Question about Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher
Kenmore Ultra Wash Dishwasher- dishes no longer getting clean
Kenmore Ultra Wash Dishwasher Model 665 13843 -
Mydishes on the top rack are no longer getting clean. I don't think any water is going to the top. The dishes on the bottom get clean but have a soap residue on them. The soap door opens but there is still soap in it.
catriver
  • 878 Answers
SOURCE: dishes not getting clean
brittgee, there has been a number of service flashes on this model. One that has to do with the upper spray arm assy. Complaint is poor washability; gritty glasses, food redeposited on glasses, especially in the corners. They redesigned the upper spray arm to improve water spray to all corners of the upper rack. The new part number is 8269022. They also redesigned the third level spinner for more consistant rotation and better washability. This was also under a service flash. Part number.8193768. Other reasons for poor wash would be; low water temperature, rinse aid disp. not working, loading etc. Catriver...post back.
Posted on Nov 25, 2006
IFIXALL
  • 868 Answers
SOURCE: Kenmore dishwasher skips the wash
Replace the electronic control board.Its located under the panel you select cycles from.
Posted on May 21, 2008
  • 4 Answers
SOURCE: Kenmore dishwasher not cleaning
Growand:
There is a rubber tube which supplies water to the top spray arms. That is, If yours has top spray arms. This rubber tube has to make a connection when one slides the top rack back in. That tube will rot after a while, check it out.
If the soap is not being used up, reduce the amount of soap you are using and run the dishwasher empty with a pie plate sitting on the bottom rack with a cup of distilled (cheap) vinegar in it. Run it hot and long, recheck and redo if neccessary.
Posted on Jul 30, 2008
micromaster
  • 3614 Answers
SOURCE: No clean dishes
Internal filtersEvery dishwasher has some type of filter to keep large food particles and foreign objects away from the pump assembly:
  • Most modern dishwashers have self-cleaning filters that don't need any routine cleaning.
  • Some have filters in the bottom of the dishwasher that you need to periodically clean. You don't need any tools to remove the filter, and cleaning it is easy. Consult your owner's manual to determine which type you have and its maintenance requirements.
If your filter is clogged, it may be causing the cleaning problem.
Drain valve
Some dishwashers have a valve (or gate) that should open only during draining. If debris lodges in the valve, it can't close properly, so water drains out during the wash cycle. Most dishwashers drain into the garbage disposer. If yours does that, listen for water flowing into the disposer during the wash cycle. If you can hear it then, the drain valve may be clogged.
Spray arms
There's a spray arm at the bottom of your dishwasher--it may have a tall spray tube mounted to the center of it. There may also be a spray arm located directly beneath the upper rack of dishes and/or above the upper rack.
If debris is blocking the holes in the spray arms where the water comes out, it could cause cleaning problems. Regularly inspect each of the spray arms and clean out the holes as necessary.
Detergent cups
Dishwashers don't perform their best if detergent is introduced only at the beginning of a cycle, so add detergent to both parts of the cup.
If the detergent cup isn't opening, see the "The detergent cup doesn't open" section, below.
Note: Dishwashers are usually wired directly to the home’s electrical system. To disconnect the power, switch off the circuit breaker or remove the fuse for the electrical circuit the dishwasher is attached to. Try to turn the unit on after disconnecting the power to be sure you were successful.
CAUTION: If you’re not sure you’ve shut off the power properly, DO NOT CONTINUE. Call a qualified appliance repair technician to complete the repair.
Posted on Sep 13, 2008
tzweeb
  • 318 Answers
SOURCE: Kenmore ultra wash dishwasher model number 665.158.5090
the only way you can tell if the upper rack is not getting enough water is to turn a glass right side up in each corner. then run for 2 minutes and see if there is water in each cup.
if you still dont get water, then you have checked the pump, the only thing left is that you are not getting enough water into the unit.
start the d/w at a normal cycle, let it fill and go into the wash cycle, takes about 3 minutes, then check to see if the water level is just below the heating element. if so then it has to be the wash pump being plugged.
if not enough water then you should change the water inlet valve. some times they do get plugged but also make sure you are getting full water pressure to the unit as that could cause not enough water into unit. the faucet under sink could be at fault i have seen valve work but not let enough water in, so dont be surprised if you need a new valve.
Posted on Jan 06, 2009
Kenmore ultra wash diswasher top rack not cleaning
see please the next video for your fix it: God bless you
Jul 21, 2012 | Kenmore 24" Built-In Dishwasher with Ultra...
The top rack on my kenmore ultra wash 3 dishwasher does not come clean and now even the bottom is starting to not clean
First perform a vinegar cycle wash in the dishwasher. Pour a cup of vinegar into the bottom of the dishwasher. Keep the temperature at the highest setting possible and perform a wash cycle.Then start using a dishwasher most probably that would solve the problem. If this does not solve the problem then there must be some parts worn out or faulty creating the problem.
There are many probable causes of failure .
To clean the dishes the water temperature is essential.It the water is not hot then the dishes will not be cleaned properly.So check the water temperature.
Also check the filter in your dishwasher.Clean the filter if there is accumulation of debris in the filter
If you are in an hard water zone , then try reducing the amount of detergent used and then try cleaning the dishes.
Dec 23, 2010 | Kenmore PRO 24 in BuiltIn Dishwasher with...
Kenomore ultra wash dishwasher will not clean dishes- water pump may be out? How do I perform self diagnostic test?
check and see if both wash arms are turning first.
does the lower arm turn but the top arm does not?
Another way to check to see if your upper wash arm is turning is to put a mug in the top rack upright. close the door and turn the dishwasher on if it fills the mug within 2 minutes you are getting proper curculation.
you press heated dry and high temp wash and toggle back and forth within 6-8 second. all the lights should light up and it will go into diagnostics.
Sep 03, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
Not cleaning properly
take a good look at the two spinning washers they are easy to remove i would suspect they are clogged clean and replace.adrian,,,,
Jul 14, 2010 | Kenmore Dishwashers
Kenmore 665.17539. fills but does not wash. makes
Kenmore 665
My dishes on the top rack are no longer getting clean. I don't think any water is going to the top. The dishes on the bottom get clean but have a soap residue on them.
Jul 01, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Dish racks for Kenmore Ultra Wash Model #665
www.Repairclinic.com is a great place to look. But from past experienc, dishwasher racks are very expensive and almost 1/2 the cost of a new one. Good luck.
Apr 21, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Viking dishwasher not cleaning bottom rack of dishes
Yes there is the Water Div valve, it diverts the water between the wash arms.
Mar 07, 2009 | Viking 24 in. Professional Series VUD141...
DISHES ON TOP RACK NOT GETTING CLEAN.
MAYTAG MODEL MDB7160AWB DISHWASHER
fills,starts wash cycle and shuts down about 2 min. into cycle
Nov 12, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Kenmore ultra wash dishwasher control lock light flashing
Just press the 'Air Dry' button for 5-6 seconds....I have an ancient Kenmore Dishwasher (ULTRA)
Oct 02, 2008 | Kenmore 15899 Built-in Dishwasher
Dishes not getting clean
Nov 25, 2006 | Kenmore 24 in. 15933 Built-in Dishwasher
Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher Logo
165 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
