Question about Dyson DC14 Animal Bagless Upright Cyclonic Vacuum
Brush doesn't turn, and hard to push on carpet...
Worked fine up to a couple days ago... of course I really need it right now with flea season upon us...
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 71 Answers
Hiyas, have you checked underneath take off the brush base cover and see if the brush belt has snapped to the side of the brush bar, if so you can get a replacement easy enough at most electrical retail stores, take the make and model number with you ;) it will be hard to push with the brushes not spinning, try raising the setting in the meantime until you can replace a new belt
Posted on Jul 19, 2009
Why is it such hard work to hoover the carpet with the dyson dc 33.it is really hard just pushing it across a new carpet.
Are your belts working and is your power head set too low? Try raising it up one or two clicks. A broken belt will not let your brushes spin and a spinning brush will help it go on carpets.
Aug 20, 2016 | Dyson Vacuums
Motor runs but brush don't spin and belt is not broken
Two core baseline things to check. Brush won't spin if the handle is all the way forward (this is where the handle mode engages), so tilt it back before turning unit over to check the brush. Also, run the brush clutch back and forth between hard floor and carpet mode a couple of times and make sure the clutch is fully engaged. Hoping it might be as straigtforward as that (I just picked up a Dyson at a flea market, a really good deal since I couldn't get the brush to spin there. After some research at home, the above finally entered my sphere of knowledge, and no problems with the brush since (other than cutting large volumes of Labrador hair off of it).
Aug 27, 2015 | Dyson DC28 Animal Airmuscle Vacuum Cleaner
Dyson 33 wont push on plush carpet
I'm sorry to hear you're having difficulty using your DC33 on this particular carpet. If you haven't already contacted our Helpline, I'd encourage you to do so, as we'll be able to discuss other options which may be more suitable for your needs.
You can reach us on 0800 298 0298 (UK), or 1-866-693-9766 (US). We'll look forward to hearing from you.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Mar 27, 2012 | Dyson DC33 Bagged Upright Vacuum
EVERYTIME I PUSH THE BUTTON REALLY LOW TO ALLOW THOROUGH CLEANING IN THE CARPET, THE LIGHT DOESN'T TURN ON AND IT DOESN,T **** THE DIRT AT ALL.. IT ONLY WORKS IF YOU PRESS IT UP ONCE BUT IT DOESN'T GET ALL...
You need to replace the belt whenever the green brush indicator light goes out or is not steady. Be sure to observe the wear settings when re-installing the brush. The ends of the brush are marked with 1, 2, or 3 notches and numbers. In normal use the brush should have setting # 1 towards the rug. These settings adjust the brush for wear, and moving the bristles out prematurely will result in excess brush and belt wear.
Feb 24, 2011 | Kirby Ultimate G Bagged Upright Vacuum
I have a Bissell Pro Heat 2X carpet cleaner and the brushes spin, then stop. I turn it off and when I re-start, the brushes do not spin until I push foreward. The it spins and stops again. Both belts are...
The reason for the brushes to stop when it is above any surface is there is a switch in the handle that stops the brushes so it dont burn your motor up it may have a faulty switch.
Jul 14, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
Loud noise when I start the vacuum in carpet position
Not exactly a solution, but more of an explanation. The noise is caused by a ratchet device that's designed to protect the belt if the brush roller becomes blocked. It's a bit like a clutch that slips when resistance on the brush gets too great. The noise will occur if there's a solid blockage, of course, but it will also occur whenever the machine senses excessive resistance. This may happen on carpets with really thick pile, but can also happen if the carpet is loosely fitted and can be sucked up tight to the roller by the force of the vacuum.
Small consolation, but the problem should lessen as the brush wears. Meanwhile, if all else fails, switch the brush off (hard floors mode) while vacuuming the problem carpet(s).
Feb 08, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Correct position of beater bar on a Dyson DC14?
I had the same problem. I removed the brush from the machine. The brush should move freely when removed. If it doesn't move freely, pull the ends from the brush, both ends come off(one will have a rod fixed to it). I would suggest you clean the ends and the inside of where the ends sit on the brush. I applied a little grease on both end housings(inside end housing) if no grease available try washing up liquid. Put the brush ends back on the brush. I then spun the brush to check that it moved freely. It should move freely, if it does fit it back on the machine and it should be silent. If you cant get it to move freely I suggest a replacement brush. Tip: I used a blunt knife and placed it through the belt to avoid removal of the belt. Good luck. Cheers Jason
Jan 19, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
In Carpet setting, the vacuum brush does not spin
I put 3 turns of electrical tape around the area of the beater bar that meets the vacuum belt. This solved the problem short of replacing the beater bar.
Jan 18, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Black marks on carpet
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19810&thid=706295
posted by carpetburner on Jun 25, 2008
While I was walking on the carpet, I noticed a couple of black marks. I figured it was on someone shoes. I was vacuum a couple of days later and stated noticing small black marks on the right side of the brush marks left in the carpet by the brushes. I tried to clean them and they don't come out. They are sort of like a scorched pinched place or something. I had the handyman take it apart and he found nothing stuck in it, belt was replaced not to long ago, and he said everything looked fine. The black marks are not on the belt side. Maybe a wheel is sticking? It all seems to roll, and turn ok.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Oreck XL Ultra Bagged Upright Vacuum. After reading your question, there are only a few things that could be causing the problem. It is very possible that the brushroll could be dirty, or install wrong, on the ends of the brushroll the gray bearing holders will state NEW and OLD and both of the bearing holders needs to be identical – meaning the 2 should say NEW / NEW or OLD / OLD, not new / old of which could be causing the problem. The average belt change should be done every 4 to 6 months for the best cleaning, and the extra belts are stored in a Ziploc bag in the refrigerator. If the wheels are spinning properly then it is not the wheels unless they are dirty and the can be cleaned just by popping them out of the bottom plate holder with a screwdriver and then clean them under the sink. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.oreck.com/ Customer Service 1-800-989-3535
Monday thru Friday Hours are: 7:00 am to 7:00 pm CST
Saturday and Sunday Hours Are; 8:00 am to 4:30 pm CST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 25, 2008 | Oreck XL Ultra Bagged Upright Vacuum
Dyson suddenly hard to push on carpet
I know this sounds silly, but it works. Turn it over and wipe all the black residue off the bottom of it (off the plastic on the bottom that rubs on the carpet as you push and pull it). I thought my husband was out of his mind when he told me that was the solution, but it really works.
Jun 02, 2008 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dyson DC14 Animal Bagless Upright Cyclonic Vacuum Logo
171 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
