the unit (you should disconnect the negative terminal of the battery when installing the radio... which I thought I skip, that was a no no.). I had checked the auto fuses, those cheap little plastic fuses behind a panel below the stearing column inside most cars, at least all the fuses I thought went to the car stereo. Turns out I missed one that was labeled "Batt" or something like that, which was the constant power wire to the car stereo. There was another fuse for the Accessory power to the car stereo (the main juice went the key is tuned to ACC or Start position). Turns out the Sony unit display runs off the constant power, or at least the unit on/off button runs off the constant power wire, so even though the ACC power wire was live, the Constant power wire had a blown fuse and the unit would not turn on. Check all your fuses inside the car, I bet that's your problem. Constant power on my Nissan Sentra was a 7.5A fuse, while the ACC power ran off a 15A fuse, but your vehicle may vary. Good luck.
Jul 16, 2009 | Sony Xplod Car Audio CDX-F7810 - CD/MP3...
When the car turns off the Sony CDX-F5510 AM/FM CD Player beeps.
yes if you are speaking of the beep go into menu settings where you afjust clock and such and turn off beep it is reminding you to remove the face..it is annoying
Nov 25, 2008 | Sony CDX-F5510 CD Player
CDX changer has power but doesn't want to eject after flat battery
i resolved this myself in the end.
I unplugged the audio & power cables whilst the stereo and engine was running.
Then plugged back in.
I turned the engine off and stereo off as well.
I then unplugged audio and power again from the back of the CDX, left it unplugged for 10 minutes whilst the engine was still off.
I then plugged the leads back in and turned the engine on. the stereo recognised the CDX, but stayed on displaying "CD Checking". I switched to radio for 20 seconds, turned back to CDX and it selected CD 1 and has been good ever since.
I'm rather pleased with myself!
Steve
May 13, 2008 | Sony CDX-T69 6-Disc CD Changer
Sony cd changer cdx-646...no card remote commander to release security code
Hi the CDX-646 is not coded. it must be your head unit thats coded.what model is the head unit?
you can get your code @ www.carradiocode.co.uk
for 33.50 if its one of the models listed you will nedd the remote comander tho.
Mark
www.blueice-electronics.co.uk
Feb 24, 2008 | Sony CDX-646 10-Disc CD Changer
Cdx-f5510
ok well listen to the radfio make sure its on tuner and wait for like thirty seconds then try to eject it while listening to the radio cuz mine is almost the same see if that works
Jan 22, 2008 | Sony CDX-F5510 CD Player
Speaker issues
Disconnect whatever wire is connected to the blue wire behind your head unit. Re-connect it to the blue/white wire, instead.
Jun 21, 2007 | Sony CDX-M770 CD Player
Sony CDX-F5510 CD Player Logo
85 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
