E-Machines 19" Widescreen Flat Panel TFT LCD HD Monitor Logo
Posted on Jul 19, 2009
HP vs17 Monitor Flickers and Turns Pink
Monitor is 3 years old. Starting occasionally flickering, then turns pink; when I move the mouse, it resumes normal color. Any solution? Thank you.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 17, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
566
Points
Pink flicker with my monitor was traced to dry joints on PCB of power supply box. Re-soldering all joints cured the problem.
Anonymous
Level 1:
New Friend:
  • Posted on Dec 18, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
566
Points
It Might be the video cable.
1helpful
The display on my L675 S7048 is flickering badly. My whites turn pink, and my blues turn green. I see it when windows starts, even the Microsoft logo has tiny green dots all around it. When I connect an...
WHITE is a mixture of the three "primary" colours.
If one of the colours is not working, then WHITE turns PINK.
So, either your LCD display is malfunctioning,
or the "data" cable between the LCD and the motherboard is malfunctioning (not transmitting all 3 signals),
or the video-card embedded into the motherboard is malfunctioning (not sending all 3 signals).
This is nothing that you can fix by yourself; take your computer to a qualified technician, for trouble-shooting and repair.
Hi, my screen just randomly turned pink im wonderi...
Check all the pins on the VGA cable, also try it on another PC to make sure it is not the PC that is causing the problem. Hopefully it will not be bad lamps.
http://s807.photobucket.com/albums/yy352/budm/Bad%20backlight%20lamp/
Hpvs17e white backround is pink
hucknannie, Power down the pc and monitor. Then disconnect and reconnect the VGA cable a few times to the rear of the pc. then turn system back on and re-boot. If your "PINK" screen still there, then you may need to have unit refurbished with new "cold-cathode-fluorescent-lamps" or have the internal "switch- mode-power supply/ccfl-inverter-supply" inspected and repaired. Yes, before you do anything, visit this web blog about HP monitors!!! http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ Read and make note that people are still visiting the blog even after 4 years!! Hope this response helps. Feel free to leave a comment and also rate this response on fixya. 12fixlouie
My HP w1907 monitor less than a year old is turning pink!
A flickering screen with pink colour is a sign of a CCFL lamp problem.
The CCFL lamp is a mini fluro tube and it provides the back-lighting, it is definitely faulty and about to fail completely.
You need to get it repaired while it is still under warranty.
1helpful
HP Pavilion Entertainment Laptop Monitor flickers black
If the laptop is under a year old it could still be under warranty and if so I would get it repaired under warranty.
OTHERWISE
You could have a faulty inverter or a CCFL lamp, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
3helpful
HP vs15 monitor Flickers then blacks out.
Hello
This monitor has 5 capacitors in the power supply that age prematurely. I can repair this for $50.00 +parts + shipping. Or you can take it to a local repairperson.
Pink screen
Not a motherboard issue. If the screen looks pink it means the backlight tube inside the screen ain't reaching full brightness (the tube has gone bad). If it flickers? Well... remember them good old florescent tubes and what happened when they go bad? Same thing.
You have a bad tube in your screen and ... hence, a defective screen.
White turns to pink on acer laptop
The problem is CCFL light bulb in the screen. It is starting to die :( Can be replaced but that is not an easy task (easier is to replace screen as new bulb comes with it)
Monitor flickers, color turns pink
This has happened to me before, seems when AVG is running is when it is noticable. After playing with the settings and doing a lot of googling and reading, my fix this time was to update the driver for the NEC monitor. It's working great for now.
Top E-Machines Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
