Maytag A7300 Washer ~1993 / Over-filled, now motor won't run
Overfilled the washer, could hear the drive belt squeaking and could smell rubber. Shut off the unit, disconnected power, motor will not run at any position on dial settings. Water still fills, nothing else seems to. Have found one glass type fuse for the door latch, it still looks viable (not melted). No other fuses can be found. The belts don't appear to be broken or overly worn (replaced two years ago). Of course if the motor isn't running the belts are not the problem... :)
Could it be the motor switch? The motor? Is there another fuse somewhere? Please advise.
Thank you so much!
  • spentZZZs Feb 27, 2008
    I have the same problem but decided to replace the whole motor but still doesn't work. Is there some kind of fuse blown due to the overfill?
  • Anonymous Jun 22, 2008
    The washer filled with water but then stopped. Now the power button wont even turn it back on. I have unplugged the washer and waited like the book says to do but nothing happens. Its a fisher paykel top load washer ecosmart.
SOURCE: washer won't spin but motor runs and belt is not broken
Check the filter! If it's full, it won't drain properly.
Posted on Jul 30, 2007
  • 1073 Answers
SOURCE: MAYTAG WASHER DOES NOT SPIN AND DOES NOT DRAIN
you have a bad motor
Posted on Apr 16, 2008
  • 1028 Answers
SOURCE: maytag washer will not agitate
ckd wiring connections motor and timer? if they look ok suspect timer ..motor contacts in timer may be shot
Posted on May 01, 2008
ngfam1
  • 639 Answers
SOURCE: MAH4000AWQ MAYTAG WASHER
PEACE,
NGAFM1 AT YOUR SERVICE
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
* The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
* The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
* A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
* The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
* The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
BLESS YOU,
PLEASE GIVE ME A GOOD RATING HERE AT FIXYA.COM BEFORE YOU SIGN OFF!
Posted on Sep 02, 2008
  • 1937 Answers
SOURCE: I have a Kenmore 70 Series washer
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
Since it isn't agitating (I assume not at all rather than just the top part of the agitator. If just the top part isn't turning then the easiest solution is replacing the 4 "agitator dogs" ) the solution points to a couple of places.
1. The motor coupler may be broken.
This piece is a fail safe between the motor and transmission. and basically transmits power to the transmission.
Following is a description of how to remove the cabinet, pump, motor and motor plate to check the motor Coupler.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If it spins and drains OK, and if you can hear the motor turning, the problem points to the transmission.
Inside the transmission are a number of gears, springs, and plastic cams and levers. Over time one of them may have either broken or worn out.
Following is a Whirlpool PDF on how top load, direct drive washers work.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
There is a Whirlpool site with a parts list for their "commercial washer" which is essentially the same as for your washer. On it is a list of all of the components and parts for the washer.
By paging down to and following the diagram of the transmission you should be able to determine which actual part is broken.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
If you've determined that the transmission is the problem, the solution points to either the Agitate Cams, Agitate Gear of the Agitate Gear Spring.
Pull the transmission.
Remove the clutch (the spring holding the clutch to the spin pinion is a bear to replace.
Remove the 8 transmission screws carefully, the transmission is full (16 oz.) of 80-90 weight oil.
Remove the transmission cover.
Pull off the spin pinion.
Push down on the agitate spring and remove the spring clip. Note where is attaches to the main shaft.
The two plastic agitate cam parts pull right off. Don't lose the washer on top of the cams.
Replace the cams, washer, spring and clip, pinion, oil (assuming you drained the oil first), cover and clutch parts.
Line up the transmission so that the release cam on the brake drum will snap onto the clutch spring retaining clip and put all parts back in the washer.
The basic tools are screwdriver, small socket set with up to a 1/2" socket, vice grips or good pliers (to remove and replace clips)
Posted on Oct 07, 2009
Maytag legacy series washer
The drive motor which spins the drum is connected to the drum by a rubber belt. Sounds like the belt is burned through. Make sure you can spin the inside tub by hand to verify that the tub can turn freely before you replace the belt. The hum is from the drive motor just spinning freely.
Sep 02, 2016 | Maytag Legacy Series Top Load Washer
Maytag oversize capacity washer just finished filling up the tub with water. Then it had a burning rubber smell. I shut it off and on a bunch of times and there isn't even any sound. (like the mot
You need to observe and check after disconnecting the power , touch the motor, the element area or the control panel or the valves/pump.
If you notice any heat on these , it can be the culprit.
You can proceed to remove the suspected part to discover what was the reason for the burning rubber smell.
Click this link: Element
Jan 25, 2013 | Maytag 3.3 cu. ft. Oversize Capacity Plus...
Noise during wash cycle & got even louder on spin cycle then washer stopped completely
Could be bad belt, or agitator sleeve cracked / or broken. Not catching.
Aug 08, 2012 | Maytag HAV3460AWW Top Load Washer
My neptune washer smells like rubber burning when i wash clothes
Hi
Older top load washers use a belt to drive to transfer the energy from motor to drum. However, if the belt slips, stretches, or breaks, it can cause friction and a burning smell, most likely a burning “rubber” smell. The belt is located either from the back access panel or from the underside of the washer.
The solution is to replace the belt with a new one. To replace the belt you can open the back lid of the washer. Remove the old belt & remove the bolt holding motor. Now remove the motor, remove & replace the 2 plastic isolators with the new ones supplied with the belt on the motor spindles. After re-installing the motor & bolt adjust the new belt.
Please post back for any further assistance.
Daniel
Jul 26, 2010 | Maytag Neptune MAH6500A Front Load Washer
Maytag washer, buring rubber smell, drum won't turn
the drum should run free if not the bearing have gone and seized they will need to be replaced. hear is a video there are others you can find the bearing kit on line using the model number https://youtu.be/WGolkFlgl3Y
Jun 22, 2017 | Maytag Washing Machines
Maytag Atlantis washer
is the smell rubber or electrical? the pump could be seizing on it and burning the belt. check this out first.
Oct 25, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Maytag washer sounds like a jackhammer when rinsing - this is a new thing with all loads. Yesterday it shut down mid cycle while still full of water and we smelled a burning rubber smell. Any ideas?
There is only one belt on the machine (the burning rubber smell, probably). Sounds like something is wrong with the clutch /drive mechanism. Unless your an accomplished DIY'er, it sounds like a job for the Maytag Man.
Sorry.........................
Sep 15, 2009 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
349 people viewed this question
Top Washing Machines Experts
