Ovens Logo
Paddy Merrill Posted on Nov 10, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Simpson Model la Stella Oven Thermowave not working Fan works and other settings OK
Stan Ford
Level 3:
Genius:
  • Master 3,131 Answers
  • Posted on Nov 10, 2016
Stan Ford
Master
Level 3:
Genius:
Answers
3131
Questions
Helped
904546
Points
9078
Burnt out element , thermostat or switch, test with meter.
Simpson atlas thermowave underbench. The clock is working. Why cam't I turn the oven on?
The oven is probably in auto mode, reprogram the timer for manual operation normaly symbolised by a image of a hand
Sep 15, 2020 • Ovens
How do I remove the door from a Simpson La Stella oven
https://www.google.com/search?source=hp&ei=4sN1Xo3pMseTjLsPoPmZ0AQ&q=How+do+I+remove+the+door+from+a+Simpson+La+Stella+oven&oq=How+do+I+remove+the+door+from+a+Simpson+La+Stella+oven&gs_l=psy-ab.3...33892.33892..34736...0.0..0.236.236.2-1......0....2j1..gws-wiz.4AN9HYMLmgM&ved=0ahUKEwiN4u-hh6voAhXHCWMBHaB8BkoQ4dUDCAU&uact=5#kpvalbx=_78V1XoCeDOWZlwSiq5-gBA59
Mar 21, 2020 • Ovens
Hello, My oven won't heat up more than 200
check that both top and bottom elements work, if a thermowave then the element which is circular and behind the grill cover the fan
Sep 30, 2019 • Ovens
1helpful
How do I remove the door on a simpson la stella wall oven to make cleaning easier
go to your authorized service agent and ask for a parts diagram for the door hinges
that will show small locks that when the door is open can be rotated into the slots of the hinges and lock the hinges open
from there you lift the door up and out of the hinge slots
Jun 08, 2017 • Ovens
2helpful
I have a 'Simpson 2001 Thermaflow Oven' and a few months ago, i was heating it up, and i heard a pop, from then on my oven has not heated up, i cannot seem to find what is wrong with it!! Please...
I would say that the oven element has blown. It is common especially if you have a fan forced model. Make sure the fan works before you go buying a new element as the replacement will fail early. Simpson ovens have to be removed from the wall cavity to replace the fan and the element. Make sure you tuen the power off before doing anything...
Give the parts supplier your model number so that you get the fight element ( and fan) if necessary.
Jul 31, 2011 • Ovens
8helpful
Cant remove glass cover to replace bulb on Simpson La Stella Atlas series oven
I have a Simpson Atlas Mira. Was having a hard time getting the glass cover off too so looked on the net for a solution. Couldn't find one so I persevered and sorted it...
The glass cover has a screw-off thread (like a glass jar) which unscrews anti-clockwise (lefty loosey). I had to give it a good few wiggles and pulls before it would start unscrewing. I also had to use a damp towel to get a proper grip - it's a slippery little bugger - but I got it in the end!
Hope this helps someone - good luck!
JD Hamilton, NZ
Aug 23, 2010 • Ovens
32helpful
Simpson Apollo can't set clock so oven won't work
I don't know if this will help. For the 720ef , this is what you need to do.
There are five buttons on the clock panel and from left to right they are:- Minute Minder, Cook time, Ready Time, Plus and Minus.
TO SET THE TIME OF DAY
Press the Cook Time button and the Ready Time button simultaneously. Use the Plus and Minus buttons to set the time.(24hr clock).
TO SELECT AN ALARM TONE.
Press the Minus button to listen to the first tone. Release it and press it again to listen to the second tone etc (3 tones)
Releasing the button after the tone has sounded will automatically set that tone.
SETTING THE MINUTE MINDER.
Press the Minuter Minder button and either the Plus or Minus buttons simultaneously to set the time.
You can cancel the timer at any time by setting it back to 00.00 by using the Minus button.
After setting, the display will revert to the time of day, but by pressing the Minute Minder button again, the display will show the remaining time.
If you want all the information, then it is best if you supply a vaild email address and this will give you access to my BT Digital Vault, where you can have a complete copy of the handbook that I have scanned in.
29helpful
Can not set clock on Simpson La Stella oven
How do i set the time on a Simpson La Scala wal oven
2answers
Simpson oven 736 evolution turns itself on briefly then turns off
sounds like you have a control board problem
Jun 12, 2009 • Ovens
Top Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you an Oven Expert? Answer questions, earn points and help others
