Ryobi Multi-Volt Battery Charger
Problem for Ryobi Multi-Volt Battery Charger
Battery charger
By ronallan on Nov 19, 2007
battery charger model 1400666 not charging The red led is not on.
this is a 12 volt charger.
Same Problem
Sep 09, 2008
-   Hi I have a 24v ryobi battery charger not working, I can hear what I think is the transformer hum when I plug it in ,but no lights are coming on , any ideas anyone ? James-   meherbaba
Aug 21, 2008
-   My Ryobi CTH 1202 Charger wont charge batteries. I took it apart and the 250V 500Ma fuse was blown. I put a new one in and as soon as I put a battery in to charge it blew again. Does anyone have any suggestions as to what the problem might be or how to test/troubleshoot the problem. Any and all help is greatly appreciated.-   paniollo
Best Solution
posted on Aug 17, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Take your charger out on a boat and dump it into the sea. Then go to the store and buy a new one.
Solution #2
posted on Dec 01, 2007
Helpful)
soleman13au
Rank: Wiz
Rating: 91%, 62 votes
I have two 18volt chargers doing the same thing. I have had them apart and it seems to be the transformer not pushing any power thru. If you can find a transformer that fits and has the right voltage that should fix the problem. From what I can make out if you leave the battery in for too long on charge it cooks the transformer. Hope this helps
Was this helpful?
Yes
No
Solution #3
posted on Aug 11, 2008
Helpful)
ray3447
Rank: Apprentice
Rating: 85%, 3 votes
I had a similiar issue, took it apart and there was a fuse blown inside, this was on my 18V Ryobi charger
Was this helpful?
Yes
No
Popular Solutions for Ryobi Multi-Volt Battery
Questions and Unsolved Problems for Ryobi Multi-Volt Battery
Do you recommend Ryobi Multi-Volt Battery Charger?
Answer
Answer
Yellow & Green Lights stay on. battery is fully discharged.
Answer
One of the front power jacks will not work. The motor side works great. The orthe side the gear on... (More)
Answer
I lent my Ryobi 18 V batteries and flashlight to a friend during a power failure. When they were... (More)
Answer
i get a yellow light with some batteries
Answer
Probably in the wrong cattegory but I need to find the tp2 mkv trailer pack- manual. As I want to... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Ryobi Multi-Volt Battery...:
Top Drills / Driver Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Drills / Driver Experts
Top Garden & Power Tool Repair
(800) 937-7279
Replacement lawn mower and snow blower parts from...
Commercial Parts Warehouse
(509) 678-4379
Precise Engine Repair proudly represents Briggs...
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
