Question about Lands Phones
Problems with sound
I'm havin troubles with sound on the telephone. I lost ringer tone and also dialing tones. How can I turn on the sound again?
    Sniper:
  • 59 Answers
Check  your phone speaker contact probes
Posted on Jul 20, 2009
The visual ringer will not flashing.
At an educated guess sounds like dial tone is set to decadic if there are two phones the other phone will set off ringer when numbers dialed. May need to get phone provider to change dial mode in exchange line interface circuit to be Dual tone Multi Frequency Dialing and then switch phones to Tone dialing rather than pulse dialing.
Jun 01, 2015 | Lands Phones
Inoperative fax and telephone line
try connecting line 2 to a simple phone and chk for dial tone.
Sep 22, 2008 | Canon FAXPHONE L80 Laser
Have a V-Tech 6.0 phone CS6319 Series - Battery OK - turns on, but NO DIAL TONE. We do not have manual, Do not see anything like Mute On/Off in menu. All connectors and plugs are secure. Help?
First, does another phone get a dial tone at the jack in question? (I prefer an old corded phone for this test since it is unlikely to have some of the problems of a cordless.) Try a new phone cord between the base and the jack. If there is no dial tone, try the test phone at other jacks. If there is no dial tone at any jack with either phone, find where your telephone service comes in and open the service box. If you are lucky and have a fairly new connection, the service box will have RJ-11 jacks. Plug your test phone into the jack and check for dial tone. Otherwise you will need the phone company to do this test. If there is no dial tone at the service box, your phone company will fix the problem for you for free.
If your test phone works:
Make sure that the base is plugged into a working outlet (no tripped circuit breaker, turned off power strip). Next check that the handsets are registered with the base. To register the handset, press the Find HS button on the base (below the in use indicator) for 4 seconds, then press # on the handset. (Our cordless phones once lost their registration during an extended power outage.) You can force deregistration by pressing and holding Find HS for 10 seconds. The In Use light should come on and flash. Then release the Find HS button and then press and release it again while the In Use light is blinking. You may need to try unplugging the base after pressing Flash/Talk and then Off/Clear before deregistering the handsets. The register the handsets.
You can Mute the microphone on the handset with the Mute button. To silence the ringer, press Menu/Select when the handset is not in use. Use the up/down arrow keys to select Ringers then press Menu/Select. Then press Menu/Select to choose Ringer Volume. Use the up/down arrows to change the volume and then press Menu/Select to confirm and save the setting. This should not change the ability to hear the dial tone.
If your test phone works at the service connection but nowhere else, then you have a wiring problem inside. Check exposed wires if you have them. Your phone company will offer to fix the issue for a fee. If the problem is at one jack, open the faceplate and check for loose wires. Some faceplates use a keystone with a punch-down tool to secure the wires. Others just wrap the wire around a screw for each pin.
If the handsets are registered and the base has power, then the cordless phone has problems. If it is under warranty, have it fixed. Otherwise, replace it; they aren't made to be user serviced.
The manual is available here: http://www.vtechcanada.com/support_docs/vtt/CS/CS6319_en_cib.pdf .
I hope this helps.
Apr 22, 2011 | Cell Phones
I am having problems with my phone not ringing It sayes it is muted please help
make sure phone is off (no dial tone or caller) , then hit program it will say directory arrow down with the volume key until it says ringer tone. it give 4 options for ringer tones and off hit select (and choosing a ring tone)
Feb 13, 2011 | Vtech 9009111 Cordless Phone
No dial tone on handset. can't send or recieve fax.
? Other equipment, which uses the same phone line as the HP All-in-One,
might be causing the test to fail. To find out if other equipment is causing a
problem, disconnect everything from the phone line, and then run the test
again. If the Dial Tone Detection Test passes without the other equipment,
then one or more pieces of the equipment is causing problems; try adding
them back one at a time and rerunning the test each time, until you identify
which piece of equipment is causing the problem.
? Try connecting a working phone and phone cord to the telephone wall jack
that you are using for the HP All-in-One and check for a dial tone. If you do
not hear a dial tone, contact your telephone company and have them check
the line.
? Make sure you have correctly connected the HP All-in-One to the telephone
wall jack. Using the phone cord supplied in the box with the HP All-in-One,
connect one end to your telephone wall jack, then connect the other end to
the port labeled 1-LINE on the back of the HP All-in-One.
If the supplied phone cord is not long enough, you can extend it. For
information, see The phone cord that came with my HP All-in-One is not long
enough.
Check the connection between the telephone wall jack and the HP All-in-One
to make sure the phone cord is secure.
Make sure you use the phone cord that came with the HP All-in-One. If you
do not use the supplied phone cord to connect from the telephone wall jack
to the HP All-in-One, you might not be able to send or receive faxes. After
you plug in the phone cord that came with the HP All-in-One, run the fax test
again.
