Cars & Trucks Logo
Clyde Davis Posted on Nov 10, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What would make a 1989 Lincoln navigator have a loud squeaking noise when either exiting the truck or pushing down on the bumper
All of a sudden I can hear this loud squeaking noise when ever I inter or exit my 1989 Lincoln navigator using the side step or by pushing down on the bumper an its driving me up a wall trying to figure out what it could be.any one please help
Randy Ohler
Level 3:
  • Lincoln Master 14,585 Answers
  • Posted on Nov 10, 2016
Randy Ohler
Lincoln Master
Level 3:
Answers
14585
Questions
8
Helped
3946348
Points
39683
Control arm bushings, usually. Being an 89, could be ball joints.
2005 Lincoln Navigator. Please help me narrow it down.
The Navigator is totally run by electronics. The only way to diagnose is with professional grade scan tool computer. It takes about 30 minutes. The throttle body has a relearn / reset procedure.
https://www.google.com/search?q=mobile+auto+electrician+near+me
https://www.google.com/search?q=2005+lincoln+navigator+throttle+body+relearn
1helpful
Sudden loud noise
Not a vacuum hose. If it is coming from the top of the motor, I would first check the oil. If there is a hole punched into the oil pan , you may be very low on oil. If oil's fine, I would suggest looking at the transmission housing. If the manhole came up and hit the housing, it may have cracked that, or cracked the fly wheel. One more thing I'm thinking is that if the manhole hit your starter, and pushed it up, It may have cracked the fly wheel. This can make it sound like it's at the top of the motor. Very loud tap tap tap tap. If you excellerate, the noise will go faster too. I just can't see a manhole doing any damage to anything in the top of motor. Make sure you check the oil ASAP. Hard to tell without hearing it. A video would even help. Let me know what you come up with. Good luck
2helpful
Suspension noise rear
Rear sway bar bushings
Why is there no power to third row seat?
Power 3RD Row Seat Problems and Tranny Shutter - Ford Truck ...
www.ford-trucks.com > ... > Expedition & Navigator
Mar 27, 2014 - Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition andLincoln Navigator SPONSORED BY: ... First the 3RD row seats won't fold down, noclicking, no sounds, nothing. I the fuses are good and there is power at the fuse box, but no power at the motors or switches. Based on continuity ...
3rd row powerfold seat stuck down - Ford Truck Enthusiasts Forums
www.ford-trucks.com > ... > 2007 - 2014 Expedition & Navigator
Mar 14, 2010 - 3rd row powerfold seat stuck down 2007 - 2014 Expedition ... 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator ... I also tried lifting the seat while my wife was pushing the button to raise it, to no effect. There is defnitelypower going to the motor but it just isn't ... Join Date: Feb 2005.
No power to third row seat on 2005 lincoln navigator - Fixya
www.fixya.com/cars/t12295627-no_power_third_row_seat_2005_lincoln
Apr 4, 2012 - no power to third row seat on 2005 lincoln navigator third row seat is ... U will have to replace the entire power seat transmission, there is no ...
Lincoln Navigator Review - Edmunds.com
Squeaking sound coming from under my truck ? I just replaced the u-joints today.
I would check all the suspension bushings. You could try to spray the bushings with WD-40. Try having someone push up and down on the bumpers, you maybe able to track down the noise.
2answers
Front suspension noise
please discribe the noise, is it a squeak?
2helpful
2answers
Starter motor always turning
The starter is not disengaging back. When you start the car the end of the starter pushes out, then retracts again. find out why it is doing that. This could be a mechanical problem. I dont think it is electrical at all.
Top Lincoln Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Lincoln Expert? Answer questions, earn points and help others
