Question about Samsung SpinPoint M40 (HM080JI) 80 GB Hard Drive
How can we set our samsung hm080ji driver to slave? There are no jumpers and all info at the samsung site seems to speak about drives with 8 pins instead of 4. We're desperate...
  • 2,567 Answers
This hard drive is a SATA hard disk drive & you cannot set it to slave. This kind of setting is only possible on IDE drives.
Posted on Jul 19, 2009
  • 198 Answers
There's these diagrams. Hope this helps.
Have a nice day!
How can i make my Samsung sp0802 hard drive become the master instead of the slave... thank you very much
Hi Good day!!! follow this
1. Decide which hard drive will be the startup (master) drive. If this drive was the startup drive previously, or if it's a new hard drive, then the master drive designation will already be set.
2. To change the designation of a new drive to be a slave drive, skip to step 4.
3. To change the designation of an existing drive to be a slave drive: Turn off the computer, unplug the power cord, remove the drive from its drive bay, and disconnect the drive from its power cord and ribbon cable.
4. Check the hard drive documentation or the label on the drive itself for master/slave jumper settings.
5. Find the jumpers on the circuit board of the drive. Jumpers are plastic plugs with metal sleeves that form a circuit between a pair of pins. Jumper locations are labeled on the board with a J followed by a number (such as J20).
6. Use tweezers or very small pliers to remove or reposition the jumpers to the configuration shown in the documentation or on the disk label.
7. Install (or reinstall) the hard drive in the computer. (See "How to Install a Second Hard Drive.")
Don't forget to vote thanks!!!
Nov 02, 2010 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
Slave jumper settings for a Maxtor N256 Hard Drive
I have never personally seen one but most drives are the same for the type of jumpers installed. See if this helps you:
http://eshop.macsales.com/Tech/manuals/idehdsettings/Maxtor72.pdf
Apr 28, 2010 | Maxtor Hard Drive
I have a samsung 2.5" sata hdd that I want to make it from a master to slave. I need a pin jumper setting info.
You dont need jumper settings for sata hard drive, the sata ports on *********** board have the configuration, just connect the new hdd to the 2nd sata port.
Mar 24, 2010 | Samsung (MP0804H) 80 GB Hard Drive
Need jumper setting for slave drive ide
If the drive is the Seagate Baracuda series, then simply remove all the jumpers from 8-pin jumper block and it will be a Slave drive.
If you want any other settings, the jumper settings are described here:
Jan 09, 2010 | Seagate (ST380011A) 80 GB IDE Hard Drive
Install old maxtor HD on newer pc, change it from mster to slave
From your own description Slave : Off therefore remove the jumpers
Jul 26, 2009 | Computers & Internet
Installing old maxtor HD on newr pc, have to change it to a slave
J50 is the one furthest from the power connector. To make it a slave remove ALL of the jumpers.
Jul 26, 2009 | Maxtor Hard Drive
How to set a Toshiba MK8064GSX hard drive as a slave? The web site shows a group of 4 pins (2 over 2) This drive has 4 pins in a row.
u have to set the jumper to the set of 2 pins that are after the power cable socket
suppose this is the powercable socket 0000 then the jumper will be set to the 2nd row of the folling pins assembly that will be 0000 :[:]:: jumper position -> [ ] look in to the pic and u need to set the jumper on the pins that says slave
Jul 08, 2009 | Toshiba MK8034GSX 80 GB SATA Hard Drive
Pin connection for 'master ..slave
I assume these are IDE drives since SATA doesn't require jumper settings. . .You will need to set the primary drive jumper to master[ma] & the secondary drive jumper to slave[sl]. Some systems require dual hdd systems to have both set to the cable select[cs] jumper. Check your motherboard or system manufacturer manual to see which setup your system requires. If you lost the manual most manufacturers have it availablr on their website under the support link. Hope this helps.
May 23, 2009 | Excelstor Technology J880 Hard Drive
Strapping or Jumpering for slave
You need the system info for the laptop you are using to see if a 2nd hdd needs to be set as slave or set in the cable select mode. Either right above the jumper pins or on the top of the hdd above the pins you should see 3 groups of 2 pins. They will be marked, ma, cs, & sl. They may not be in this order as each hdd manufacturer is different but all will have those 3 markings. If you set as slave cover the 2 jumper pins marked sl. For cable select cover the 2 pins marked cs. Hope this helps & please remember to rate my answer.
Jan 23, 2009 | Computers & Internet
Samsung SpinPoint M40 (HM080JI) 80 GB Hard Drive Logo
383 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
