Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
WHEN I PUSH START BUTTON ON MY 01 FAT BOY IT JUST SPINS, IS THIS A SELENOID OR STARTER PROBLEM
  • wayne_echols Jul 19, 2009
    The starter, is spinning not the motor, i thought the selenoid is what engages the pinion gear.
  • 22 Answers
Well considering you said it spins, i'm assuming you mean that you hear the starter spinning and it's not turning the motor. That means the starter gear is probably worn out and you'll need a new starter, as for the solenoid, if the solenoid was bad you would not hear the starter doing anything. So its a safe bet that your starter is not working properly.
If it is turning the motor, then you have an ignition or fuel issue.
Posted on Jul 19, 2009
Testimonial: "thanks for the responce, it was starter just spinning and not turning motor. oil tank was fun to remove. problem solved."
Starter problem 1997 FLSTS
see the diagram attached, and by pass it . GOD BLESS YOU07b0a924-114d-4fdb-a9c3-005a442421f7.gif4c66c703-1a35-40c8-931c-f38f83eeeeca.jpgHowever if the problem persist you must replace the starter unit.to out tolerance parts.
God bless you
Jul 11, 2013 | Motorcycles
Sterter problem
your safer bet is a new starter because if you are having those kind of problems its not long before more starts to happen, bad bushings etc. buy a new starter
Jul 11, 2013 | 1993 Harley Davidson FLSTF Fat boy
Starter clicks does not start
Is it the starter or the starter relay clicking? If as you say it is the starter this usually leads to worn brushes and or armature comuntator in the starter. This can often be confirmed by tapping with somthing solid such as a large wrench on the starter while holding the button depressed. If the starter tries to operate while tapping a starter rebuild is in order. Good luck!
Dec 30, 2012 | 1993 Harley Davidson FLSTF Fat boy
2004 vtx 1800 c won't start using the start button
it sounds like a grounding issue check you groung from the battery to the engine
Aug 29, 2012 | Cars & Trucks
Push the start button on my 94 fatboy. Will not engage starter. New battery but If I jump battery starter will engage. Is this the starter relay and if so how do I replace it
If you're saying that the new battery will not start your bike but when you jump the battery in the bike, it will, I'd say you have a problem with the new battery. When you "jump start" any vehicle by connecting another battery to your battery, you're connecting the batteries in parallel. This keeps the voltage the same but adds the current capabilities of the two batteries together. You either don't have enough battery or your starter is drawing too much current. Check all your connections and see if they're clean. What kind of battery did you buy? It should have been a stock replacement battery of the same size and current capacity.
Good Luck
Steve
Aug 18, 2011 | 1993 Harley Davidson FLSTF Fat boy
My 97 fatboy battery started dying in 2010. Put bike away for season bought new battery put it in now when I hit start button starter relay clicks wont start an orange and white wire under the seat was...
Well, I don't really know how to tell you to troubleshoot your starter when you don't have a meter. When you press the starter button, there is a starter relay that is usually mounted on the rear fender extension on the Fat Boy that engages and provides voltage to the starter solenoid. This voltage goes to the solenoid via the single small wire that plugs onto the starter just above the d-sided plate on the end of the starter. This wire goes hot which energizes the coil in the solenoid. The magnetism pulls the plunger into the starter. The plunger has a large round copper "washer" that make contact to two copper terminals inside the solenoid that connects the battery to the starter motor.
To test the starter, make SURE your transmission is in neutral. Take the 5-sided plate off the end of the starter. There are three 3mm bolts that hold the plate on. Behind the plate, you'll find the plunger and long spring. Using a large screwdriver or something, push the plunger into the solenoid as far as you can. The starter should engage and turn the engine. If not, look at the copper contacts inside the solenoid. If they look burned and are not smooth across the face, you may need to replace them. Rebuild kits are available both through Harley and aftermarket suppliers.
Good Luck
Steve
Mar 30, 2011 | 1993 Harley Davidson FLSTF Fat boy
Starter doesn't engage with switch on handle bars all the time
check the connections in the switch. maybe a cable is broken, maybe the ground have some rust
Apr 27, 2010 | 1993 Harley Davidson FLSTF Fat boy
2001 fat Boy Starter just spins and doesn't engage. Is it the jack shaft or the solenoid and how do I check to determine the problem?
Well this is not going to be fun. In order to know you are going to have to remove the primary. After that you can see if the solenid is working, if the gear is engaging.
If you end up needing to replace the starter...it is well worth the $$ to have someone else do it.
Sep 16, 2009 | 2001 Harley Davidson FLSTF - FLSTFI Fat...
Electric Start Spns & won't engage
i have a riding mower and i get that problem sometimes and what i do to fix it is i take a metal pole and put against the motor and gear on the starter and push when it moves i turn the key and that normally fixes it.
Jun 14, 2009 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
Lands Phones Logo
645 people viewed this question
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
