Garden Logo
Posted on Jul 19, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cub Cadet 2145 doesn't have a spark
I have replaced the ignition coil and removed the ground wire from the coil to check for a spark. Still nothing at all. This lawn tractor has an Onan 14 hp horizontal shaft engine. I have replaced the spark plug, ignition coil, and voltage regulator. I am totally stumped. Thanks for your help.
  • 1 more comment
  • skyline5way Jul 20, 2009
    Yes, I used a business card for the gap. The magnets were definitely pulling hard on the coil.
    Initially I had a problem of the engine stopping after a few minutes of mowing. After it rested and cooled, it would start back up. The last time this happened, it wouldn't start. Checked the spark and nothing. Replaced the voltage regulator and then the coil. Still nothing, then unhooked the ground wire from the coil, still nothing. Maybe the new coil is defective? Thanks so much for your help!
  • skyline5way Jul 22, 2009
    I found the problem! I had put the new coil in backwards. There is an arrow on the side of it to match the flywheel rotation. Duh! Breathing too many gasoline fumes I guess!
  • Mike McDowell May 11, 2010
    When you replaced the coil did you gap it per specs? Are the magnets still on the flywheel?
Mike McDowell
Level 2:
  • Expert 148 Answers
  • Posted on Jul 22, 2009
Mike McDowell
Expert
Level 2:
Answers
148
Questions
0
Helped
90292
Points
359
2answers
Mower wont start no spark
Isolate and verify trouble is within engine.
Locate connectors where wiring harnesses from engine and equipment are joined. Separate connectors and remove white kill lead from engine connector. Rejoin connectors and position or insulate kill lead terminal so it cannot touch ground.
If spark returns after isolating the ignition modules by disconnecting the white wire then the problem is with the machine, not the engine.
1helpful
Cub Cadet won't turnover.
Try boosting it directly from the battery and see if it will turn over now. I had that problem and found my cable on the ground side had corrosion in it. I put new cables on and is ok now.
Cub cadet 2166 16 hp kohler command. no spark. replaced coil still no spark
Check the ground wire to yhe coil it may not be releasing so the coil can send spark to the plug
I need to know the location of the spark plug on my Cub Cadet GT 2550. I need to replace it.
They are on each cylinder head. There is a wire from the coil to each spark plug. Remove the wire and you'll see the spark plug
1helpful
Cub cadet ltx 1045 wont start, no spark.
remove the top cover from the engine and remove the small wire from the coil if still no spark the coil is bad
2helpful
3answers
Cub cadet 12.5 hp kohler comand engine sporadic loss of spark
spark control, yes, trace spark plug wire back to its end, you will find what I will call a coil, for lack of the better word, it can be. I would think that is your problem, if you are presently not getting a spark in the plug.
1helpful
Cub Cadet 2145 with 14HP Onan Engine.
sounds like you may have ignition coil or module whichever you prefer (one in the same) may be heating up and shutting down? Check all your grounding connections also
May 28, 2010 • Garden
No Spark - Cub Cadet model 71 with a Kohler 8hp
check condition of the magneto,located under the flywheel
Cutting grass.heard loud Pop tractor shut Cub Cadet 1210 Hydro
just trace the spark plug wire to the coil but you can check the spark by putting a new plug in the wire and make sure it is grounded and turn the engine over if you have spark then you have to pull the fly wheel off and check the fly wheel key
Top Garden Experts
Jay Finke
Jay Finke
john h