If you are using a phone splitter, this can cause faxing problems. (A splitter is
a two-cord connector that plugs into a telephone wall jack.) Try removing the
splitter and connecting the HP All-in-One directly to the telephone wall jack.
If your telephone system is not using a standard dial tone, such as some
PBX systems, this might cause the test to fail. This will not cause a problem
sending or receiving faxes. Try sending or receiving a test fax.
Check to make sure the country/region setting is set appropriately for your
country/region. If the country/region setting is not set or is set incorrectly, the
test might fail and you might have problems sending and receiving faxes.
Make sure you connect the HP All-in-One to an analog phone line or you will
not be able to send or receive faxes. To check if your phone line is digital,
connect a regular analog phone to the line and listen for a dial tone. If you do
not hear a normal sounding dial tone, it might be a phone line set up for
digital phones. Connect the HP All-in-One to an analog phone line and try
sending or receiving a fax.
again.
After you resolve any problems found, run the fax test again to make sure it
passes and the HP All-in-One is ready for faxing. If the Dial Tone Detection test
continues to fail, contact your telephone company and have them check the
phone line.
Dec 03, 2010 | HP Laserjet M1319F Laser Multifunction...
Not able to ring out or recieve calls on landline 01772465172
Is there a dial tone? Have you tried plugging in outside in the NID(phone box) on the side if the house. Take a corded telephone out to the box if it has a test port to plug into. If it does, plug in. If you have a dialtone, then the problems inside with either the station wires or jacks, or other equipment that is plugged into the jacks. Remove all devises from the jacks if trouble is inside and take a known working phone and plug it into a jack. if it works, plug in another device, so on and so on. Be sure to check dial tone, break dial tone by pressing a button. Hang phone up and see if dial tone has returned. If not, then that piece of equipment is bad.
If no dial tone at the NID, then call in a trouble report of NO DIAL TONE to the telephone company of cable provider. To save money if trouble is inside, purchase the inside wiring maintenance plan and then have them come work on the phone lines. After the service is restored, call and cancel the maintenance. $5 and you're back in service, provided that's all the teleco charges for wiring maintenance.
Nov 30, 2010 | Lands Phones
The ringer is off and I don't know hoe to turn it on
I have two uniden phones 2.4 GHz and the ringer is turned off and we cannot figure out how to turn it back on again. Please help!!!
May 18, 2009 | Uniden TRU4485-2 Cordless Phone
I need to retrieve my home phone messages from cell phone
Activating Call Forwarding
You can activate Call Forwarding whenever you want your calls to be sent to another phone, including a mobile phone. Once activated, all your calls will be sent to the forwarding number you request. Each time a call is forwarded, you will hear one short reminder tone on your home phone, but you will not be able to answer the call from your home number.
1. Lift your telephone's receiver and listen for a dial tone.
2. Press *7 2.
In some areas you must use 72#
Dial 1172 on rotary or pulse-dialing phones.
3. At the tone, dial the telephone number where you want your calls transferred.
You will hear the number you entered ring. When the number is answered, Call Forwarding is activated.
4. If the call is not answered or the line is busy, hang up and call the number again within two minutes.
You will hear two short tones telling you that Call Forwarding is activated.
5. Hang up the receiver.
Deactivating Call Forwarding
Turn Call Forwarding off when you want to receive calls on your home phone.
2. Press * 73.
In some areas you must use 73#
Dial 1173 on rotary or pulse-dialing phones.
3. Listen for two short tones.
Call Forwarding is now off and you will receive your calls at your home number.
Dec 01, 2008 | Uniden Cordless Phone
Office jet all in one printer 4215
If you are using speed dial to dial the fax number, the HP Officejet
might be dialing too fast or too soon. To solve this problem, try one
of the following:
Try manually dialing the fax number from the HP Officejet front
panel, or from an attached phone. For information, see send a
fax using monitor dialing
on page 43 or send a fax manually
from a telephone
on page 43.
Re-create the speed dial setting and insert some pauses. For
information, see create individual speed-dial entries on
page 56.
If your telephone line has a PBX system, make sure you are dialing
the number for an outside line before dialing the fax number.
The receiving fax machine might be having problems. To check this,
try calling the fax number from a telephone and listen for fax tones.
If you cannot hear fax tones, the receiving fax might not be turned
on or connected, or a voice mail service could be interfering with
the recipient’s phone line.
http://h10032.www1.hp.com/ctg/Manual/c00095626.pdf
May 07, 2008 | HP Officejet 4215v All-in-One Printer
Cordless telephone sw/from pulse to tone
In General Electric (GE):
TONE/PULSE DIALING
To set to tone or pulse dialing:
1. Press and hold the program button for two seconds. You will hear a beep.
2. Press the *tone button to select Tone Dialing or press #pause to select Pulse Dialing.
3. Press the program button again. You will hear a confirmation tone.
Nov 25, 2007 | GEH5450 Cordless Phone
Lands Phones Logo
79 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
